    MSPhysics 1.0.3 (16 October 2017)
    929 Posts 172 Posters 1.3m Views 173 Watching
    • BillMackB Offline
      BillMack
      Thanks, but I'm still getting the bugsplat.
      I uninstalled 64bit and tried 32bit of SU 2015. First I tried with the original MSP/AMS - same result. Next, I tried with latest MSP/AMS. No good.
      I'll try SU 2015 64bit again, this time with latest MSP/AMS versions.
      Could I be missing some C++ runtime or .Net framework or other low level library?
      I've tried uninstalling other programs, updating drivers, shutting off services - nothing seems to make a difference.
      SU 2015 leaves no hint or trace in Windows Event Log so there's no clue as to what's going on.
      I did notice something strange when I installed SU 2015 32bit. The installer complained about needing to update something that was in use by another program. It listed the Motorola Device Manager Service - I believe that's part of the install for my Motorola smartphone. I let installer do the update - the Motorola service crashed, but later I looked at the running services and it had restarted normally.
      That made me think there might be some other runtime that's being troublesome.
        Anton_S
        That's bad. It seems like there is something wrong with your Windows system or my MSPhysics project. I wish I could help, but I'm no expert when it comes to runtime libraries. Sooner or later I will test my MSPhysics on various PCs and if I come across an issue like that, I will notify you.
        • BillMackB Offline
          BillMack
          Thank you for your help.
          If I find a solution, I'll post here with the details.
          • F Offline
            faust07
            Wonderful to read that you continue to work at the Physics plugins.
            I have not had the courage to play with MS-Physics until now.
            Does it make sense to install MS-Physics and SketchyPhysics in SketchUp 2015 32bit simultaneously? And to test both plugins with the same (simple) model?
              Anton_S
              Yes, MSPhysics and SketchyPhysics can be placed in same plugins folder. But, both plugins won't interact with each other; properties assigned by SketchyPhysics will not affect properties assigned by MSPhysics. To get the model to work the same way on both MSPhysics and SketchyPhysics, you'll need to assign similar properties with SketchyPhysics UI and MSPhysics UI.
              • F Offline
                faust07
                Ah, good - Thank you. Will try it.
                • romboutR Offline
                  rombout
                  THis is probably windwos only, correct?
                    Anton_S
                    Yes rombout, its windows only. Furthermore, it's unstable and incomplete. Try out SketchyPhysics 3.6.0, while MSPhysics is still under development.
                      tomasz
                      I wish you developed it further or at least made it stable.
                      Here is my quick try with Thea. Maybe it will motivate you slightly 😄
                      Thea Render - Shadow Catcher + IBL
                      • soloS Offline
                        Tomasz!! you tease.
                          Another brick on the wall! 😄
                            RobiBue
                            Hi, I'm using SU2015 and with
                            ams_Lib 3.1.2 and
                            MSPhysics 0.2.1
                            I get the following errors:
                            [pre:16r2j6vf]Error Loading File C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/main.rb
                            Error: #<NameError: uninitialized constant AMS::FFI>
                            C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/sdl.rb:10:in <module:SDL>' C:/Users/*[User Name]*/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/sdl.rb:4:in <top (required)>'
                            C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                            C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/main.rb:39:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
                            C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/*[User Name]*/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:106:in register_extension'
                            C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:106:in <module:MSPhysics>' C:/Users/*[User Name]*/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:88:in <top (required)>'[/pre:16r2j6vf]
                            Please help
                            thanks
                            • luckyvacL Offline
                              luckyvac
                              hello, I can not seem to find a tutorial to create joint . I use SketchyPhysics . I've the table IU but not the icons .
                              Where are the joints ???
                              Thanks for your help.
                              i've 0.2.0 it's worry ?
                              jean-luc
                                Anton_S
                                MSPhysics will be up and running soon. Have a great holiday!
                                  Anton_S
                                  Hi, 0.3.0 Alpha has been released! Go to first post for download.
                                  Changelog:
                                  • Reverted to SDL1 and SDL_Mixer1, which fixed the crash that occurred after using SketchUp for a few minutes.
                                  • Optimized the C++ extension.
                                  • Upgraded to Newton 3.14.
                                  • Added joints. Still more work to go.
                                  • Added replay animation tool. It can record materials and emitters.
                                  I might post videos regarding the features soon. Meanwhile, try out the chains.
                                  chains.skp
                                  • cottyC Offline
                                    cotty
                                    Tried with SU16-64 Win8.1-64:
                                    my SketchUp gallery
                                      Anton_S
                                      Try deleting the old version and download the new one. It might be bragging about localization, but in theory it shouldn't.
                                      • cottyC Offline
                                        cotty
                                        I've compared my installed files with the zip and there were some files missing in my installation. Now it's working perfect, thank you!
                                        click to animate
                                        my SketchUp gallery
                                        • cottyC Offline
                                          cotty
                                          I like the debug modus of your chain model 😉
                                          click to animate
                                          my SketchUp gallery
                                          • cottyC Offline
                                            cotty
                                            How can these (groups of) bodies collide? If the lower group is exploded, the individual parts collide but not as a group/component.
                                            click to animate
                                            coll_example.skp
                                            my SketchUp gallery
                                            • 11
                                            • 46
                                            • 47
                                            • 9 / 47
