    [Plugin] QuadFaceTools
    680 Posts 116 Posters 647.5k Views 116 Watching
    • plot-parisP Offline
      plot-paris
      Hey guys,
      I run into this problem quite often, where I model a shape, making sure, every surface is a quad.
      But when I use SUbD to subdivide, it looks wrong.
      When I then use the "Flip Triangulation Tool" of QuadFaceTools, I can see that some faces (marked red in the model below) are not being recognized as quads.
      Does any one know how this happens? And more importantly, how to fix it?
      Cheers,
      Jakob
      QuadProblem_v01.skp
      • BoxB Offline
        Sometimes you just need to tell it to make quads.
          plot-paris
          haha, I could have sworn I tried that. But obviously I didn't. 😳
          Thanks a lot
            That reminds me - I had this idea for a function that would automatically color the faces as you modelled. I added an issue to track this: https://bitbucket.org/thomthom/quadface-tools/issues/98/live-quad-validation
              Just need an icon...
                Version 0.11.0 is out.
                • N Offline
                  numerobis
                  😎 πŸ‘
                  • cottyC Offline
                    cotty
                    πŸ‘ and πŸ‘
                    my SketchUp gallery
                    • pbacotP Offline
                      Nice!
                      • ithilI Offline
                        ithil
                        Very cool!!!
                        Thank you! πŸ‘
                          plot-paris
                          Working nicely! Very valuable tool for quick and clean quad face modelling.
                          Could you make it so, that the green / red color is removed when disabling Live Mesh Analysis?
                          That would show clearly, if the system is switched on or off.
                            hm... yea, that's not a bad idea. All though - it would remove the materials completely. It would not restore any materials that might previously been there as it's not being tracked and isn't easily trackable either.
                            Logged in issue tracker: https://bitbucket.org/thomthom/quadface-tools/issues/100/remove-analysis-material-after-toggling-it
                              Carto
                              Hello ThomThom,
                              I'm currently attempting to size a UV texture using the UV Mapping tool with standard measurements (i.e inches 12", 12") but the value is ignored when typed. Did I type the values correctly or miss something else? Thanks.
                              Regards
                                Hm... can you share a sample model? Maybe it's related to model units or something. (which version of QFT do you have?)
                                  Carto
                                  Hello ThomThom,
                                  See attached model. I have the latest version 0.11.0
                                  UV_Example.skp
                                    Oh, I see now. The input is accepting input as relative scale - not model units. The input currently represent how many times the texture tiles across the X and Y UV axes.
                                      Carto
                                      Hello ThomThom,
                                      Thank you for looking at this. I was just converting from metric to standard, but it would be convenient if you could enter the actual model units. Thanks again for a great plugin.
                                      Regards
                                        Version 0.12.0
                                        • Made OBJ importer create groups from OBJ groups.
                                        • Made OBJ importer correct SketchUp's "auto-orientation" of faces which was some times confused by internal faces.
                                          Version 0.12.0 was made to allow OBJs exported using Mineways read properly in SketchUp:
                                          Just a moment...
                                          (www.realtimerendering.com)
                                          • eneroth3E Offline
                                            eneroth3
                                            This is my home in minecraft πŸ˜„ . This really works and it's amazing! Some manual labor was needed to clean up the edges between blocks but that's fine, the plugin does a great job!
                                            3D Warehouse
                                            (3dwarehouse.sketchup.com)
                                            My website: http://julia-christina-eneroth.se/
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 33
                                            • 34
                                            • 25 / 34
