    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 651.9k Views 135 Watching
    • david_hD
      david_h
      Okay . .. I just got a new computer and have reinstalled SU. A lot of this stuff I did so long ago that I can't remember anymore how I did it. My problem here is I had a shortcut for edge style by exis that shows the axes in their respective green, red and blue colors. It used to be accessed via "View>Rendering>Axis"
      But on my new download of SU that is no longer there! Any ideas how I can shortcut this?
      Thx,
      D
      • C
        Charlie__V
        [attachment=2:1fhbp1h6]<!-- ia2 -->axis_1.png<!-- ia2 -->[/attachment:1fhbp1h6][attachment=1:1fhbp1h6]<!-- ia1 -->axis_2.jpg<!-- ia1 -->[/attachment:1fhbp1h6]
        Thx,
        D
        Should be there....I just checked on my install (SU Pro 2016)
        • david_hD
          david_h
          Yeah. .. my menu shows that as well, and set the old shortcut accordingly, but problem is. . .there is no View/Rendering .. . on the pull down. It's like that has gone away. Regardless, the shortcut doesn't work. .. cuz it seems that the path is wrong.
          So i have to go thru the styles dialogue to change it manually. Bit of a pain. Like I said.. . i haven't had to worry about this for years, so I have forgotten a lot of this stuff.
            Some shortcut-able commands simply don't [now] appear in the main menus.
            And the View/Rendering/Edge/By Material is one such...
            It is accessed via the Style > Edit panel...
            But by using the 'filter' you can get the command to list, then select it and [re]set the desired shortcut to it...
            • david_hD
              david_h
              Thx TIG . . .unfortunately the Shortcut will take me to the menu, but I still have to do the manual switching to color by axis. .. which for as often as I use it is okay, but it is kinda frustrating that they fix what ain't broke.
              • ely862meE
                ely862me
                You can force axis inference with the rotate tool by tapping the arrow keys !!
                You can edit the component settings in the In model components Edit !
                You can change the component axes from the inside of the component by right clicking outside the geometry.
                DUH!!
                Elisei (sketchupper)
                Come and See EliseiDesign
                  JGA
                  David,
                  Could you not just set up a style to show the edge value you want, then assign just the style to a scene tab?
                  Regards,
                  JGA
                    I don't normally need to do this as I don't use Color by Axis very often but I just set up a keyboard shortcut for View/Rendering/Edge/By Axis and it toggles between All Same and By Axis with no problem.
                    • david_hD
                      david_h
                      yeah. . . that's the way I used to have it. . .but in the new View Pull-down... View>Rendering>Edge by Axis is no longer there. See pic above. Hence the problem. the closest Shortcut I could find was the one that takes me to the styles menu and then I still had to click.
                      NO worries. i don't use it that often either , but it's handy when I need to check things.
                      I'll find a work around I guess.
                      • BoxB
                        I know we are in the Doh thread but.... Doh. David, Dave is saying use the shortcut settings that you will find in Windows/Preferences/Shortcuts to set a keystroke to that specific visual setting that you want.
                        In other words, make a shortcut so when you hit a key combination of your choice, or even one key, the style will change to Colour By Axis.
                        • david_hD
                          david_h
                          okay. . .I'm not a wizard here. It seems to me I have done that. I obviously am missing something. Not ashamed to admit it. Check my posts above to get the history of this and then I am more than happy to be schooled.
                            David, I'm not trying to school you but here's what I have.
                            Keyboard shortcut is set.
                            Edge settings for my normal default style.
                            After hitting Shift+A to toggle the edge color by axis. It even shows the on axis edges colored in the thumbnail. Note, I only chose that shortcut because I knew it wasn't already used.
                            It toggles back and forth as expected.
                            • BoxB
                              Is this what you want? Sorry I did ctrl e rather than your preferred ctrl shift a.
                              • david_hD
                                david_h
                                Dave R and Box. Sorry. DIdn't mean to sound defensive or whatever. I need to turn in my Green 'Top Sketchucator Badge" it was erroneously bestowed anyway.
                                I will re-look at this as per your hints. actually, I am not Skupping as much as I used to so I forget a lot of things.
                                again. . it's not keeping me up at night. . .yet
                                But It would be nice to get this resolved.
                                thank you so much.
                                D
                                • X
                                  xone
                                  Unsure if the right place to ask but I got a little issue with the new reference point stuff in Sketchup 2016.
                                  Previously whenever we reference something, the cursor / protractor will go to the point of transform ON the object I want to adjust.
                                  But now in Sketchup 2016, when I try to rotate something, I got mighty confused as the protractor appear at somewhere else, stuck behind/inside objects, parallel to the referred surface. INSTEAD of going to the point of rotation.
                                  Is there a setting or something to go back to the old way?
                                  http://i.imgur.com/deWhqAp.jpg
                                    In your screen shot from 2016 you have back edges turned on. Do you get the same result if you have them turned off?
                                    • X
                                      xone
                                      Yes I have to turn on back edge to even see the protractor which appear behind/inside other objects.
                                      If I turn off back edge then I can't see the protractor in this example as it appear behind the cylinder.
                                        shawb
                                        My most recent Duh! moment was finding that in the VCB (measurement field)if either of the two lengths was what you need just type the separator comma followed by a number or a number followed by the comma and Enter.
                                          shawb
                                          @bob james said:
                                          @bob james said:
                                          @jql said:
                                          Apologies accepted if you post it on the Duh thread!
                                          So here goes my duh:
                                          @bob james said:
                                          This seems so simple that it must already exist, but I could not find it.
                                          For example: I want to make a 4" square post at a specific spot. If I wanted a round post there I would just select the circle tool, place the cursor at the point and drag out (or put a value in the VCB).
                                          I'd like to be able to do that for a square: select tool, place the cursor at the point and drag out (or put a value in the VCB)
                                          I apologize if this already exists
                                          @jql said:
                                          LOL bob you can make your life difficult if you draw a 4 sided circle and explode it.
                                          Or you can make your life painless if you draw a 4 sided polygon without exploding it.
                                          Those two are native tools. Do you forget sketchup also has native tools?
                                          Your suggestions create 45 deg rotated squares.
                                          Why can't someone just make a simple extension to make an orthogonally positioned square starting from a center point?
                                          How about this?
                                          Use the four sided polygon as suggested. Place an initial polygon on the line of axis (your fence line?) with the placement/inference line on this axis. You now have a rotated 4 sided polygon at 45 deg to the axis. Place the actual fence post polygon to the required centre spot and use its placement line to pick-up a perpendicular inference from the initial polygon. Your fence post is now square on to the fence line. Hope I have placed this reply correctly.
                                          • david_hD
                                            david_h
                                            Okay. serious gob-smacking d'oh here. I got it to work.
                                            Thanks. Although. . I thought I did all this stuff. But whatever. .it works now.
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 31 / 35
