    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
      maxosmedia
      Thanks Dave R! But, you links is for LibFredo6_v6.8
        The current version is available in the SCF Plugin Store as described in the first post of this thread. Use the SCF Plugin Store to automatically install it.
          maxosmedia
          What am I doing wrong?
            Not sure. I just tried it and it worked fine for me. Is it a file association problem? Maybe try clearing the IE caches/temporary internet files and give it another try.
              maxosmedia
              IE? MacOSX. No file associations problem on OS level
                Sorry. Clear the Safari caches.
                  maxosmedia
                  Safari caches? This screenshot is from SU plugin "Sketcucation plugin store"
                    On a PC all of SketchUp's dialogs use Internet-Explorer.
                    On a MAC all of SketchUp's dialogs use Safari.
                    This usage is quite separate from whatever you use for your day-to-day browsing.
                    Like everything else... the SketchUcation PluginStore uses those 'helper' applications for its dialogs...
                    So if you are on a MAC open Safari, then empty its cache...
                    Then restart SketchUp and see if that helps...
                      maxosmedia
                      Thanks TIG! Cleaned. No effect, the same bug
                        driven
                        when that fails to make a difference you can trash the SU WebKit cache, because it not really Safari...
                        Drag this to Trash...
                        ~/Library/Caches/com.sketchup.SketchUp.2015
                        or whatever version of SU your running [your profile says v8???]
                          maxosmedia
                          Thanks driven!
                          SU cache is trashed, SU is restarted, No effect!
                            driven
                            well unless your really still on v8, WebDialog seems to not be the issue...
                            I'll try and instal it...
                              driven
                              works with v15, but it's sooo long since I fired up SU v8, SketchUcation Plugin Store shows a 404...
                              maybe later...
                                driven
                                but it did instal using Preferences >> Instal Extension...
                                  Poot
                                  I installed the joint push pull by rubyscript. And i'm trying to install the lib fredo..... by plugin store.
                                  What am i doing wrong here? I push install in the plugin store then this comes out.
                                  When i restart sketchup he says this?
                                  • fredo6F Offline
                                    A priori, you need to install LibFredo6 6.9. Did you do it (if so, you should see a submenu "LibFredo6 Settings..." in the Window menu of Sketchup.
                                      The clue is in the message.
                                      First load the latest LibFredo, then whatever Fredo's tools you use.
                                      [Because the Lib has changed you need the latest tools too]
                                      Finally restart SketchUp to complete the installations...
                                        Poot
                                        Hi guys,
                                        Thanks for the fast reply's but i think that it's going wrong on the first pic.
                                        Pc says as you see on the pic:
                                        You can write to main plugins folder, and...
                                        You have a costum plugins folder.
                                        then he give's the two folders but i can not pick one,
                                        I have pressed enter and every button on my keyboard so i don't undestand how i properly can instal the fredo 6.3 tools. Ore choose the correct folder what is going wrong here?
                                        Thanks in advance,
                                        Sam
                                          Poot
                                          Fixed it, i made the most obvious mistake ever. (schame shame shame πŸ˜• )
                                          I just needed to make the window bigger and choose the correct map.
                                          Thanks again guys!!
                                            coasterinc
                                            iv come up against a really confusing issue, ALL fredo tools have stopped working, (scale, round corner, pushpull, curviloft, tool on surface) none of them do anything when i press the icons... they stopped working on 2015, uninstalled and cleaned everything out of old plugin folders (appdata loc), reinstalled and nonthing, try 2016 and the exact same thing happens, why on earth do they now no longer work?!
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 109
                                            • 110
                                            • 18 / 110
