    [Plugin] QuadFaceTools
    680 Posts 116 Posters 771.9k Views 116 Watching
    • ithilI
      ithil
      Very cool!!!
      Thank you! πŸ‘
      • plot-parisP
        plot-paris
        Working nicely! Very valuable tool for quick and clean quad face modelling.
        Could you make it so, that the green / red color is removed when disabling Live Mesh Analysis?
        That would show clearly, if the system is switched on or off.
          hm... yea, that's not a bad idea. All though - it would remove the materials completely. It would not restore any materials that might previously been there as it's not being tracked and isn't easily trackable either.
          Logged in issue tracker: https://bitbucket.org/thomthom/quadface-tools/issues/100/remove-analysis-material-after-toggling-it
          • C
            Carto
            Hello ThomThom,
            I'm currently attempting to size a UV texture using the UV Mapping tool with standard measurements (i.e inches 12", 12") but the value is ignored when typed. Did I type the values correctly or miss something else? Thanks.
            Regards
              Hm... can you share a sample model? Maybe it's related to model units or something. (which version of QFT do you have?)
              • C
                Carto
                Hello ThomThom,
                See attached model. I have the latest version 0.11.0
                UV_Example.skp
                  Oh, I see now. The input is accepting input as relative scale - not model units. The input currently represent how many times the texture tiles across the X and Y UV axes.
                  • C
                    Carto
                    Hello ThomThom,
                    Thank you for looking at this. I was just converting from metric to standard, but it would be convenient if you could enter the actual model units. Thanks again for a great plugin.
                    Regards
                      Version 0.12.0
                      • Made OBJ importer create groups from OBJ groups.
                      • Made OBJ importer correct SketchUp's "auto-orientation" of faces which was some times confused by internal faces.
                        Version 0.12.0 was made to allow OBJs exported using Mineways read properly in SketchUp:
                        http://www.realtimerendering.com/erich/minecraft/public/mineways/
                        • eneroth3E
                          eneroth3
                          This is my home in minecraft πŸ˜„ . This really works and it's amazing! Some manual labor was needed to clean up the edges between blocks but that's fine, the plugin does a great job!
                          3D Warehouse
                          (3dwarehouse.sketchup.com)
                          My website: http://julia-christina-eneroth.se/
                          • K
                            kaas
                            Anyone uses OffsetLoop? Whats the best way to use it? I'm getting mostly crashes / bugreport Oops-loops with 0.12.
                              Got a sample model? Screenshot?
                              • K
                                kaas
                                Just a simple box and there we go again. If nobody else has problems I guess its a clash with other plugins. I will try to do a clean install for all my plugins soon.
                                  Doesn't have to be a clash. The offset tool is a recent one that was more of an experiment. I had it hidden for a while but people insisted it should be visible by default. But it will have some problems still. I have an open issue to improve or rewrite it.
                                  That being said - I wasn't able to reproduce your exact scenario. Can you share the model please?
                                  Also, what version of the extension do you have?
                                  • K
                                    kaas
                                    I'm using
                                    QFC 0.12.0
                                    TTlib 2.10.6
                                    I attached a file. The shape doesn't really matter though - sometimes it crashes on me on a simple box...
                                    Edit 10-10-2016: just cleaned my plugin directory. Installed TT_lib2, QFT, Selectiontoys and tested again. Same crashes so I would suspect no clashing plugins.
                                    qft_oops.skp
                                      Hmm.... I cannot reproduce on this one either. Can you do a video capture to show your steps?
                                      • K
                                        kaas
                                        Here you go - shocking isn't it? I'm thinking I'm wasting your time. There must be something wrong at my end. Although it is strange; only TTlib2, QFT, Selection toys installed (all fresh from SketchUcation tools & TTlib2 from Extension warehouse). SU-pro 16.1.1449 64 bit.
                                        Edit + pic: it also crashes after adding a few loops and at some point it doesn't detect the loop anymore (blue line) and...ooops
                                        qft_oops.avi
                                          Hmm... have you submitted the reports? Did you include your name/email other info?
                                          Also, what version of Internet Explorer do you have installed? The error reporting dialog looks odd.
                                          • K
                                            kaas
                                            I have submitted only a very few (user name Max). Sometimes it caused an oops-loop and I didn't report those either.
                                            I'm running win7 x64 on my desktop with IE11.0.9600.18449
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 33
                                            • 34
                                            • 25 / 34
