    [Plugin] QuadFaceTools
    673 Posts 116 Posters 524.4k Views 116 Watching
    • N Offline
      numerobis
      😎 πŸ‘
      • cottyC Offline
        cotty
        πŸ‘ and πŸ‘
        my SketchUp gallery
        • pbacotP Offline
          Nice!
          • ithilI Offline
            ithil
            Very cool!!!
            Thank you! πŸ‘
            • plot-parisP Offline
              plot-paris
              Working nicely! Very valuable tool for quick and clean quad face modelling.
              Could you make it so, that the green / red color is removed when disabling Live Mesh Analysis?
              That would show clearly, if the system is switched on or off.
                hm... yea, that's not a bad idea. All though - it would remove the materials completely. It would not restore any materials that might previously been there as it's not being tracked and isn't easily trackable either.
                Logged in issue tracker: https://bitbucket.org/thomthom/quadface-tools/issues/100/remove-analysis-material-after-toggling-it
                  Carto
                  Hello ThomThom,
                  I'm currently attempting to size a UV texture using the UV Mapping tool with standard measurements (i.e inches 12", 12") but the value is ignored when typed. Did I type the values correctly or miss something else? Thanks.
                  Regards
                    Hm... can you share a sample model? Maybe it's related to model units or something. (which version of QFT do you have?)
                      Carto
                      Hello ThomThom,
                      See attached model. I have the latest version 0.11.0
                      UV_Example.skp
                        Oh, I see now. The input is accepting input as relative scale - not model units. The input currently represent how many times the texture tiles across the X and Y UV axes.
                          Carto
                          Hello ThomThom,
                          Thank you for looking at this. I was just converting from metric to standard, but it would be convenient if you could enter the actual model units. Thanks again for a great plugin.
                          Regards
                            Version 0.12.0
                            • Made OBJ importer create groups from OBJ groups.
                            • Made OBJ importer correct SketchUp's "auto-orientation" of faces which was some times confused by internal faces.
                              Version 0.12.0 was made to allow OBJs exported using Mineways read properly in SketchUp:
                              Mineways
                              (www.realtimerendering.com)
                              • eneroth3E Offline
                                eneroth3
                                This is my home in minecraft πŸ˜„ . This really works and it's amazing! Some manual labor was needed to clean up the edges between blocks but that's fine, the plugin does a great job!
                                3D Warehouse
                                (3dwarehouse.sketchup.com)
                                My website: http://julia-christina-eneroth.se/
                                  kaas
                                  Anyone uses OffsetLoop? Whats the best way to use it? I'm getting mostly crashes / bugreport Oops-loops with 0.12.
                                    Got a sample model? Screenshot?
                                      kaas
                                      Just a simple box and there we go again. If nobody else has problems I guess its a clash with other plugins. I will try to do a clean install for all my plugins soon.
                                        Doesn't have to be a clash. The offset tool is a recent one that was more of an experiment. I had it hidden for a while but people insisted it should be visible by default. But it will have some problems still. I have an open issue to improve or rewrite it.
                                        That being said - I wasn't able to reproduce your exact scenario. Can you share the model please?
                                        Also, what version of the extension do you have?
                                          kaas
                                          I'm using
                                          QFC 0.12.0
                                          TTlib 2.10.6
                                          I attached a file. The shape doesn't really matter though - sometimes it crashes on me on a simple box...
                                          Edit 10-10-2016: just cleaned my plugin directory. Installed TT_lib2, QFT, Selectiontoys and tested again. Same crashes so I would suspect no clashing plugins.
                                          qft_oops.skp
                                            Hmm.... I cannot reproduce on this one either. Can you do a video capture to show your steps?
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 33
                                            • 34
                                            • 19 / 34
