    2017 is here
    82 Posts 31 Posters 14.5k Views 31 Watching
    • K
      kaas
      For people who have/make custom ruby plugins: the way you install / enable extensions has been slightly changed.
      Just in case:
      1. zip your loader.rb (+ folder)
      2. rename the zip to rbz
      3. install by using the extension manager.
      4. In the extension manager - choose the settings (top right) and choose 'unrestricted'
      Edit: seems like dropping rb's still works. It failed at first for me but it must have been another issue.
      • jujuJ
        juju
        minor annoyance I have is that IE11 (I use Chrome for browsing but keep IE installed as SketchUp uses it) keeps on popping up now that I didn't have with the previous version, anybody else experiencing this?
        • jujuJ
          juju
          aaarrgh!
          starting to load extensions (starting on EW) and already have 3 that you can only install from EW directly that have licence issues... seriously??!!!
          the new version isn't starting off so well...
          I am impressed with the LO updates though, I hope the actual lives up to webpage I read on it.
          SU2017 is 64-bit only, I can see some whining there but not from me though, I never needed the 32-bit version in SU2016...
          • K
            kaas
            @juju said:
            ...already have 3 that you can only install from EW directly that have licence issues...
            +1 😞
              The 3D engine upgrade is what'll yield the biggest benefit in following releases.
              Last time we had an upgrade was v7.1. But this release open ups a huge amount of scope in the viewport.
              I like this release. Well done to all involved.
              • N
                numerobis
                I hope you're right and it's a real improvement.
                But what does "in following releases" mean? So there is no improvement now, but maybe in future release? Why not now?
                  driven
                  @juju said:
                  ...keep IE installed as SketchUp uses it...
                  SU now uses an embedded version of Chrome and HTMLDialogs, most plugins that use WebDialogs will not be updated to use it yet and still need IE or Safari to be up to date...
                    There are improvements in SU2017. I can see them on my screen when I look at the model, can't you? The changes they made make it so even more improvements can be made in future releases.
                    • jujuJ
                      juju
                      link to source?
                      +++ EDIT +++
                      OK so I found the reference on the SketchUp page, any references / benches on how much better / faster it is?
                      • C
                        cadmunkey
                        Some nice new features there, looking forward to using it once I finish this project.
                          @numerobis said:
                          I didn't test it myself, i just reacted to the "new features" video.
                          So you made incorrect assumptions without testing for yourself. Download it and try it. What have you got to lose?
                          I see huge line quality improvement and faster redraw on complex models with textures and shadows. Transparency is much nicer especially when you have multiple transparent surfaces overlapping. It handles large texture sizes better, and you can use large textures without degrading sketchy styles.
                          • N
                            numerobis
                            So it's mostly texture related? Not geometry?
                              What do you mean? And why won't you just try it and see for yourself?
                              • jujuJ
                                juju
                                I had to have some sugar water a moment ago, I saw the pricing on the Hololens and the app required to use it for SketchUp models...
                                Hololens: starting at $3000
                                SketchUp Viewer for Hololens: starting at $1499
                                The CheckUp 2017 app is great for people wanting to see if they need to upgrade anything in order to run SketchUp 2017. I tried it and passed on all levels, so minimum specification are met... 👍
                                  For the same reason you don't drive a new car like a lunatic until you get some milage on the clock. Then you drive like a lunatic.
                                  There's no avoiding that 2017 out performs previous releases in terms of viewport performance.
                                  I'm excited about what they can do with this upgraded viewport engine. Look at the Trimble Dimensions demo yesterday with the Hololens integration.
                                  They're downplaying the change but the signs are there. 64bit only. No more software rendering. GPUs on OpenGL 3 or above. It's all geared towards a better viewport performance.
                                  So it begs the question....what as users do we want in the viewport to help sell designs to clients?
                                  Fancy shaders that bring specular reflections, matcap shaders for NPR, soft shadows, per-pixel shading, ambient occlusion etc....
                                  As I said before, I like this release. Faster, more operability with LayOut, new SDK features and overall better platform to build out the extension ecosystem.
                                  As a sidenote, upgrading the engine doesn't mean file imports are faster. SketchUp is a surface modeller and anytime you import a mesh it needs to rebuild it, heal edges, assign textures etc...
                                  You can't benchmark it because everyone's setup is different.
                                  But the change means SketchUp can innovate more with what is possible in the viewport. That is why I look forward to feature request with this pipeline.
                                  Did anyone start a SketchUp 2018 Feature Request thread yet???
                                  • jujuJ
                                    juju
                                    if it's texture related it will help a lot already seeing that the more textures you have in your model the bigger the file size and thus slower performance
                                      The Dynamic Component extension got an overhaul for SU2017 so you need to update it in SU2015 if you're still going to use that version. Go to the Extension Warehouse in SketchUp 2015 and update the extension. Update the other SU extensions while you're at it.
                                      • halroachH
                                        halroach
                                        Thank you Dave, installing the new version in 2015 seems to solve it!
                                        For anyone else encountering this error, the updated Dynamic Components Extension can be found here:
                                        https://extensions.sketchup.com/en/content/dynamic-components
                                        Where could one find more information on what has been updated in the dynamic components extension?
                                        FlexTools - Super Quick Windows, Doors, Slats...
                                        • halroachH
                                          halroach
                                          Just installed Sketchup 2017. Improvements look nice, BUT... Now I am getting an Error in 2015 (that was not there before!)
                                          In 2015 - When I select a dynamic component to see it's 'Component Options' window, the window doesn't work, and I get the following error:
                                          " ERROR: Callback function error: Object doesn't support propery or method 'atachEvent' @/dcbridge.js[601]. "
                                          This makes all dynamic components quite unusable in 2015. Beware!
                                          In 2017 they work ok, but this can really screw things up for many people that are just trying this out...
                                          There have been a few guys here that have been beta testing 2017, and they reported having this bug too... anyone else?!
                                          Anyone got a solution?
                                          [EDIT] - Solution in the post below - installing the latest version of the Dynamic Components Extension (https://extensions.sketchup.com/en/content/dynamic-components)
                                            I think everything that is published about the changes in SU2017 would be in the Release Notes.
                                            I think most of the changes for DCs and the other SU extensions relate to the web page stuff.
                                            • 2 / 5
