    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.9m Views 79 Watching
    • cottyC Offline
      cotty
      SCF_Cotty_subd17.skp
      my SketchUp gallery
      • cottyC Offline
        cotty
        SCF_Cotty_subd18.skp
        my SketchUp gallery
        • cottyC Offline
          cotty
          my SketchUp gallery
          • cottyC Offline
            cotty
            my SketchUp gallery
              For the Thumb and the rest! ๐Ÿ‘
              • BoxB Offline
                I did this for something else but may as well drop it in here too.
                • cottyC Offline
                  cotty
                  SCF_Cotty_subd22.zip
                  my SketchUp gallery
                    For crazzy models you can use the incedible TopMod! ๐Ÿ˜Ž
                    And Import OBJ by TIG for "SU MAKE"! ๐Ÿค“
                    SUbD Low Subdivisions
                    bague_v6.zip
                    • panixiaP Offline
                      panixia
                      pilou did you try with .obj importer from quadface tools? it should preserve quads..
                        My original start TopMod model had some triangular faces!
                        And some original TopMod surfaces are curved!
                        • panixiaP Offline
                          panixia
                          i saw the triangles, but i suspect the "curved" should be simply non-planar quads.
                          in that case quadface importer could hopefully handle them..
                          is topmod free? that looks intersting..
                            Can you share the OBJ file?
                              From the Topmod ?
                              No Problem ๐Ÿ˜„
                              soccerball_obj.zip
                                Here is the result of the OBJ imported using QuadFaceTools:
                                Notice that it has less triangles than your original import - this is because the QFT OBJ importer will ensure non-planar quads are created as QuadFaceTools quads. In in turns makes it better for SUbD.
                                You can see that under the hood there are still triangles in SketchUp - but for the sake of QFT and SUbD they will be treated as quads.
                                • HornOxxH Offline
                                  HornOxx
                                  Hi All
                                  I've finally found the time, to install and start SubD, which runs very well so far and I love it already. I am glad as well, that SubD is finally here and has caused all these contributions which are great, even funny and educational all together.
                                  Now I'm working my way through all your contributions and the exercise models that you have posted here. Cotty and all the others - thank you all for posting them!!!
                                  I understand why it is better to use quad faces instead of triangulation, even if I'm light years away to understand the connections to (for example) Quadfce tools and how or when to use these additional "Quad" tools - Iยดm starting to learn :- ))
                                  Here is a first simple question
                                  I show an example of Cotty - How is it possible to get this shown SubD-quad-mesh visible?
                                  (I see the creases only and when I activate show hidden geometry, I see the creases and the triangulation of course)
                                  never trust a skinny cook
                                  • cottyC Offline
                                    cotty
                                    Unsmooth quads from the quadface tools for the group:
                                    my SketchUp gallery
                                    • HornOxxH Offline
                                      HornOxx
                                      I see the Quads !!! :- )) Thanks Cotty
                                      • cottyC Offline
                                        cotty
                                        May the quads be with you!
                                        my SketchUp gallery
                                        • cottyC Offline
                                          cotty
                                          SCF_Cotty_subd23.skp
                                          my SketchUp gallery
                                            Sorry I don't see "Import OBJ" on the menus of QuadFaceTools(0.9.1 & 0.9.2) ? ๐Ÿ˜ฎ
                                            Only "Export" ! (SU Make 2016 2015)
                                            • 83
                                            • 84
                                            • 3 / 84
