    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
    • garydornG
      garydorn
      @garydorn said:
      Howdy
      Please excuse my questions if its not suitable here.
      I've modelled up an AC aceca body - using SU 6 - native tools only , following CaljuCotcas how to model in a car in 3D using blueprints https://www.youtube.com/watch?v=Hgrix3m1l9k
      blueprint is from a 3Warehouse model called Aceca ( no model just blueprints.)
      Is SubD something that could be used to smooth out and simplify the surface better than what I've modelled so far. - some of my surfaces are still too dimply.
      Thanks - any advice appreciated.
      Probably NOT the best example, but I have managed to SubD the Aceca. It still needs a bit of work to get the bonnet the right shape. Still its better than previous posting.
      I divided the body in sections and adjusted each section separate. i.e. bonnet, front valance , front fender, rear fender boot, roof.
      somethings I've noticed
      1. Quad lines/loops need to be equal number when joining adjacent Groups to look even.
      2. loops look best when they align in a reasonably straight line and evenly spaced.
      3. remember to UnSubD when want to adjust something!!! i.e. work on base geometry
      4. turn off hidden line prior to SubD otherwise it may go into circular mode.
      5. save during progress often - 3 times I got bugspats, when I didn't save in SubD view, then when I go back to base geometry - BAM - got me!
      6. I ended up using TomThoms solid inspector2 tool ( as per his suggestion) quite a bit to find out where I was having poor geometry that prevented SubD from working.
      I'm not very good at setting up the base model so that Quads face tools can used - most of this is simply line tool and moving vector points.
      This is a pretty groovy plugin.
      This is on SketchUP Make 2016 on 2009 iMac with 12 GB RAM Mac Os 10.11.3
      chow
      PS my process was;
      1. remove all surfaces so just wire frame was left - adjust wire frame to suit.
      2. select wireframe and run Quad Face tools > convert> wireframe to Quads.
      3. select QF mesh - run Tools>solid Inspector 2 - check surfaces - adjust as necessary - it has good guide notes.
      4. select mesh - run subD
      5. if SubD has error message ( more then 2 faces to an edge)- redo steps 2, 3 + 4 until it works.
      AC Aceca body through SubD process.
      rear view of Aceca subD -1
        @garydorn said:
        1. save during progress often - 3 times I got bugspats, when I didn't save in SubD view, then when I go back to base geometry - BAM - got me!
        Oh - that's disconcerting! Are you able to reproduce? Btw, can you make sure you submit the BugSplats? Please include some info in the BugSplat message so I can look it up. Then let me know after you submitted them - and let me know what version of SU you use and what OS.
        • BoxB
          I'm somewhat dumbfounded Thomthom, one of my gifs that you posted on the subd farsebook page has just hit 900 shares. It was a 30 second, pre coffee hangover bleary eyed rough sketch.
          There is no understanding social media.
          But I hope it has boosted your sales.
            I know!I just saw the numbers - it's blown away anything else posted! Clearly people like GIF mini-tuts.
            Thank you very much for sharing all these examples - it gives me great insight to how people use the extension and other users loves it as well.
            I'll be gone for a week - once I get back I'll finish up with OpenSubdiv and make sure to get some extra sections on the website with more GIFs/how-to etc.
            • BoxB
              Those are amazing figures. As you noticed I had to create a Box page so I could respond.
              Perhaps I should post a few gifs there.
                Please do! Makes it even easier for me to re-share and give credit.
                • BoxB
                  Ok, but I can't say I am a fan of farsebook or their proprietary gif setup.
                  • HieruH
                    Hieru
                    I much prefer doing and reading mini gif tutorials.
                    What workflow is everyone else using for their creation? At the moment I create them from layers in PS. Is there a faster method I'm missing?
                    www.davidhier.co.uk
                      All up to you. If you don't want to deal with Facebook then that's fine. I just thought you wanted to set up a page for your own services.
                      Yea, the GIF system is awkward - I have to upload to Giphy first then link that in the post.
                      I'm using ScreenPresso to record and export GIFs.
                      • HieruH
                        Hieru
                        That's great guys. I'll check those out next time I put together a mini tutorial.
                        www.davidhier.co.uk
                        • BoxB
                          .gif screen capture software records whatever you do.
                          Two well known ones, Licecap and Gifcam.
                          I actually prefer gifcam but it won't work with mac.
                          • Z
                            ZahariStoyanov
                            Hey guys, this is a wonderful thread! Here's my current project using QuadFace Tools and SubD:
                            https://scontent-frt3-1.xx.fbcdn.net/hphotos-xpl1/t31.0-8/s851x315/12466328_1038864449467541_7326254369661684896_o.jpg
                            https://scontent-frt3-1.xx.fbcdn.net/hphotos-xfp1/v/t1.0-0/p160x160/12512297_1038864436134209_3435024690201240614_n.jpg?oh=6f1449c29fdcda30b6210c9d7345237d&oe=57599E7F
                            https://scontent-frt3-1.xx.fbcdn.net/hphotos-xpf1/v/t1.0-0/p160x160/12400739_1038864412800878_4399751789969425144_n.jpg?oh=b19f471da84867a38d6783bf738ee508&oe=57520500
                            https://scontent-frt3-1.xx.fbcdn.net/hphotos-xfl1/v/t1.0-0/p160x160/12509604_1038864426134210_7820093745963454804_n.jpg?oh=7470e075d891f7520dc202fe2ef6c927&oe=5756338B
                            https://scontent-frt3-1.xx.fbcdn.net/hphotos-xpf1/t31.0-8/12771570_1065256206828365_55738688581584253_o.jpg
                            https://scontent-frt3-1.xx.fbcdn.net/hphotos-xpl1/t31.0-8/12719666_1065256220161697_5091952030927022492_o.jpg
                            https://scontent-frt3-1.xx.fbcdn.net/hphotos-xpl1/v/l/t1.0-0/s480x480/10415613_1065256213495031_480815097045284889_n.jpg?oh=73c6a8db1d03d784055ca25ff00d0b4c&oe=5769D754
                            • BoxB
                              Excellent. Looks suspiciously like a modified Trabant.
                              • ntxdaveN
                                ntxdave
                                1+ on what Box said............nice looking model.
                                Press F1...thank me later
                                • BoxB
                                  I've just noticed that's 23,000 people in about a day and this thread is coming up to 20,000 views over two months, which is bloody fast by forum standards.
                                  No doubt someone will share my own gif with me on my personal facebook page very soon.
                                  • Z
                                    ZahariStoyanov
                                    Thanks! Yep, it's supposedly a track Trabi 😄
                                    • garydornG
                                      garydorn
                                      Hmm, I wondered about that when it happened - i.e. sending you the bugsplat. Sure if it happens again I can do.
                                        Technically the BugSplats doesn't get sent to me directly - but my day-job is working for SketchUp so I'm able to look up these crashes. 😉
                                        • BoxB
                                          A quick tip.
                                          You can crease individual vertices to get specific results.
                                          The creases here create the tent poles and flap.
                                          http://i155.photobucket.com/albums/s296/storeben/SU/Tent_1.gif
                                          • cottyC
                                            cotty
                                            my SketchUp gallery
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 83
                                            • 84
                                            • 22 / 84
