    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
    • soloS
      πŸ˜„
      Tomasz!! you tease.
        Another brick on the wall! πŸ˜„
          RobiBue
          Hi, I'm using SU2015 and with
          ams_Lib 3.1.2 and
          MSPhysics 0.2.1
          I get the following errors:
          [pre:16r2j6vf]Error Loading File C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/main.rb
          Error: #<NameError: uninitialized constant AMS::FFI>
          C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/sdl.rb:10:in <module:SDL>' C:/Users/*[User Name]*/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/sdl.rb:4:in <top (required)>'
          C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
          C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/main.rb:39:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
          C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/*[User Name]*/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:106:in register_extension'
          C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:106:in <module:MSPhysics>' C:/Users/*[User Name]*/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:88:in <top (required)>'[/pre:16r2j6vf]
          Please help
          thanks
          • luckyvacL
            luckyvac
            hello, I can not seem to find a tutorial to create joint . I use SketchyPhysics . I've the table IU but not the icons .
            Where are the joints ???
            Thanks for your help.
            i've 0.2.0 it's worry ?
            jean-luc
              Anton_S
              MSPhysics will be up and running soon. Have a great holiday!
                Anton_S
                Hi, 0.3.0 Alpha has been released! Go to first post for download.
                Changelog:
                • Reverted to SDL1 and SDL_Mixer1, which fixed the crash that occurred after using SketchUp for a few minutes.
                • Optimized the C++ extension.
                • Upgraded to Newton 3.14.
                • Added joints. Still more work to go.
                • Added replay animation tool. It can record materials and emitters.
                I might post videos regarding the features soon. Meanwhile, try out the chains.
                chains.skp
                • cottyC
                  cotty
                  Tried with SU16-64 Win8.1-64:
                  my SketchUp gallery
                    Anton_S
                    Try deleting the old version and download the new one. It might be bragging about localization, but in theory it shouldn't.
                    • cottyC
                      cotty
                      I've compared my installed files with the zip and there were some files missing in my installation. Now it's working perfect, thank you!
                      click to animate
                      my SketchUp gallery
                      • cottyC
                        cotty
                        I like the debug modus of your chain model πŸ˜‰
                        click to animate
                        my SketchUp gallery
                        • cottyC
                          cotty
                          How can these (groups of) bodies collide? If the lower group is exploded, the individual parts collide but not as a group/component.
                          click to animate
                          coll_example.skp
                          my SketchUp gallery
                          • cottyC
                            cotty
                            If I assign the hinge to the ground instead of the group of objects, the collision works, but I need the assignment to that group for this case:
                            coll_example2.skp
                            my SketchUp gallery
                              Anton_S
                              Cotty, joint properties can be editted. Select the desired joint, open MSPhysics UI, and enable 'connected collide' option.
                              • cottyC
                                cotty
                                Thank you, Anton, that helped!
                                my SketchUp gallery
                                  RobiBue
                                  Just a heads up replying to my post:
                                  ams_Lib 3.1.2 and
                                  MSPhysics 0.2.1
                                  [pre:1doxyosj]Error Loading File ...[/pre:1doxyosj]
                                  Please help
                                  thanks
                                  Thank you,
                                  the new version "0.3.0" runs smoothly on SU 15 and 16
                                  Great work ❗ πŸ‘
                                  • P
                                    PituPhysics
                                    Hello Anton! For me it's not working. New installed SU16-x64 and AMS 3.1.3.
                                    404 Not Found
                                    (sketchucation.com)
                                    • F
                                      faust07
                                      Initial tests are promising. Great work Anton! πŸ‘ I can not resist to carry out detailed experiments with joints and scripts. Extreme wishes are an import function for SketchyPhysics models and detection of replay data by the Twilight renderer. 😐
                                      • P
                                        PituPhysics
                                        404 Not Found
                                        (sketchucation.com)
                                        I'm sorry, my fault. 😞 Now work perfectly πŸ‘
                                          Seems terrific! 😎
                                          Nothing for multi-Languages System ?
                                            Deano45
                                            Hello, New to MsPhysics. I've installed SU16-x64 and AMS 3.1.3. But keep getting bug splats.
                                            I thought it might be my Desktop, So i tried my laptop and got the same bug splat. The install is pretty simple am i missing a step?
                                            Thanks Deano
                                            • 11
                                            • 46
                                            • 47
                                            • 9 / 47
