    [Plugin] 3D Text Editor
    204 Posts 51 Posters 237.9k Views 50 Watching
    • shake1S
      shake1
      Hi, is it possible to increase the number of segments (before place text)?
      Please make this addition.
      for example
      http://i.imgur.com/oRnBbNG.jpg
        As far as I know the tool already uses the maximum smoothness settings available through the API.
          There's an alternative though. Make the text without extrusion and use Curvizard's Smooth Contours on the curves. I've done that on the S but not on the G in the screen shot.
            That's a solution, but any editing of the 3d-Text will lose the smoothing and it'll need redoing from scratch + extruding again.
              True. But if shake1 has to have smoother curves...
                As far as I know thomthom uses the max smoothness available in the API's .add_3dText method.
                But of course if thomthom were willing he could make the 3dText with no extrusion, then apply some customized smoothing methods to the edges, then pushpull all of the faces to the extrusion value.
                I know thomthom has used some 'douglas_peucker' algorithms etc before to simplify/smooth curves...
                Perhaps they or something similar would help ?
                • shake1S
                  shake1
                  Hi Tig, my friend told me about the "maximum", but i think there are some news about how to work around this limitation.
                  Dave R - yes, i use Curvizard and BZ Convert to catmull spline, but it would be a bit to simplify the process of smoothing
                  is there any chance in the future to do more smoothing inside 3D Text Editor?
                  • G
                    Garry K
                    Hi Tig - I used Douglas Peucker Algorithms back in the early 1990's with GIS. Actually it reduces the geometry through simplicity but doesn't actually increase the smoothness. My first experience with these was with Arc GIS and Map Objects etc. The overall process is to eliminate vertex that are very close to the prior vertex but do so without overly reducing the accuracy of the GIS path.
                    We used it before the US eliminated military GPS selective availability in 2007. After dropping SA and with the more storage and processing power we opted to reduce our reliance upon Douglas Peucker.
                      I had a sneaking suspicion that his Douglas-Peucker was for curve-simplification...
                      For smoothing he'll need algorithms like...
                      Butterworth
                      Kalman
                      Laplacian
                      Savitzky-Golay
                      Ramer-Douglas-Peucker
                      Kolmogorov-Zurbenko
                      etc
                      There are lots !
                      I wonder what Fredo uses in his tool ?
                      His code is so complex I can only see what half of it does !
                      • tt_suT
                        tt_su
                        That's correct - I used it with the intent to simplify contour data from imported CAD drawings.
                        • V
                          viru
                          Hello,
                          I have 12 users that run this plugin on sketchup8. But sense sk8 is no longer going to work to pull in maps on June 1 I am working on getting all of the plugins that we use to be usable in sk15 with the least amount of work for my user (they like things simple). This seems to function the exact same as in SK8 my only question is there a way to have an icon on the tool bar or perhaps a custom tool bar that would bring this up instead of going to draw> 3d text editor every time?
                          Thanks,
                          Viru
                          Never mind I got this to work I had the correct files I just needed to change one file name to load them. 😆
                          • JClementsJ
                            JClements
                            Hi Thomas:
                            1.
                            If a fraction (ie., 1/2) or decimal (.5) is entered for the text size, then the UI gets broken.
                            Would it be possible to allow size values less than an inch? If not, then can you error-trap for this?
                            2.
                            When zoomed in, the screen display of the characters while you enter text in the UI may not be seen. Could there be an option to have the text centered in the SU window OR allow the user to click at a location in the SU window where the text is to be displayed?
                              Davidfi1
                              Hi.
                              Thank you for very useful plugin.
                              I want to report a small bug in the plugin.
                              The bug is in "Camera facing components" (see attached example 3D Text Bug.skp)
                              If I try to edit the text inside this component -
                              the new text is moved to face the camera - without the component moving.
                              You can see very funny mistakes if try to edit while not facing the camera 😄
                              P.S I am using Sketchup 2015 15.3.331 64-bit on win 7 & EI 11.
                              • K
                                kaas
                                ThomThom,
                                If I may ask... is there a solution for V16 to prevent this plugin losing focus to SketchUp? If you run this plugin, start typing, at some point the webdialog will loose focus and you're firing keyboard shortcuts instead... This makes working with your plugin a far lesser experience.
                                I described the problem already here: http://sketchucation.com/forums/viewtopic.php?f=180%26amp;t=63669 and I found a simple fix (see the same topic - 7th post) but that fix seems to only work for simple code and not for more complex tools...
                                I hope you know of a better solution...
                                  I'm afraid that I don't know how to handle the focus change in SU2016. I know they are looking at it internally, but I don't know what might change.
                                  • C
                                    caronte01
                                    HI Thomthom,
                                    I've used this plugin a lot, and really really like it. It should replace the default text tool in sketchup. Thank you!
                                    I've been doing some 3d laser cutting lately, and have been using a lot of "engraving" fonts such as this one:
                                    http://www.ffonts.net/Machine-Tool-Gothic.font . The preview in windows font viewer is horrible, but in sketchup they work just fine. If I understand correctly, ttf fonts have to be closed shapes, but that makes for an ineffective engraving/cutting font.
                                    I usually create the text and then explode it/edit it to remove the last segment, so I get single line fonts. This is fine, but makes the text non editable after this. Is it possible to have an option in your plugin to use these kind of fonts and not close the loops / draw the last segment.
                                    Again, thanks a lot for all your work!
                                    Santiago
                                      The extension has very little control over how the text is drawn - it's all done by SketchUp.
                                      But there is an option to fill or not fill;
                                      • C
                                        caronte01
                                        Hi Thomthom,
                                        thanks for the reply.
                                        Yes, but that option only removes the polygon, the lines are all drawn with or without filled polygon.
                                        So if I understand, text is created by sketchup directly, not by your plugin. What your plugin does is in a way, control the native sketchup 3d text tool, and keep a reference of the text content, so it can be changed afterwards.
                                        Not easy to change I guess, or, it should be changed directly in sketchup's core.
                                          Yes, it keeps track of the text and create it using a single API method: http://ruby.sketchup.com/Sketchup/Entities.html#add_3d_text-instance_method
                                          It's the UI that's the most complicated part of it - which isn't that complicated by itself.
                                            Version 1.2.0
                                            This version should be more reliable in getting the list of system fonts. I require update TT_Lib, version 2.11 or newer.
