    1.3k Posts 300 Posters 3.1m Views 298 Watching
      Maybe you could post the SKP file? We might actually be able to help you if we could get our mitts on it.
        jmeek
        Curviloft skinning is working now, after uninstalling and reinstalling Fredo6 Tools. The disruption of began after installing Fredo6 Tools over top the already installed Curviloft.
        • JClementsJ
          JClements
          Request: For lofting along a path, could its prompt read,
          "1st Select Lofting Path, thenEdges to be Lofted".
          It would help new users or those who haven't used the plugin in a while.
          • fredo6F
            Good idea. Thanks
            Actully Curviloft needs some refresh to be more user-friendly.
              spardacus
              Is there any way to resize the control panel in the Sketchup Interface? Even when I lower my screen resolution the Control panel remains rather small - too small to read.
              See attachment.
              • fredo6F
                See attachment.
                I don't see the attachment.
                Unfortunately, there is no solution from the plugin. You may want to have a look at the following thread, where the problem is evoked with some solution.
                • fredo6F
                  By the way, the latest version (published for SU2016) includes a status and tooltip to indicate the order of selection.
                  • JClementsJ
                    JClements
                    Thanks.
                    • dereiD
                      derei
                      Curviloft is creating strange looking geometry on Single F-Spline Curve Mode. Can't figure out why.
                      I would appreciate any idea why this is happening.
                      Thank you.
                      Please see attached image and skp file.
                      curviloft.skp
                      DESIGNER AND ARTIST DEREI.UK
                      • fredo6F
                        Derei,
                        There is a bug / limitation for close-loop contours with F-Spline. It certainly deserves a fix.
                        Might be the same for B-Spline with close-loop by the way.
                        • dereiD
                          derei
                          @fredo6 said:
                          Derei,
                          After MANY tries I was able to fix it. I cut the loop in two, deleted the last segment (on the part whith the glitch), then I mirrored it to make it again closed loop. After doing the same to all tree loops, the skinning went well. Can't understand why. What was different in the newly made curve...
                          Because I tried before only to delete the two segments (on both side of symmetry plane) and redraw them... but that didn't fix the problem. Only completely deleting half and mirroring it after redrawing the segment helped.
                          • fredo6F
                            Glad you found a workaround.
                            Actually, closing splines 'nicely' is not so easy, and FSpline is somehow special, home-made. So I need to adjust the method.
                            • K
                              kaas
                              @derei: I never close loops but always work with two halves that I group after the both lofts are done. Works quite nicely.
                              • E
                                Einstein
                                Thank you! If I could use only one plugin in SU, that would be Curviloft 😄
                                  AcesHigh
                                  any idea what is causing this?
                                  http://i.imgur.com/shJAw9o.jpg
                                    Have you installed fresh versions of both Curviloft AND LibFredo6?
                                      AcesHigh
                                      Yes. Although in my memory I had Curviloft already installed, I was not finding it anywhere. So maybe I did not installed it before on Sketchup 15.
                                      So I installed from the Sketchucation Store Curviloft, it didn´t work (already showed that message). Then I installed the last LibFredo. No change.
                                        Perhaps you have some residual files from an older version. I would suggest going to the Plugins folder using the Sketchucation Plugin store tool. Delete any files and folders you find related to both Curviloft and LibFredo6. Make sure there's nothing left. Quit SketchUp. Then open it again and using the SCF Plugin Store tool, reinstall both.
                                          You also need to restart SketchUp to effect the changes to Fredo's newly installed extensions and/or updated Lib...
                                          • B
                                            Bisectrix
                                            I got this error message when re-starting SU after having Curviloft installed:
                                            "You must install LibFredo6 version 6.9 or higher to run Fredo6_Curviloft"
                                            LibFredo6 is installed correctly. Another Plugin, e.g. Bezier Spline is running without any such error message during starting SU.
                                            Maybe anyone could help me how to fix it?
                                            Regards,
                                            • 51
                                            • 52
                                            • 53
                                            • 54
                                            • 55
                                            • 65
                                            • 66
                                            • 53 / 66
