    1.3k Posts 299 Posters 2.7m Views 297 Watching
      blackcat1313
      @box said:
      You can use another of Fred's excellent plugins to cleanup before lofting.
      Here it is cleaned with Curvizard then Curviloft.
      That is amazing, thank you so much! I installed Curvizard, followed the video, and everything was looking good until the last loft segment. Then I got a bugsplat.
      Any ideas? I'm using Sketchup 2013 on a Mac if that makes any difference.
      Bill
        blackcat1313
        Hi Box -
        I have been looking at the documentation for Curvizard and I see there are quite a few settings on the buttons palette that affect the way the tool works. Would it be possible for you to share with me the settings you used to clean up the curves? The video above is tightly cropped so the settings are not visible. Thanks!
        Bill
          blackcat1313
          You may have been able to loft it, but can you make it into a solid? I have been able to loft using 4 the airfoils, but even though it looks good, there are too many errors to make it into a solid. I can get faces on the root, tip, and trailing edge, but Solid Inspector**2 finds hundreds of problems that it says cannot be fixed automatically.
          This is with Sketchup 2015, I upgraded to see if that would improve things. It didn't.
          • caermaloC Offline
            caermalo
            Hello fredo
            I have the following problem with the plugin
              dogtorque
              OH MY GOD!
              Thank You so Much
              I just tried out this tool and it works it is saving me sooo much time in my creating the faces in my 3d models! and since I do 3d modeling of my own car designs so I can use them in unity this tool is like a blessing! and that it is free just makes you a generous person! if anyone else made this tool they would more than likely of charged a large amount of money for this tool which would suck because I literally don't have a budget for my 3d modeling because I don't have a job right now and I'm currently living with my parents.
                jmeek
                I'm using Curviloft on a Mac. It worked great for one day. Now skinning process bar just stops with 0%. No further effort on my part seems to correct this situation. I'm trying skinning function on a very simple wire frame. Can anyone offer suggestions?
                  Maybe you could post the SKP file? We might actually be able to help you if we could get our mitts on it.
                    jmeek
                    Curviloft skinning is working now, after uninstalling and reinstalling Fredo6 Tools. The disruption of began after installing Fredo6 Tools over top the already installed Curviloft.
                    • JClementsJ Offline
                      JClements
                      Request: For lofting along a path, could its prompt read,
                      "1st Select Lofting Path, thenEdges to be Lofted".
                      It would help new users or those who haven't used the plugin in a while.
                      • fredo6F Offline
                        Good idea. Thanks
                        Actully Curviloft needs some refresh to be more user-friendly.
                          spardacus
                          Is there any way to resize the control panel in the Sketchup Interface? Even when I lower my screen resolution the Control panel remains rather small - too small to read.
                          See attachment.
                          • fredo6F Offline
                            See attachment.
                            I don't see the attachment.
                            Unfortunately, there is no solution from the plugin. You may want to have a look at the following thread, where the problem is evoked with some solution.
                            • fredo6F Offline
                              By the way, the latest version (published for SU2016) includes a status and tooltip to indicate the order of selection.
                                JClements
                                Thanks.
                                • dereiD Offline
                                  derei
                                  Curviloft is creating strange looking geometry on Single F-Spline Curve Mode. Can't figure out why.
                                  I would appreciate any idea why this is happening.
                                  Thank you.
                                  Please see attached image and skp file.
                                  curviloft.skp
                                  DESIGNER AND ARTIST DEREI.UK
                                  • fredo6F Offline
                                    Derei,
                                    There is a bug / limitation for close-loop contours with F-Spline. It certainly deserves a fix.
                                    Might be the same for B-Spline with close-loop by the way.
                                    • dereiD Offline
                                      derei
                                      @fredo6 said:
                                      Derei,
                                      After MANY tries I was able to fix it. I cut the loop in two, deleted the last segment (on the part whith the glitch), then I mirrored it to make it again closed loop. After doing the same to all tree loops, the skinning went well. Can't understand why. What was different in the newly made curve...
                                      Because I tried before only to delete the two segments (on both side of symmetry plane) and redraw them... but that didn't fix the problem. Only completely deleting half and mirroring it after redrawing the segment helped.
                                      • fredo6F Offline
                                        Glad you found a workaround.
                                        Actually, closing splines 'nicely' is not so easy, and FSpline is somehow special, home-made. So I need to adjust the method.
                                          kaas
                                          @derei: I never close loops but always work with two halves that I group after the both lofts are done. Works quite nicely.
                                          • E Offline
                                            Einstein
                                            Thank you! If I could use only one plugin in SU, that would be Curviloft πŸ˜„
                                            • 51
                                            • 52
                                            • 53
                                            • 54
                                            • 55
                                            • 65
                                            • 66
                                            • 53 / 66
