    [Plugin] TT_Lib²
    310 Posts 66 Posters 499.0k Views 66 Watching
      SKPudden
      Hi TT
      Thanks for the fast response.
      Here's what the Console gives me:
      load 'tt_cleanup.rb'
      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_cleanup.rb:20: warning: already initialized constant PLUGIN_ID
      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_cleanup.rb:21: warning: already initialized constant PLUGIN_NAME
      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_cleanup.rb:22: warning: already initialized constant PLUGIN_VERSION
      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_cleanup.rb:25: warning: already initialized constant FILENAMESPACE
      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_cleanup.rb:26: warning: already initialized constant PATH_ROOT
      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_cleanup.rb:27: warning: already initialized constant PATH
      true
      load 'tt_cleanup/core.rb'
      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2.rb:19: warning: already initialized constant PLUGIN_ID
      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2.rb:20: warning: already initialized constant PLUGIN_NAME
      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2.rb:21: warning: already initialized constant PLUGIN_VERSION
      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/system.rb:16: warning: already initialized constant PLATFORM_IS_OSX
      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/system.rb:19: warning: already initialized constant PLATFORM_IS_WINDOWS
      Error: #<TypeError: /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/system.rb:22:in expand_path': can't convert nil into String> /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_cleanup/core.rb:11 /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/system.rb:22 /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/TT_Lib2/core.rb:10:in require'
      /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_cleanup/core.rb:10:in require' /Library/Application Support/Google SketchUp 7/SketchUp/Plugins/tt_cleanup/core.rb:10 (eval):155:in load'
      (eval):155
      The versions installed are:
      Cleanup 3.2.0
      TT Lib 2.9.8
        Oh, I forgot to come back to this issue. Is it still an issue or have you found a way to resolve it?
          SKPudden
          Hi Thomas. Thanks for getting back to me. I now have a working setup but only on my Mac at work. it's an Intel Mac Mini running 10.5.8 and I'm using SU7, TT_Cleanup 3.2.1 with TT_Lib 2.7.1. I tried 2.7.0, 2.8.3 and 2.9.8 before this and none of them worked. On my home computer, a G4 desktop running 10.4.11, no combination of TT_Cleanup and TT_Lib will work. I've tried them all (many times). Do you have any suggestions? Thanks.
            SKPudden
            Further to my earlier post:
            1. I now have a working setup on a 10.5.8 partition on my home Mac, using TT_Cleanup 3.2.1 and TT_Lib2 2.7.1 (the same setup as my Mac at work). I haven't tried every possible combination, but 2.9.8 definitely won't work. Having to use a separate partition is obviously not ideal, but it's a workround - a pity all my other stuff is on the main partition (running 10.4.11).
            2. I now have a working setup on the main partition using Cleanup 2.0.0. which of course requires no TT_Lib. Again not ideal, but it's a workround.
            It appears that the operating system may be the problem. Is there a way to get the more recent versions of TT_Cleanup and TT_Lib2 to run on OSX 10.4.11? If not, what is the most recent version of TT_Cleanup that will run on 10.4.11 (with or without TT_Lib)?
            Trouble is, Cleanup3 is such an advance on 2 that I may have to consider upgrading the main partition just to get the benefits!
              10.4...hmm... been a long time since I used that. I think I have an old G4 Mac Mini somewhere. Though not sure if it's alive.
              And what's the latest SketchUp version you can run on 10.4? (Guess I should know this.... :s)
                SKPudden
                I knew you'd say that :OD
                On 10.4 the latest version of Sketchup is 7. Leopard can use 8.
                • ssokolS
                  ssokol
                  ThomThom , thank you for your great plugins!
                  I use Sketchup 2014 on Win8.1 and I have problem. I installed your current plugins but error appear. I had simillar problem with other plugins but I resolved this by creating other plugin folder without polish letters. But if moved your plugins to this folder it doesn't work. please help.Thank you.
