πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
MSPhysics 1.0.3 (16 October 2017)
921 Posts 171 Posters 882.9k Views 173 Watching
    tomasz
    @anton_s said:
    Yes rombout, its windows only. Furthermore, it's unstable and incomplete.
    I wish you developed it further or at least made it stable.
    Here is my quick try with Thea. Maybe it will motivate you slightly πŸ˜„
    Thea Render - Shadow Catcher + IBL
    Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
      πŸ˜„
      Tomasz!! you tease.
        Another brick on the wall! πŸ˜„
          RobiBue
          Hi, I'm using SU2015 and with
          ams_Lib 3.1.2 and
          MSPhysics 0.2.1
          I get the following errors:
          [pre:16r2j6vf]Error Loading File C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/main.rb
          Error: #<NameError: uninitialized constant AMS::FFI>
          C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/sdl.rb:10:in <module:SDL>' C:/Users/*[User Name]*/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/sdl.rb:4:in <top (required)>'
          C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
          C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/main.rb:39:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
          C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/*[User Name]*/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:106:in register_extension'
          C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:106:in <module:MSPhysics>' C:/Users/*[User Name]*/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:88:in <top (required)>'[/pre:16r2j6vf]
          Please help
          thanks
            luckyvac
            hello, I can not seem to find a tutorial to create joint . I use SketchyPhysics . I've the table IU but not the icons .
            Where are the joints ???
            Thanks for your help.
            i've 0.2.0 it's worry ?
            jean-luc
              Anton_S
              MSPhysics will be up and running soon. Have a great holiday!
                Anton_S
                Hi, 0.3.0 Alpha has been released! Go to first post for download.
                Changelog:
                • Reverted to SDL1 and SDL_Mixer1, which fixed the crash that occurred after using SketchUp for a few minutes.
                • Optimized the C++ extension.
                • Upgraded to Newton 3.14.
                • Added joints. Still more work to go.
                • Added replay animation tool. It can record materials and emitters.
                I might post videos regarding the features soon. Meanwhile, try out the chains.
                chains.skp
                  cotty
                  Tried with SU16-64 Win8.1-64:
                  my SketchUp gallery
                    Anton_S
                    Try deleting the old version and download the new one. It might be bragging about localization, but in theory it shouldn't.
                      cotty
                      I've compared my installed files with the zip and there were some files missing in my installation. Now it's working perfect, thank you!
                      click to animate
                      my SketchUp gallery
                        cotty
                        I like the debug modus of your chain model πŸ˜‰
                        click to animate
                        my SketchUp gallery
                          cotty
                          How can these (groups of) bodies collide? If the lower group is exploded, the individual parts collide but not as a group/component.
                          click to animate
                          coll_example.skp
                          my SketchUp gallery
                            cotty
                            If I assign the hinge to the ground instead of the group of objects, the collision works, but I need the assignment to that group for this case:
                            coll_example2.skp
                            my SketchUp gallery
                              Anton_S
                              Cotty, joint properties can be editted. Select the desired joint, open MSPhysics UI, and enable 'connected collide' option.
                                cotty
                                Thank you, Anton, that helped!
                                my SketchUp gallery
                                  RobiBue
                                  Just a heads up replying to my post:
                                  ams_Lib 3.1.2 and
                                  MSPhysics 0.2.1
                                  [pre:1doxyosj]Error Loading File ...[/pre:1doxyosj]
                                  Please help
                                  thanks
                                  Thank you,
                                  the new version "0.3.0" runs smoothly on SU 15 and 16
                                  Great work ❗ πŸ‘
                                    PituPhysics
                                    Hello Anton! For me it's not working. New installed SU16-x64 and AMS 3.1.3.
                                    http://sketchucation.com/forums/download/file.php?mode=view%26amp;id=135827
                                    • F Offline
                                      faust07
                                      Initial tests are promising. Great work Anton! πŸ‘ I can not resist to carry out detailed experiments with joints and scripts. Extreme wishes are an import function for SketchyPhysics models and detection of replay data by the Twilight renderer. 😐
                                        PituPhysics
                                        I'm sorry, my fault. 😞 Now work perfectly πŸ‘
                                          Seems terrific! 😎
                                          Nothing for multi-Languages System ?
                                          • 11
                                          • 46
                                          • 47
                                          • 9 / 47
