    Expect SubD to release
    21 Posts 12 Posters 13.1k Views 12 Watching
    • duanekempD Offline
      duanekemp
      Countdown clock ticking away. Ready, set,......
      Duane Kemp
      Kemp Productions
      Puidoux, Switzerland
      Gallery:
      https://duanekemp.artstation.com/
        Go...
        It's out ๐Ÿ˜‰
          And its French Manual & site! ๐Ÿ˜‰
          • hellnbakH Offline
            hellnbak
            Just purchased this plugin (on the off-chance that I may actually understand and be able to use it ๐Ÿ˜† ), BUT...
            when I went to download it I got the following warning
            evilsoftwareempire.com??????
            I haven't downloaded it yet, am understandably reluctant to do so until I hear that it is indeed safe.
              That's thomthoms website.
              No harm unless you are afraid of fun.
              Sent from my iPhone using Tapatalk
                [attachment=0:3c70rdjo]<!-- ia0 -->2016-01-05_112759.png<!-- ia0 -->[/attachment:3c70rdjo]
                Haha! What a nice combo. Yea, that's my site. ๐Ÿ˜„ I needed to split out the extensions from my personal website, so I set up this one. Tongue and cheek name. ๐Ÿ˜›
                The warning from your AV is probably because it's a new binary file and filename that it's never heard of. If you obtained it from the website it should be good.
                Btw, what AV are you using? Is there is way for you to report false positives?
                • mitcorbM Offline
                  mitcorb
                  evils of t ware empire? ๐Ÿ’š
                  • hellnbakH Offline
                    hellnbak
                    Thanks for the replies.
                    I have downloaded and installed the plugin. I have also checked out some of the documentation, manual, videos, etc. Looks like another one well beyond my very limited capabilities ๐Ÿ˜’
                    Oh well.
                    It was McAfee Web Advisor that flagged the download. I don't know about flagging false positives, I just installed it a few weeks ago. Normally I avoid anything to do with McAfee but decided to give this one a try.
                    I am very cautious about what I download, your website name didn't give me a warm fuzzy feeling ๐Ÿ˜ฎ
                      ๐Ÿ˜„
                      http://33.media.tumblr.com/c130c78afc24041c06b8fcee9220e557/tumblr_inline_n9hqedid8T1ru2o15.gif
                      • ontaottoO Offline
                        ontaotto
                        Hi there, for those who have installed the plugin can answer to this curiosity I have?
                        Do this works as the subdivision function as in other 3D modelling programs? I mean, to obtain circular shapes you work basically with hexagons or preferably octagons, in addition you need to take care about quads, in the understanding that faces should be in four sides to get the best models, do this plugin works like that? If so, can someone post a sample please?
                        Kind regards everyone!
                        Otto
                        Twitter: @ontaotto
                          Otto
                          SUbD uses Catmull-Clark algorithm for subdividing - which is very common. The same "rules" apply to SUbD as in other quad-based modellers with subdivision.
                          One way would be to use a hexagonal or octagonal approximation and subdivide that.
                          There are some nice topology examples over at this Tumble account: http://topology-guides.tumblr.com/
                          Like this: http://topology-guides.tumblr.com/image/124121026900
                          Another way is to use creasing, you can make a cylinder with inly a cube if you want. A cube will approximate to a sphere eventually - and you can crease the top and bottom to make a cylinder:
                          The latter will probably require more subdivision and create a denser mesh - the former might save you some polygons in the end at the expense of a little more work up front.
                          On some applications the subdivision is applied only in the viewport at render time - but in SketchUp, as an extension - SUbD needs to generate actual entities. So you might want to avoid too many subdivision levels to avoid dense meshes slowing down your model.
                          I usually prefer a combo, of rather low-poly and creasing to tweak details.
                          • ontaottoO Offline
                            ontaotto
                            Thank you Thomas, I have seen this image in Twitter, so if this plugin can do this, I am in, because it is exactly what I was expecting for.
                            https://pbs.twimg.com/media/CYIs7ijWcAAsF2P.png;large
                            Regards
                            Otto
                            Twitter: @ontaotto
                            • JQLJ Offline
                              JQL
                              Regards
                              Otto
                              That's exactly what it can do!
                              www.casca.pt
                              Visit us on facebook!
                                Regards
                                Otto
                                That was created by Rich O'Brien using SUbD ๐Ÿ˜„
