    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.4m Views 79 Watching
      @pilou said:
      For crazzy models you can use the incedible TopMod! ๐Ÿ˜Ž
      And Import OBJ by TIG for "SU MAKE"! ๐Ÿค“
      Can you share the OBJ file?
        From the Topmod ?
        No Problem ๐Ÿ˜„
        soccerball_obj.zip
          Here is the result of the OBJ imported using QuadFaceTools:
          Notice that it has less triangles than your original import - this is because the QFT OBJ importer will ensure non-planar quads are created as QuadFaceTools quads. In in turns makes it better for SUbD.
          You can see that under the hood there are still triangles in SketchUp - but for the sake of QFT and SUbD they will be treated as quads.
          • HornOxxH
            HornOxx
            Hi All
            I've finally found the time, to install and start SubD, which runs very well so far and I love it already. I am glad as well, that SubD is finally here and has caused all these contributions which are great, even funny and educational all together.
            Now I'm working my way through all your contributions and the exercise models that you have posted here. Cotty and all the others - thank you all for posting them!!!
            I understand why it is better to use quad faces instead of triangulation, even if I'm light years away to understand the connections to (for example) Quadfce tools and how or when to use these additional "Quad" tools - Iยดm starting to learn :- ))
            Here is a first simple question
            I show an example of Cotty - How is it possible to get this shown SubD-quad-mesh visible?
            (I see the creases only and when I activate show hidden geometry, I see the creases and the triangulation of course)
            never trust a skinny cook
            • cottyC
              cotty
              Unsmooth quads from the quadface tools for the group:
              my SketchUp gallery
              • HornOxxH
                HornOxx
                I see the Quads !!! :- )) Thanks Cotty
                • cottyC
                  cotty
                  May the quads be with you!
                  my SketchUp gallery
                  • cottyC
                    cotty
                    SCF_Cotty_subd23.skp
                    my SketchUp gallery
                      Sorry I don't see "Import OBJ" on the menus of QuadFaceTools(0.9.1 & 0.9.2) ? ๐Ÿ˜ฎ
                      Only "Export" ! (SU Make 2016 2015)
                      • BoxB
                        I've never ventured much into the realm of furniture making so as a first quick doodle I'm impressed by the ease with which I came up with something almost recognisable in less than 30 minutes fiddling. No doubt I could render it and make it look flash, but I love the raw topology.
                        • HornOxxH
                          HornOxx
                          Hi - to get any first experiences I did a little testing, mainly based on Cottys SubD_04 model above. I was interested on how an existing texture behaves to the SubD process - it's amazing how confidently and fast that works ...
                          Cotty, how did you get this rainbow-colour on that subd23 chair which looks so great - is it texturing?
                          zipped skp2015 file
                          used texture
                          • cottyC
                            cotty
                            Nice! Here's the chair texture...
                            my SketchUp gallery
                              Ah, yea, the docs probably don't mention this at all, but it's listed among the other importers:
                              File > Import
                              The only reason the exporter isn't among the other exporter is that the API is lacking the interface. Them guys over at SketchUp should fix that! ...oh wait...
                                It makes me very happy to hear that. My biggest concern with SUbD was how it relied on quad topology and I wasn't sure how well that requirement of workflow would be received in the realms on SketchUp.
                                  Thanks for sharing that model - it's a nice study of geometry and texture.
                                  At the moment SUbD use simple linear interpolation for the textures. However, I am working with integrating OpenSubdiv into a future release. That will give more options for textures;
                                  Source: http://graphics.pixar.com/library/Geri/paper.pdf
                                    @Thomthom
                                    In fact all works fine! ๐Ÿ’š
                                    It was half my fault! I was too confident of the first reading text! ๐Ÿ˜„
                                    • cottyC
                                      cotty
                                      my SketchUp gallery
                                        Tron! ๐Ÿ˜‰
                                          Glitch ?
                                          SUbD finds internal faces and can't be apply! (Who don't exist)
                                          (Artisan subdivides ๐Ÿ˜‰
                                          subd_glitch_v6.skp
                                            SUbD Catmull-Clark algorithm require the mesh to be a manifold or a surface without any forks. That model you have there have an edge with four faces connected - the algorithm cannot handle that. In another modelling package where the entities didn't merge you'd get away with it as you could have overlapping edges. But since SU merges entities at all times these types of scenarios becomes a challenge.
                                            OpenSubdiv 3 supports internal faces - maybe it would be able to cope with this as well - I'm not sure. But that's still down the line in the road map.
                                            • 83
                                            • 84
                                            • 3 / 84
