    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 957.8k Views 172 Watching
    • F Offline
      faust07
      Ah, good - Thank you. Will try it.
      • romboutR Offline
        rombout
        THis is probably windwos only, correct?
          Anton_S
          Yes rombout, its windows only. Furthermore, it's unstable and incomplete. Try out SketchyPhysics 3.6.0, while MSPhysics is still under development.
            tomasz
            I wish you developed it further or at least made it stable.
            Here is my quick try with Thea. Maybe it will motivate you slightly πŸ˜„
            Thea Render - Shadow Catcher + IBL
            • soloS Offline
              πŸ˜„
              Tomasz!! you tease.
                Another brick on the wall! πŸ˜„
                  RobiBue
                  Hi, I'm using SU2015 and with
                  ams_Lib 3.1.2 and
                  MSPhysics 0.2.1
                  I get the following errors:
                  [pre:16r2j6vf]Error Loading File C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/main.rb
                  Error: #<NameError: uninitialized constant AMS::FFI>
                  C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/sdl.rb:10:in <module:SDL>' C:/Users/*[User Name]*/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/sdl.rb:4:in <top (required)>'
                  C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                  C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/main.rb:39:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
                  C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/*[User Name]*/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:106:in register_extension'
                  C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:106:in <module:MSPhysics>' C:/Users/*[User Name]*/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:88:in <top (required)>'[/pre:16r2j6vf]
                  Please help
                  thanks
                  • luckyvacL Offline
                    luckyvac
                    hello, I can not seem to find a tutorial to create joint . I use SketchyPhysics . I've the table IU but not the icons .
                    Where are the joints ???
                    Thanks for your help.
                    i've 0.2.0 it's worry ?
                    jean-luc
                      Anton_S
                      MSPhysics will be up and running soon. Have a great holiday!
                        Anton_S
                        Hi, 0.3.0 Alpha has been released! Go to first post for download.
                        Changelog:
                        • Reverted to SDL1 and SDL_Mixer1, which fixed the crash that occurred after using SketchUp for a few minutes.
                        • Optimized the C++ extension.
                        • Upgraded to Newton 3.14.
                        • Added joints. Still more work to go.
                        • Added replay animation tool. It can record materials and emitters.
                        I might post videos regarding the features soon. Meanwhile, try out the chains.
                        chains.skp
                        • cottyC Offline
                          cotty
                          Tried with SU16-64 Win8.1-64:
                          my SketchUp gallery
                            Anton_S
                            Try deleting the old version and download the new one. It might be bragging about localization, but in theory it shouldn't.
                            • cottyC Offline
                              cotty
                              I've compared my installed files with the zip and there were some files missing in my installation. Now it's working perfect, thank you!
                              click to animate
                              my SketchUp gallery
                              • cottyC Offline
                                cotty
                                I like the debug modus of your chain model πŸ˜‰
                                click to animate
                                my SketchUp gallery
                                • cottyC Offline
                                  cotty
                                  How can these (groups of) bodies collide? If the lower group is exploded, the individual parts collide but not as a group/component.
                                  click to animate
                                  coll_example.skp
                                  my SketchUp gallery
                                  • cottyC Offline
                                    cotty
                                    If I assign the hinge to the ground instead of the group of objects, the collision works, but I need the assignment to that group for this case:
                                    coll_example2.skp
                                    my SketchUp gallery
                                      Anton_S
                                      Cotty, joint properties can be editted. Select the desired joint, open MSPhysics UI, and enable 'connected collide' option.
                                      • cottyC Offline
                                        cotty
                                        Thank you, Anton, that helped!
                                        my SketchUp gallery
                                          RobiBue
                                          Just a heads up replying to my post:
                                          ams_Lib 3.1.2 and
                                          MSPhysics 0.2.1
                                          [pre:1doxyosj]Error Loading File ...[/pre:1doxyosj]
                                          Please help
                                          thanks
                                          Thank you,
                                          the new version "0.3.0" runs smoothly on SU 15 and 16
                                          Great work ❗ πŸ‘
                                            PituPhysics
                                            Hello Anton! For me it's not working. New installed SU16-x64 and AMS 3.1.3.
                                            http://sketchucation.com/forums/download/file.php?mode=view%26amp;id=135827
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 46
                                            • 47
                                            • 17 / 47
