    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
    • cottyC
      cotty
      May the quads be with you!
      my SketchUp gallery
      • cottyC
        cotty
        SCF_Cotty_subd23.skp
        my SketchUp gallery
          this is because the QFT OBJ importer will ensure non-planar quads are created as QuadFaceTools quads
          Sorry I don't see "Import OBJ" on the menus of QuadFaceTools(0.9.1 & 0.9.2) ? ๐Ÿ˜ฎ
          Only "Export" ! (SU Make 2016 2015)
          • BoxB
            I've never ventured much into the realm of furniture making so as a first quick doodle I'm impressed by the ease with which I came up with something almost recognisable in less than 30 minutes fiddling. No doubt I could render it and make it look flash, but I love the raw topology.
            • HornOxxH
              HornOxx
              Hi - to get any first experiences I did a little testing, mainly based on Cottys SubD_04 model above. I was interested on how an existing texture behaves to the SubD process - it's amazing how confidently and fast that works ...
              Cotty, how did you get this rainbow-colour on that subd23 chair which looks so great - is it texturing?
              zipped skp2015 file
              used texture
              never trust a skinny cook
              • cottyC
                cotty
                Nice! Here's the chair texture...
                my SketchUp gallery
                  Ah, yea, the docs probably don't mention this at all, but it's listed among the other importers:
                  File > Import
                  The only reason the exporter isn't among the other exporter is that the API is lacking the interface. Them guys over at SketchUp should fix that! ...oh wait...
                    It makes me very happy to hear that. My biggest concern with SUbD was how it relied on quad topology and I wasn't sure how well that requirement of workflow would be received in the realms on SketchUp.
                      Thanks for sharing that model - it's a nice study of geometry and texture.
                      At the moment SUbD use simple linear interpolation for the textures. However, I am working with integrating OpenSubdiv into a future release. That will give more options for textures;
                      Source: http://graphics.pixar.com/library/Geri/paper.pdf
                        @Thomthom
                        In fact all works fine! ๐Ÿ’š
                        It was half my fault! I was too confident of the first reading text! ๐Ÿ˜„
                        • cottyC
                          cotty
                          my SketchUp gallery
                            Tron! ๐Ÿ˜‰
                              Glitch ?
                              SUbD finds internal faces and can't be apply! (Who don't exist)
                              (Artisan subdivides ๐Ÿ˜‰
                              subd_glitch_v6.skp
                                SUbD Catmull-Clark algorithm require the mesh to be a manifold or a surface without any forks. That model you have there have an edge with four faces connected - the algorithm cannot handle that. In another modelling package where the entities didn't merge you'd get away with it as you could have overlapping edges. But since SU merges entities at all times these types of scenarios becomes a challenge.
                                OpenSubdiv 3 supports internal faces - maybe it would be able to cope with this as well - I'm not sure. But that's still down the line in the road map.
                                • BoxB
                                  It would be handy if either SubD or Solid inspector could highlight these annoying joints. They can be a real headache to find manually sometimes.
                                    Solid Inspector used to complain about these - but because they where considered false positives in many cases it was changed to ignore them.
                                    I do have ideas for an analytical tool for QFT that will visualize quads from triangles and ngons. Maybe it can lightlight forks as well...
                                    By the way, I tried the model on an experimental build I have where I try to wire up OpenSubdiv and it seemed to be able to cope with it:
                                    OpenSubdiv experimental version
                                      THx for the explanation and the effort! ๐Ÿ˜Ž
                                      • panixiaP
                                        panixia
                                        ๐Ÿ˜ please please auto-detect sausages ad donuts ๐Ÿ˜
                                        somewere i should have a "wishlist" i wrote with some examples included too..
                                        • BoxB
                                          Another quick late night doodle just for fun and to help wrap my head around quads.
                                          It's very quick and simple but everything is so easy to manipulate with the combination of QFT, VT and SubD.
                                          SubD Plane Proxy.skp
                                          • olisheaO
                                            olishea
                                            nice cotty loving this thread....I'll get involved soon ๐Ÿ˜„
                                            oli
                                            • 83
                                            • 84
                                            • 4 / 84
