    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
      Anton_S
      Yes, MSPhysics and SketchyPhysics can be placed in same plugins folder. But, both plugins won't interact with each other; properties assigned by SketchyPhysics will not affect properties assigned by MSPhysics. To get the model to work the same way on both MSPhysics and SketchyPhysics, you'll need to assign similar properties with SketchyPhysics UI and MSPhysics UI.
      • F
        faust07
        Ah, good - Thank you. Will try it.
        • romboutR
          rombout
          THis is probably windwos only, correct?
            Anton_S
            Yes rombout, its windows only. Furthermore, it's unstable and incomplete. Try out SketchyPhysics 3.6.0, while MSPhysics is still under development.
            • T
              tomasz
              I wish you developed it further or at least made it stable.
              Here is my quick try with Thea. Maybe it will motivate you slightly πŸ˜„
              Thea Render - Shadow Catcher + IBL
              • soloS
                πŸ˜„
                Tomasz!! you tease.
                  Another brick on the wall! πŸ˜„
                    RobiBue
                    Hi, I'm using SU2015 and with
                    ams_Lib 3.1.2 and
                    MSPhysics 0.2.1
                    I get the following errors:
                    [pre:16r2j6vf]Error Loading File C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/main.rb
                    Error: #<NameError: uninitialized constant AMS::FFI>
                    C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/sdl.rb:10:in <module:SDL>' C:/Users/*[User Name]*/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/sdl.rb:4:in <top (required)>'
                    C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                    C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/main.rb:39:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
                    C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/*[User Name]*/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:106:in register_extension'
                    C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:106:in <module:MSPhysics>' C:/Users/*[User Name]*/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:88:in <top (required)>'[/pre:16r2j6vf]
                    Please help
                    thanks
                    • luckyvacL
                      luckyvac
                      hello, I can not seem to find a tutorial to create joint . I use SketchyPhysics . I've the table IU but not the icons .
                      Where are the joints ???
                      Thanks for your help.
                      i've 0.2.0 it's worry ?
                      jean-luc
                        Anton_S
                        MSPhysics will be up and running soon. Have a great holiday!
                          Anton_S
                          Hi, 0.3.0 Alpha has been released! Go to first post for download.
                          Changelog:
                          • Reverted to SDL1 and SDL_Mixer1, which fixed the crash that occurred after using SketchUp for a few minutes.
                          • Optimized the C++ extension.
                          • Upgraded to Newton 3.14.
                          • Added joints. Still more work to go.
                          • Added replay animation tool. It can record materials and emitters.
                          I might post videos regarding the features soon. Meanwhile, try out the chains.
                          chains.skp
                          • cottyC
                            cotty
                            Tried with SU16-64 Win8.1-64:
                            my SketchUp gallery
                              Anton_S
                              Try deleting the old version and download the new one. It might be bragging about localization, but in theory it shouldn't.
                              • cottyC
                                cotty
                                I've compared my installed files with the zip and there were some files missing in my installation. Now it's working perfect, thank you!
                                click to animate
                                my SketchUp gallery
                                • cottyC
                                  cotty
                                  I like the debug modus of your chain model πŸ˜‰
                                  click to animate
                                  my SketchUp gallery
                                  • cottyC
                                    cotty
                                    How can these (groups of) bodies collide? If the lower group is exploded, the individual parts collide but not as a group/component.
                                    click to animate
                                    coll_example.skp
                                    my SketchUp gallery
                                    • cottyC
                                      cotty
                                      If I assign the hinge to the ground instead of the group of objects, the collision works, but I need the assignment to that group for this case:
                                      coll_example2.skp
                                      my SketchUp gallery
                                        Anton_S
                                        Cotty, joint properties can be editted. Select the desired joint, open MSPhysics UI, and enable 'connected collide' option.
                                        • cottyC
                                          cotty
                                          Thank you, Anton, that helped!
                                          my SketchUp gallery
                                            RobiBue
                                            Just a heads up replying to my post:
                                            ams_Lib 3.1.2 and
                                            MSPhysics 0.2.1
                                            [pre:1doxyosj]Error Loading File ...[/pre:1doxyosj]
                                            Please help
                                            thanks
                                            Thank you,
                                            the new version "0.3.0" runs smoothly on SU 15 and 16
                                            Great work ❗ πŸ‘
                                            • 11
                                            • 46
                                            • 47
                                            • 9 / 47
