    [Plugin] 3D Text Editor
    198 Posts 50 Posters 165.0k Views 49 Watching
    • TIGT Online
      I had a sneaking suspicion that his Douglas-Peucker was for curve-simplification...
      For smoothing he'll need algorithms like...
      Butterworth
      Kalman
      Laplacian
      Savitzky-Golay
      Ramer-Douglas-Peucker
      Kolmogorov-Zurbenko
      etc
      There are lots !
      I wonder what Fredo uses in his tool ?
      His code is so complex I can only see what half of it does !
      • tt_suT Offline
        tt_su
        That's correct - I used it with the intent to simplify contour data from imported CAD drawings.
        • V Offline
          viru
          Hello,
          I have 12 users that run this plugin on sketchup8. But sense sk8 is no longer going to work to pull in maps on June 1 I am working on getting all of the plugins that we use to be usable in sk15 with the least amount of work for my user (they like things simple). This seems to function the exact same as in SK8 my only question is there a way to have an icon on the tool bar or perhaps a custom tool bar that would bring this up instead of going to draw> 3d text editor every time?
          Thanks,
          Viru
          Never mind I got this to work I had the correct files I just needed to change one file name to load them. πŸ˜†
          • JClementsJ Offline
            JClements
            Hi Thomas:
            1.
            If a fraction (ie., 1/2) or decimal (.5) is entered for the text size, then the UI gets broken.
            Would it be possible to allow size values less than an inch? If not, then can you error-trap for this?
            2.
            When zoomed in, the screen display of the characters while you enter text in the UI may not be seen. Could there be an option to have the text centered in the SU window OR allow the user to click at a location in the SU window where the text is to be displayed?
              Davidfi1
              Hi.
              Thank you for very useful plugin.
              I want to report a small bug in the plugin.
              The bug is in "Camera facing components" (see attached example 3D Text Bug.skp)
              If I try to edit the text inside this component -
              the new text is moved to face the camera - without the component moving.
              You can see very funny mistakes if try to edit while not facing the camera πŸ˜„
              P.S I am using Sketchup 2015 15.3.331 64-bit on win 7 & EI 11.
                kaas
                ThomThom,
                If I may ask... is there a solution for V16 to prevent this plugin losing focus to SketchUp? If you run this plugin, start typing, at some point the webdialog will loose focus and you're firing keyboard shortcuts instead... This makes working with your plugin a far lesser experience.
                I described the problem already here: http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=63669 and I found a simple fix (see the same topic - 7th post) but that fix seems to only work for simple code and not for more complex tools...
                I hope you know of a better solution...
                  I'm afraid that I don't know how to handle the focus change in SU2016. I know they are looking at it internally, but I don't know what might change.
                    caronte01
                    HI Thomthom,
                    I've used this plugin a lot, and really really like it. It should replace the default text tool in sketchup. Thank you!
                    I've been doing some 3d laser cutting lately, and have been using a lot of "engraving" fonts such as this one:
                    http://www.ffonts.net/Machine-Tool-Gothic.font . The preview in windows font viewer is horrible, but in sketchup they work just fine. If I understand correctly, ttf fonts have to be closed shapes, but that makes for an ineffective engraving/cutting font.
                    I usually create the text and then explode it/edit it to remove the last segment, so I get single line fonts. This is fine, but makes the text non editable after this. Is it possible to have an option in your plugin to use these kind of fonts and not close the loops / draw the last segment.
                    Again, thanks a lot for all your work!
                    Santiago
                      The extension has very little control over how the text is drawn - it's all done by SketchUp.
                      But there is an option to fill or not fill;
                        caronte01
                        Hi Thomthom,
                        thanks for the reply.
                        Yes, but that option only removes the polygon, the lines are all drawn with or without filled polygon.
                        So if I understand, text is created by sketchup directly, not by your plugin. What your plugin does is in a way, control the native sketchup 3d text tool, and keep a reference of the text content, so it can be changed afterwards.
                        Not easy to change I guess, or, it should be changed directly in sketchup's core.
                          Yes, it keeps track of the text and create it using a single API method: http://ruby.sketchup.com/Sketchup/Entities.html#add_3d_text-instance_method
                          It's the UI that's the most complicated part of it - which isn't that complicated by itself.
                            Version 1.2.0
                            This version should be more reliable in getting the list of system fonts. I require update TT_Lib, version 2.11 or newer.
                            • Bob JamesB Offline
                              Bob James
                              I cannot find TT_Lib2 listed in SketchUcation Store
                              • TIGT Online
                                Do a less rigid search [no '2']:
                                https://sketchucation.com/pluginstore?pln=TT_Lib
                                  j_fiore
                                  Hi Thomas,
                                  I have downloaded this plugin and will be using it on a regular bases. It works great for me so far. Thanks for putting it out there.
                                  I have 2 requests for a future version if you are planning on developing this further:
                                  1. A dropdown (or similar) that allows users to choose the layer for the text to be placed on in the context menu. For example, if I want to keep all my text on a layer called "Labels". I know I can do it now by double clicking on the text, highlighting all lines, and putting them on the correct layer. Choosing the layer from the context menu would be a real time saver.
                                  2. I don't know if it is even possible, but I was wondering if there could be a way to have the 3D text auto-fill based on a dynamic component attribute. Maybe something along the lines of the user making a custom attribute called "3D_Text_Input" at the top level of a component, and inserting a 3D text object into the dynamic component as a child component. Then the text field in the context menu for your plugin could automatically retrieve the input via a "=parent!3D_Text_Input" command (or similar). This feature could be turned on or off via a checkbox in the context menu. I would be willing to pay for this functionality because it would save me so much time, but it doesn't exist in any plugin that I am aware of.
                                    Aroundthebend
                                    Hi ThomThom, I'm having problems with 3D Text Editor. If I create some text using this Plugin then rotate it I get problems editing it! After I select 'Edit Text' the text rotates back to it's original orientation!?
                                    I'm using SketchUp Pro 2016 on a Mac OS X 10.11.06.
                                      Jorgensen
                                      I'm having the same issue - not a big deal but it would be nice not to need to rotate in place after edit.
                                      jorgensen
                                      • atelierpaarA Offline
                                        atelierpaar
                                        Hello and good morning,
                                        After intalling 3D Text Editor in SU 2019 I cant find the plugin
                                        Is it me or SU 2019 ??
                                        thanks for looking into it
                                        Uli
                                          Did you look in the Draw menu? Make sure you have installed the most recent version and also the latest TT_Lib2 installed.
                                            atelierpaar
                                            ok that was it !!
                                            the draw menue ist the thing to look for,
                                            thanks for your advice
                                            Uli
                                            • 8 / 10