                  Error below:
                  Error Loading File C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb
                  Error: #<IOError: Path not found>
                  C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:49:in initialize' C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:124:in new'
                  C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:124:in <module:Lib>' C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:110:in module:TT'
                  C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:20:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                  C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2.rb:40:in register_extension'
                  C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2.rb:40:in <module:Lib>' C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2.rb:14:in module:TT'
                  C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2.rb:13:in <top (required)>' Error Loading File C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb Error: #<IOError: Path not found> C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/c_extension_manager.rb:49:in initialize'
                  C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:124:in new' C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:124:in module:Lib'
                  C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:110:in <module:TT>' C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/TT_Lib2/core.rb:20:in <top (required)>'
                  C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                  C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb:10:in <top (required)>' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require'
                  C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load' C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools.rb:39:in register_extension'
                  C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools.rb:39:in <module:MaterialTools>' C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools.rb:15:in module:Plugins'
                  C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools.rb:14:in <module:TT>' C:/Users/Stanisław/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools.rb:13:in <top (required)>'
                  Thanks for help!
                    Right, I would need to poke around in dark corners to see if I can find the hardware to reproduce this. To be honest - I haven't tested my plugins on SU7 for a long time...
                      Non-english characters should not be a problem in SU2014 any more as we updated the Ruby interpreter to version 2.0 that should handle Unicode.
                      Can you give me a screenshot of the content of:
                      There should be a 'libraries' folder containing a 'stage' folder:
                      Do you find that?
                      Also what is the content of the 'stage' folder?
                        SKPudden
                        I'm giving serious consideration to upgrading my home rig to 10.5.8 (which is as far as it can go). It would have a number of benefits (not the least of which would be the ability to use Cleanup3!). There would also be a few drawbacks, but I suppose these could be alleviated by keeping a 10.4 partition (mainly for for Classic apps - yes, I still use OS9 sometimes). Thank you for looking into this, and if you feel like having a look, please do. But I can manage with version 2 for now.
                        • X
                          xjhossef
                          Hi Thomthom
                          I really appreciate your great plugins.
                          since installing the new tt_lib2. I get this error and it is not installed, only when I open the already saved files but when I open sketchup 2014 as a new document is normally installed
                          :C
                          ERROR: The request could not be satisfied
                          (i307.photobucket.com)
                          • tt_suT
                            tt_su
                            Are you using the first release of SketchUp 2014? If so, please update to maintenance release 1.
                              smuncky
                              We were having the same problem as xjhossef. Couldn't figure out what it was because it worked on one half of the computers but not the other.
                              Looks like IT didn't update the half w/ the problem to maintenance release 1.
                              Thanks for the heads up ThomThom!
                                jemoto
                                Thanks for all the great work. I have a problem installing TT_Lib2 and Bezier Surface to my Sketchup 2013, actually on two different computers, one running W7 32-bit and one running W8 64-bit. The error messages are the same. I am told TT_Lib is not installed although it is listed under extensions, and then I get the following error messages in the Ruby Console:
                                Error Loading File C:/Program Files/SketchUp/SketchUp 2013/Plugins/TT_Lib2/core.rb
                                5: Access is denied. - C:/Users/Anybody/AppData/Local/Temp/TT_Lib2.rb/2.9.15/1.8/win32/tt_lib2.so
                                Error Loading File C:/Program Files/SketchUp/SketchUp 2013/Plugins/TT_Lib2.rb
                                Error Loading File C:/Program Files/SketchUp/SketchUp 2013/Plugins/tt_bezier_surface/core.rb
                                uninitialized constant TT::Version
                                Error Loading File tt_bezier_surface.rb
                                Do you have any idea what causes this? I have searched the net, but without success.
                                • tt_suT
                                  tt_su
                                  How are you installing the extension?
                                  Are you using a User or Administrator account?
                                    jemoto
                                    I am using a User account (supposedly with administrator privileges), and I suspected that could have something to do with it. I just tried to install under a "real" administrator account, and then it works. Only problem now is that I cannot invoke the "Create Quadpatch" icon, but it is in the Draw menu, so not a big deal.
                                    Thanks a lot for your help!
                                    • P
                                      Pherim
                                      Hello,
                                      I just installed CleanUp v3.3.1, Solid Inspector 2.4.3, and TT Library 2.10.2 and now ThomThom's Menu doesn't work any more, apparently. Only PickIt remains in the Menu, all other plugins are scattered around the Extensions Menu, which also breaks some of my Shortcuts.
                                        @pherim said:
                                        Hello,
                                        What else do you have installed? You use Fredo'd extension loader or the SCF manager?
                                        • P
                                          Pherim
                                          Not as far as I know. I used the Sketchucation Plugin Store to install them and until now everything worked fine.
                                            What OS and SketchUp version are you one?
                                            Can you post a screenshot of your Plugins folder?
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 15 / 16
