    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 439.9k Views 109 Watching
    • deaneauD
      deaneau
      Here some inspirations for grids. the download is a PDF format. This can instantly imported in illustrator (AI) and than exported as dxf, eps, svg.
      is only a tip not a request πŸ˜‰
      greetings from berlin
      Dean
      Link: https://incompetech.com/graphpaper/
      • sdmitchS
        sdmitch
        @gnome_mo said:
        Mitch, I can't thank you enough.
        I feel kinda stupid to ask this, but I can't figure it out:
        I would like to make tiles or wood like this picture. I've made it "by hand" but I'm sure you have settings to make it like this (next row is half length moved). Is it possible?
        https://s9.postimg.org/yplue0417/Capture.jpg
        Use the 'Brick' pattern or 'Tile' pattern with 50% offset.
        http://sdmitch.blogspot.com/
        • G
          gnome_mo
          πŸ‘ πŸ‘ πŸ‘
            mumbus
            First off let me say that this plugin is amazing and I use it often. I do have a question about it. Often times when I am generating a floor with a wood material already attached to the surface, it rotates the texture 90 degrees when it completes the floor. So the texture ends up running perpendicular to the board. I have tried various solutions like rotating the texture 90 degrees before running the plugin, reinserted the texture, etc. Any thoughts on this?
            • sdmitchS
              sdmitch
              The plugin doesn't do any UV mapping of the existing material so each "board" is treated as an independent face with the material applied to each just as if you did it manually.
                mumbus
                Perhaps I am not explaining myself properly. I have attached an animated .gif as an example. I use this to randomly distribute the texture around the boards.
                • sdmitchS
                  sdmitch
                  If you want the "Wood" pattern to look just like the face with the material applied then you have to map the texture to each face that is created by FloorGenerator.
                    devrimimar
                    I downloaded several times but It does not work? Any idea ?
                    • sdmitchS
                      sdmitch
                      No, but if you want to provide a little more information like Sketchup version, where you are downloading from, where are you downloading to, Ruby Console output when trying to use, etc., I might be able to help.
                      • Mousa_SAM
                        Mousa_SA
                        Hello Sdmitch,
                        Firstly thanks for this great plugin, it is very useful, I have a feature request and I would be appreciated if you can add it to your plugin.
                        V-ray 3.4 for Sketchup have a features is called MultiSubTex and TriPlanar, these features will add a ability to random the texture for the same component after rendering (in V-ray Frame Buffer), so it will be great if your plugin have an option to make similar tiles as component, that will reduce the file size in some cases, Note it will put the tiles which have been cut (by the face boundary) in one group, So what so you think ?
                        • sdmitchS
                          sdmitch
                          Sorry, but I think not.
                          • deaneauD
                            deaneau
                            @Mousa_SA is this a post rendering effect?
                            I think a good way is to provide the developers with pictures. not all devΒ΄s have all plugins on the disk. vray is really a little bit special. i like that some render engine developer provide sketchup. what do you think about to ask the vray developer,too?
                            @sdmitch i must repeat me by myself... your "small" plugins will be every time helpful. some plugins i use every time when i have a project with sidewalks etc. or when i have an other problem πŸ˜‰
                            some plugins i will never missing. nice that you have now an email contact address.
                            i will tell you a thank you.
                            Dean
                            • Mousa_SAM
                              Mousa_SA
                              Dean
                              Yes Dean, you can say that, in Sketchup 2017 it's has an object IDs Feature, so Chaos group will implement MultiSubTex, you can read more about it here:
                              https://docs.chaosgroup.com/display/VRAYSKETCHUP/MultiSub+Tex
                              And Ithil made this tutorial for the TexTriplaner Feature:
                              https://www.youtube.com/watch?v=VVD_UfJA5Hc
                              sdmitch, maybe that deserve another look !
                              • yourpasswordisY
                                yourpasswordis
                                I saw it posted on the first page of this plugin, a LAP setting would be AMAZING.
                                I'm in Architectural Visualization and material properties don't allow for accurate displacement maps. A plugin like this is tantalizingly close to creating the repeating clap/lap siding which our pro-user group needs. Sketchup has been blessed with rendering engines but this modelling aid is missing!
                                The difference between good enough and awesome is huge
                                • sdmitchS
                                  sdmitch
                                  I did try to develop a clapboard option several years ago but never produced a satisfactory one. Perhaps it would be worth another look.
                                    seghier
                                    hello
                                    where is the link ?
                                      You will find Floor Generator here! πŸ˜‰
                                      http://sdmitch.blogspot.fr/
                                        meegg
                                        Your plugin is amazing. Thank You.
                                        Is there a possibility to make some additional options in octagons pattern? Option to give the size of two tiles: the big one and the smaller one. It would be very helpful.
                                        • sdmitchS
                                          sdmitch
                                          Have you looked at the "Hopscotch" patterns?
                                          • sdmitchS
                                            sdmitch
                                            A basic "Clapboard" option has been added.
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
