    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 393.0k Views 109 Watching
    • TIGT Online
      @Sabastien
      Please open the Ruby Console.
      Now try to use the tool.
      What happens?
      Any error messages?
      Are you selecting a face before running the tool?
      More info please...
      • N Offline
        Nibelungs
        @tig said:
        @Sabastien
        What happens?
        Any error messages?
        More info please...
        Hi, sorry for my late.
        The error in the Ruby Console is " <SystemStackError: stack level too deep> C:/Users/*/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:95 "
        • sdmitchS Offline
          sdmitch
          Are you using metric or inches? Do you use "." or "," as the decimal separator?
          My guess is that the plugin is being caught in a perpetual loop of trying to read/write the current defaults.
          http://sdmitch.blogspot.com/
            autumnwind
            Hi to everybody, I can't make it work on my project. It creates the grid but no bricks, or sometimes accidentally it creates just 3 or 4 bricks. the error seems to happen most when I use the offset (and I need it actually). I have no error in my geometry apparently, just it's not that regularly in its border so it implies many bricks to be cut.
            any suggestion or possible error?
            thanks in advance
            • sdmitchS Offline
              sdmitch
              thanks in advance
              If you would care to post a model, version<=2014, containing the face and a list or screenshot of the parameters you are attempting to use, I will try to determine and fix the problem.
                gnome_mo
                Guys, I have a problem. I can't seem to make tiles 200*200mm size, always getting the same message:
                "TILE DIMENSIONS MAY BE TOO SMALL. 2008 TILE NEEDED".
                What am I doing wrong?
                • sdmitchS Offline
                  sdmitch
                  You aren't doing anything wrong. It just letting you know that the size choosen will result in a large number of tiles. Click "Yes" in the messagebox to proceed.
                  • deaneauD Offline
                    deaneau
                    Here some inspirations for grids. the download is a PDF format. This can instantly imported in illustrator (AI) and than exported as dxf, eps, svg.
                    is only a tip not a request πŸ˜‰
                    greetings from berlin
                    Dean
                    Link: https://incompetech.com/graphpaper/
                    • sdmitchS Offline
                      sdmitch
                      @gnome_mo said:
                      Mitch, I can't thank you enough.
                      I feel kinda stupid to ask this, but I can't figure it out:
                      I would like to make tiles or wood like this picture. I've made it "by hand" but I'm sure you have settings to make it like this (next row is half length moved). Is it possible?
                      https://s9.postimg.org/yplue0417/Capture.jpg
                      Use the 'Brick' pattern or 'Tile' pattern with 50% offset.
                        gnome_mo
                        πŸ‘ πŸ‘ πŸ‘
                          mumbus
                          First off let me say that this plugin is amazing and I use it often. I do have a question about it. Often times when I am generating a floor with a wood material already attached to the surface, it rotates the texture 90 degrees when it completes the floor. So the texture ends up running perpendicular to the board. I have tried various solutions like rotating the texture 90 degrees before running the plugin, reinserted the texture, etc. Any thoughts on this?
                          • sdmitchS Offline
                            sdmitch
                            The plugin doesn't do any UV mapping of the existing material so each "board" is treated as an independent face with the material applied to each just as if you did it manually.
                              mumbus
                              Perhaps I am not explaining myself properly. I have attached an animated .gif as an example. I use this to randomly distribute the texture around the boards.
                              • sdmitchS Offline
                                sdmitch
                                If you want the "Wood" pattern to look just like the face with the material applied then you have to map the texture to each face that is created by FloorGenerator.
                                  devrimimar
                                  I downloaded several times but It does not work? Any idea ?
                                  • sdmitchS Offline
                                    sdmitch
                                    No, but if you want to provide a little more information like Sketchup version, where you are downloading from, where are you downloading to, Ruby Console output when trying to use, etc., I might be able to help.
                                    • Mousa_SAM Offline
                                      Mousa_SA
                                      Hello Sdmitch,
                                      Firstly thanks for this great plugin, it is very useful, I have a feature request and I would be appreciated if you can add it to your plugin.
                                      V-ray 3.4 for Sketchup have a features is called MultiSubTex and TriPlanar, these features will add a ability to random the texture for the same component after rendering (in V-ray Frame Buffer), so it will be great if your plugin have an option to make similar tiles as component, that will reduce the file size in some cases, Note it will put the tiles which have been cut (by the face boundary) in one group, So what so you think ?
                                      • sdmitchS Offline
                                        sdmitch
                                        Sorry, but I think not.
                                        • deaneauD Offline
                                          deaneau
                                          @Mousa_SA is this a post rendering effect?
                                          I think a good way is to provide the developers with pictures. not all devΒ΄s have all plugins on the disk. vray is really a little bit special. i like that some render engine developer provide sketchup. what do you think about to ask the vray developer,too?
                                          @sdmitch i must repeat me by myself... your "small" plugins will be every time helpful. some plugins i use every time when i have a project with sidewalks etc. or when i have an other problem πŸ˜‰
                                          some plugins i will never missing. nice that you have now an email contact address.
                                          i will tell you a thank you.
                                          Dean
                                          • Mousa_SAM Offline
                                            Mousa_SA
                                            Dean
                                            Yes Dean, you can say that, in Sketchup 2017 it's has an object IDs Feature, so Chaos group will implement MultiSubTex, you can read more about it here:
                                            https://docs.chaosgroup.com/display/VRAYSKETCHUP/MultiSub+Tex
                                            And Ithil made this tutorial for the TexTriplaner Feature:
                                            https://www.youtube.com/watch?v=VVD_UfJA5Hc
                                            sdmitch, maybe that deserve another look !
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
