    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 357.4k Views 109 Watching
    • N Offline
      Nibelungs
      It does not work with Sketchup 2015?
      The plugin is installed, I see it in the toolbar ... but it does not open when I pressed. 😞
        @Sabastien
        Please open the Ruby Console.
        Now try to use the tool.
        What happens?
        Any error messages?
        Are you selecting a face before running the tool?
        More info please...
        • N Offline
          Nibelungs
          @tig said:
          @Sabastien
          What happens?
          Any error messages?
          More info please...
          Hi, sorry for my late.
          The error in the Ruby Console is " <SystemStackError: stack level too deep> C:/Users/*/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/SDM_FloorGenerator_WD.rb:95 "
          • sdmitchS Offline
            sdmitch
            Are you using metric or inches? Do you use "." or "," as the decimal separator?
            My guess is that the plugin is being caught in a perpetual loop of trying to read/write the current defaults.
            http://sdmitch.blogspot.com/
              autumnwind
              Hi to everybody, I can't make it work on my project. It creates the grid but no bricks, or sometimes accidentally it creates just 3 or 4 bricks. the error seems to happen most when I use the offset (and I need it actually). I have no error in my geometry apparently, just it's not that regularly in its border so it implies many bricks to be cut.
              any suggestion or possible error?
              thanks in advance
              • sdmitchS Offline
                sdmitch
                thanks in advance
                If you would care to post a model, version<=2014, containing the face and a list or screenshot of the parameters you are attempting to use, I will try to determine and fix the problem.
                  gnome_mo
                  Guys, I have a problem. I can't seem to make tiles 200*200mm size, always getting the same message:
                  "TILE DIMENSIONS MAY BE TOO SMALL. 2008 TILE NEEDED".
                  What am I doing wrong?
                  • sdmitchS Offline
                    sdmitch
                    You aren't doing anything wrong. It just letting you know that the size choosen will result in a large number of tiles. Click "Yes" in the messagebox to proceed.
                    • deaneauD Offline
                      deaneau
                      Here some inspirations for grids. the download is a PDF format. This can instantly imported in illustrator (AI) and than exported as dxf, eps, svg.
                      is only a tip not a request πŸ˜‰
                      greetings from berlin
                      Dean
                      Link: https://incompetech.com/graphpaper/
                      • sdmitchS Offline
                        sdmitch
                        @gnome_mo said:
                        Mitch, I can't thank you enough.
                        I feel kinda stupid to ask this, but I can't figure it out:
                        I would like to make tiles or wood like this picture. I've made it "by hand" but I'm sure you have settings to make it like this (next row is half length moved). Is it possible?
                        https://s9.postimg.org/yplue0417/Capture.jpg
                        Use the 'Brick' pattern or 'Tile' pattern with 50% offset.
                          gnome_mo
                          πŸ‘ πŸ‘ πŸ‘
                            mumbus
                            First off let me say that this plugin is amazing and I use it often. I do have a question about it. Often times when I am generating a floor with a wood material already attached to the surface, it rotates the texture 90 degrees when it completes the floor. So the texture ends up running perpendicular to the board. I have tried various solutions like rotating the texture 90 degrees before running the plugin, reinserted the texture, etc. Any thoughts on this?
                            • sdmitchS Offline
                              sdmitch
                              The plugin doesn't do any UV mapping of the existing material so each "board" is treated as an independent face with the material applied to each just as if you did it manually.
                                mumbus
                                Perhaps I am not explaining myself properly. I have attached an animated .gif as an example. I use this to randomly distribute the texture around the boards.
                                • sdmitchS Offline
                                  sdmitch
                                  If you want the "Wood" pattern to look just like the face with the material applied then you have to map the texture to each face that is created by FloorGenerator.
                                    devrimimar
                                    I downloaded several times but It does not work? Any idea ?
                                    • sdmitchS Offline
                                      sdmitch
                                      No, but if you want to provide a little more information like Sketchup version, where you are downloading from, where are you downloading to, Ruby Console output when trying to use, etc., I might be able to help.
                                      • Mousa_SAM Offline
                                        Mousa_SA
                                        Hello Sdmitch,
                                        Firstly thanks for this great plugin, it is very useful, I have a feature request and I would be appreciated if you can add it to your plugin.
                                        V-ray 3.4 for Sketchup have a features is called MultiSubTex and TriPlanar, these features will add a ability to random the texture for the same component after rendering (in V-ray Frame Buffer), so it will be great if your plugin have an option to make similar tiles as component, that will reduce the file size in some cases, Note it will put the tiles which have been cut (by the face boundary) in one group, So what so you think ?
                                        • sdmitchS Offline
                                          sdmitch
                                          Sorry, but I think not.
                                          • deaneauD Offline
                                            deaneau
                                            @Mousa_SA is this a post rendering effect?
                                            I think a good way is to provide the developers with pictures. not all devΒ΄s have all plugins on the disk. vray is really a little bit special. i like that some render engine developer provide sketchup. what do you think about to ask the vray developer,too?
                                            @sdmitch i must repeat me by myself... your "small" plugins will be every time helpful. some plugins i use every time when i have a project with sidewalks etc. or when i have an other problem πŸ˜‰
                                            some plugins i will never missing. nice that you have now an email contact address.
                                            i will tell you a thank you.
                                            Dean
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
