    [Plugin] QuadFaceTools
    673 Posts 116 Posters 543.9k Views 116 Watching
    • cottyC Offline
      cotty
      πŸ‘ and πŸ‘
      my SketchUp gallery
      • pbacotP Offline
        Nice!
        • ithilI Offline
          ithil
          Very cool!!!
          Thank you! πŸ‘
          • plot-parisP Offline
            plot-paris
            Working nicely! Very valuable tool for quick and clean quad face modelling.
            Could you make it so, that the green / red color is removed when disabling Live Mesh Analysis?
            That would show clearly, if the system is switched on or off.
              hm... yea, that's not a bad idea. All though - it would remove the materials completely. It would not restore any materials that might previously been there as it's not being tracked and isn't easily trackable either.
              Logged in issue tracker: https://bitbucket.org/thomthom/quadface-tools/issues/100/remove-analysis-material-after-toggling-it
                Carto
                Hello ThomThom,
                I'm currently attempting to size a UV texture using the UV Mapping tool with standard measurements (i.e inches 12", 12") but the value is ignored when typed. Did I type the values correctly or miss something else? Thanks.
                Regards
                  Hm... can you share a sample model? Maybe it's related to model units or something. (which version of QFT do you have?)
                    Carto
                    Hello ThomThom,
                    See attached model. I have the latest version 0.11.0
                    UV_Example.skp
                      Oh, I see now. The input is accepting input as relative scale - not model units. The input currently represent how many times the texture tiles across the X and Y UV axes.
                        Carto
                        Hello ThomThom,
                        Thank you for looking at this. I was just converting from metric to standard, but it would be convenient if you could enter the actual model units. Thanks again for a great plugin.
                        Regards
                          Version 0.12.0
                          • Made OBJ importer create groups from OBJ groups.
                          • Made OBJ importer correct SketchUp's "auto-orientation" of faces which was some times confused by internal faces.
                            Version 0.12.0 was made to allow OBJs exported using Mineways read properly in SketchUp:
                            Mineways
                            (www.realtimerendering.com)
                            • eneroth3E Offline
                              eneroth3
                              This is my home in minecraft πŸ˜„ . This really works and it's amazing! Some manual labor was needed to clean up the edges between blocks but that's fine, the plugin does a great job!
                              3D Warehouse
                              (3dwarehouse.sketchup.com)
                              My website: http://julia-christina-eneroth.se/
                                kaas
                                Anyone uses OffsetLoop? Whats the best way to use it? I'm getting mostly crashes / bugreport Oops-loops with 0.12.
                                  Got a sample model? Screenshot?
                                    kaas
                                    Just a simple box and there we go again. If nobody else has problems I guess its a clash with other plugins. I will try to do a clean install for all my plugins soon.
                                      Doesn't have to be a clash. The offset tool is a recent one that was more of an experiment. I had it hidden for a while but people insisted it should be visible by default. But it will have some problems still. I have an open issue to improve or rewrite it.
                                      That being said - I wasn't able to reproduce your exact scenario. Can you share the model please?
                                      Also, what version of the extension do you have?
                                        kaas
                                        I'm using
                                        QFC 0.12.0
                                        TTlib 2.10.6
                                        I attached a file. The shape doesn't really matter though - sometimes it crashes on me on a simple box...
                                        Edit 10-10-2016: just cleaned my plugin directory. Installed TT_lib2, QFT, Selectiontoys and tested again. Same crashes so I would suspect no clashing plugins.
                                        qft_oops.skp
                                          Hmm.... I cannot reproduce on this one either. Can you do a video capture to show your steps?
                                            kaas
                                            Here you go - shocking isn't it? I'm thinking I'm wasting your time. There must be something wrong at my end. Although it is strange; only TTlib2, QFT, Selection toys installed (all fresh from SketchUcation tools & TTlib2 from Extension warehouse). SU-pro 16.1.1449 64 bit.
                                            Edit + pic: it also crashes after adding a few loops and at some point it doesn't detect the loop anymore (blue line) and...ooops
                                            qft_oops.avi
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 33
                                            • 34
                                            • 18 / 34
