    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 433.6k Views 109 Watching
      skavan
      Oh gosh - thank you so much that would be awesome!
      If it helps, I have attached a simple SU (2013 for max compatibility) file that shows the concept.
      The polygon on the left is a simple version of a target shape with the desired tile centerpoint shown as the intersection of two guidelines.
      The shape on the right is my current workaround -- which is to force the shape to be equidistant around this target point, and then to go back and trim the excess. This is not too much of a pain on this simple example, but becomes very time consuming when one of the side corridor arms, bends at say 45 degrees! Hopefully it makes more sense to look at than to explain in text!
      Oh - as a tiny cosmetic point, if I choose a tight gap width of say 3/16" (vs. 1/4") it works fine, and is seemingly saved to defaults. When I next open the plugin, it shows as 1/4" not 3/16". I'm pretty sure its storing the right number, but the display is formatted to a single digit fraction. Would be great to expand the formatting to two digits.
      Thanks again for a truely time saving plugin.
      s.
      FloorGen test.skp
        skavan
        and one more teeny thing for utter coolness is to support an alternating material...for a checkerboard style.
        I can think of two ways of (easily??) doing this:
        1. If different materials are applied to front and back of face and Current Texture is chosen, alternate material, starting with front then back -OR-
        2. If a "special seed value" like -1 is chosen, alternate between the chosen materials in selection via the rand_tex option.
        I hope you can tell that I just LOVE your plugin and am using it to figure out how to tile a 15,000 sq.ft house!
        I promise to stop now!
        • sdmitchS
          sdmitch
          Sorry but the way this plugin creates the pattern, by intersecting a grid with the selected face, it is impossible to predict the order of the created faces.
          http://sdmitch.blogspot.com/
          • N
            Nibelungs
            It does not work with Sketchup 2015?
            The plugin is installed, I see it in the toolbar ... but it does not open when I pressed. 😞
              @Sabastien
              Please open the Ruby Console.
              Now try to use the tool.
              What happens?
              Any error messages?
              Are you selecting a face before running the tool?
              More info please...
              • N
                Nibelungs
                @tig said:
                @Sabastien
                What happens?
                Any error messages?
                More info please...
                Hi, sorry for my late.
                The error in the Ruby Console is " <SystemStackError: stack level too deep> C:/Users/*/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:95 "
                • sdmitchS
                  sdmitch
                  Are you using metric or inches? Do you use "." or "," as the decimal separator?
                  My guess is that the plugin is being caught in a perpetual loop of trying to read/write the current defaults.
                    autumnwind
                    Hi to everybody, I can't make it work on my project. It creates the grid but no bricks, or sometimes accidentally it creates just 3 or 4 bricks. the error seems to happen most when I use the offset (and I need it actually). I have no error in my geometry apparently, just it's not that regularly in its border so it implies many bricks to be cut.
                    any suggestion or possible error?
                    thanks in advance
                    • sdmitchS
                      sdmitch
                      thanks in advance
                      If you would care to post a model, version<=2014, containing the face and a list or screenshot of the parameters you are attempting to use, I will try to determine and fix the problem.
                      • G
                        gnome_mo
                        Guys, I have a problem. I can't seem to make tiles 200*200mm size, always getting the same message:
                        "TILE DIMENSIONS MAY BE TOO SMALL. 2008 TILE NEEDED".
                        What am I doing wrong?
                        • sdmitchS
                          sdmitch
                          You aren't doing anything wrong. It just letting you know that the size choosen will result in a large number of tiles. Click "Yes" in the messagebox to proceed.
                          • deaneauD
                            deaneau
                            Here some inspirations for grids. the download is a PDF format. This can instantly imported in illustrator (AI) and than exported as dxf, eps, svg.
                            is only a tip not a request πŸ˜‰
                            greetings from berlin
                            Dean
                            Link: https://incompetech.com/graphpaper/
                            • sdmitchS
                              sdmitch
                              @gnome_mo said:
                              Mitch, I can't thank you enough.
                              I feel kinda stupid to ask this, but I can't figure it out:
                              I would like to make tiles or wood like this picture. I've made it "by hand" but I'm sure you have settings to make it like this (next row is half length moved). Is it possible?
                              https://s9.postimg.org/yplue0417/Capture.jpg
                              Use the 'Brick' pattern or 'Tile' pattern with 50% offset.
                              • G
                                gnome_mo
                                πŸ‘ πŸ‘ πŸ‘
                                  mumbus
                                  First off let me say that this plugin is amazing and I use it often. I do have a question about it. Often times when I am generating a floor with a wood material already attached to the surface, it rotates the texture 90 degrees when it completes the floor. So the texture ends up running perpendicular to the board. I have tried various solutions like rotating the texture 90 degrees before running the plugin, reinserted the texture, etc. Any thoughts on this?
                                  • sdmitchS
                                    sdmitch
                                    The plugin doesn't do any UV mapping of the existing material so each "board" is treated as an independent face with the material applied to each just as if you did it manually.
                                      mumbus
                                      Perhaps I am not explaining myself properly. I have attached an animated .gif as an example. I use this to randomly distribute the texture around the boards.
                                      • sdmitchS
                                        sdmitch
                                        If you want the "Wood" pattern to look just like the face with the material applied then you have to map the texture to each face that is created by FloorGenerator.
                                          devrimimar
                                          I downloaded several times but It does not work? Any idea ?
                                          • sdmitchS
                                            sdmitch
                                            No, but if you want to provide a little more information like Sketchup version, where you are downloading from, where are you downloading to, Ruby Console output when trying to use, etc., I might be able to help.
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
