    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
      maxosmedia
      Hm... where is "download" button?
        Hm...It helps to look at the first post of the thread to which Fredo linked.
          maxosmedia
          Thanks Dave R! But, you links is for LibFredo6_v6.8
            The current version is available in the SCF Plugin Store as described in the first post of this thread. Use the SCF Plugin Store to automatically install it.
              maxosmedia
              What am I doing wrong?
                Not sure. I just tried it and it worked fine for me. Is it a file association problem? Maybe try clearing the IE caches/temporary internet files and give it another try.
                  maxosmedia
                  IE? MacOSX. No file associations problem on OS level
                    Sorry. Clear the Safari caches.
                      maxosmedia
                      Safari caches? This screenshot is from SU plugin "Sketcucation plugin store"
                        On a PC all of SketchUp's dialogs use Internet-Explorer.
                        On a MAC all of SketchUp's dialogs use Safari.
                        This usage is quite separate from whatever you use for your day-to-day browsing.
                        Like everything else... the SketchUcation PluginStore uses those 'helper' applications for its dialogs...
                        So if you are on a MAC open Safari, then empty its cache...
                        Then restart SketchUp and see if that helps...
                          maxosmedia
                          Thanks TIG! Cleaned. No effect, the same bug
                            driven
                            when that fails to make a difference you can trash the SU WebKit cache, because it not really Safari...
                            Drag this to Trash...
                            ~/Library/Caches/com.sketchup.SketchUp.2015
                            or whatever version of SU your running [your profile says v8???]
                              maxosmedia
                              Thanks driven!
                              SU cache is trashed, SU is restarted, No effect!
                                driven
                                well unless your really still on v8, WebDialog seems to not be the issue...
                                I'll try and instal it...
                                  driven
                                  works with v15, but it's sooo long since I fired up SU v8, SketchUcation Plugin Store shows a 404...
                                  maybe later...
                                    driven
                                    but it did instal using Preferences >> Instal Extension...
                                      Poot
                                      I installed the joint push pull by rubyscript. And i'm trying to install the lib fredo..... by plugin store.
                                      What am i doing wrong here? I push install in the plugin store then this comes out.
                                      When i restart sketchup he says this?
                                      • fredo6F Offline
                                        A priori, you need to install LibFredo6 6.9. Did you do it (if so, you should see a submenu "LibFredo6 Settings..." in the Window menu of Sketchup.
                                          The clue is in the message.
                                          First load the latest LibFredo, then whatever Fredo's tools you use.
                                          [Because the Lib has changed you need the latest tools too]
                                          Finally restart SketchUp to complete the installations...
                                            Poot
                                            Hi guys,
                                            Thanks for the fast reply's but i think that it's going wrong on the first pic.
                                            Pc says as you see on the pic:
                                            You can write to main plugins folder, and...
                                            You have a costum plugins folder.
                                            then he give's the two folders but i can not pick one,
                                            I have pressed enter and every button on my keyboard so i don't undestand how i properly can instal the fredo 6.3 tools. Ore choose the correct folder what is going wrong here?
                                            Thanks in advance,
                                            Sam
                                            • 102
                                            • 103
                                            • 104
                                            • 105
                                            • 106
                                            • 109
                                            • 110
                                            • 104 / 110
