    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 433.6k Views 109 Watching
      mumbus
      First off let me say that this plugin is amazing and I use it often. I do have a question about it. Often times when I am generating a floor with a wood material already attached to the surface, it rotates the texture 90 degrees when it completes the floor. So the texture ends up running perpendicular to the board. I have tried various solutions like rotating the texture 90 degrees before running the plugin, reinserted the texture, etc. Any thoughts on this?
      • sdmitchS
        sdmitch
        The plugin doesn't do any UV mapping of the existing material so each "board" is treated as an independent face with the material applied to each just as if you did it manually.
        http://sdmitch.blogspot.com/
          mumbus
          Perhaps I am not explaining myself properly. I have attached an animated .gif as an example. I use this to randomly distribute the texture around the boards.
          • sdmitchS
            sdmitch
            If you want the "Wood" pattern to look just like the face with the material applied then you have to map the texture to each face that is created by FloorGenerator.
              devrimimar
              I downloaded several times but It does not work? Any idea ?
              • sdmitchS
                sdmitch
                No, but if you want to provide a little more information like Sketchup version, where you are downloading from, where are you downloading to, Ruby Console output when trying to use, etc., I might be able to help.
                • Mousa_SAM
                  Mousa_SA
                  Hello Sdmitch,
                  Firstly thanks for this great plugin, it is very useful, I have a feature request and I would be appreciated if you can add it to your plugin.
                  V-ray 3.4 for Sketchup have a features is called MultiSubTex and TriPlanar, these features will add a ability to random the texture for the same component after rendering (in V-ray Frame Buffer), so it will be great if your plugin have an option to make similar tiles as component, that will reduce the file size in some cases, Note it will put the tiles which have been cut (by the face boundary) in one group, So what so you think ?
                  • sdmitchS
                    sdmitch
                    Sorry, but I think not.
                    • deaneauD
                      deaneau
                      @Mousa_SA is this a post rendering effect?
                      I think a good way is to provide the developers with pictures. not all dev´s have all plugins on the disk. vray is really a little bit special. i like that some render engine developer provide sketchup. what do you think about to ask the vray developer,too?
                      @sdmitch i must repeat me by myself... your "small" plugins will be every time helpful. some plugins i use every time when i have a project with sidewalks etc. or when i have an other problem 😉
                      some plugins i will never missing. nice that you have now an email contact address.
                      i will tell you a thank you.
                      Dean
                      • Mousa_SAM
                        Mousa_SA
                        Dean
                        Yes Dean, you can say that, in Sketchup 2017 it's has an object IDs Feature, so Chaos group will implement MultiSubTex, you can read more about it here:
                        https://docs.chaosgroup.com/display/VRAYSKETCHUP/MultiSub+Tex
                        And Ithil made this tutorial for the TexTriplaner Feature:
                        https://www.youtube.com/watch?v=VVD_UfJA5Hc
                        sdmitch, maybe that deserve another look !
                        • yourpasswordisY
                          yourpasswordis
                          I saw it posted on the first page of this plugin, a LAP setting would be AMAZING.
                          I'm in Architectural Visualization and material properties don't allow for accurate displacement maps. A plugin like this is tantalizingly close to creating the repeating clap/lap siding which our pro-user group needs. Sketchup has been blessed with rendering engines but this modelling aid is missing!
                          The difference between good enough and awesome is huge
                          • sdmitchS
                            sdmitch
                            I did try to develop a clapboard option several years ago but never produced a satisfactory one. Perhaps it would be worth another look.
                              seghier
                              hello
                              where is the link ?
                                You will find Floor Generator here! 😉
                                http://sdmitch.blogspot.fr/
                                  meegg
                                  Your plugin is amazing. Thank You.
                                  Is there a possibility to make some additional options in octagons pattern? Option to give the size of two tiles: the big one and the smaller one. It would be very helpful.
                                  • sdmitchS
                                    sdmitch
                                    Have you looked at the "Hopscotch" patterns?
                                    • sdmitchS
                                      sdmitch
                                      A basic "Clapboard" option has been added.
                                      • P
                                        peerman
                                        That is great!! Thank you for the LAP addition!
                                        iMac i7 4,2GHz, 32GB RAM, OS X 10.13.5, Sketchup 2018 Pro, ArchiCAD 21, V-Ray 3.6
                                          meegg
                                          "Hopscotch" pattern doesn't fit 😉
                                          It must be octagonal pattern but with specific dimensions of two tiles: the big one - octagonal and smaller one - square tile.
                                            rogalxxx
                                            I'm having problems with the plugin in SU 2017. Su 2015 seems to be working fine.
                                            Using even stock settings I get a lot of random tiles missing.
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
