    1.5k Posts 471 Posters 3.3m Views 470 Watching
      kashiu
      Hi fredo
      I have the su2015 & Im interstate in the round corner pouring, can you help me?
        littleche
        HI
        I Have problem with this model . round corner can't rounding this model and recive overlab error.
        How can I fix this problem?
        P & P.skp
        thanks
        • fredo6F Offline
          @littleche said:
          HI
          thanks
          Unfortunately, with the current algorithm, this is not possible.
          At the sharp corner, you have edges which are smaller than the offset.
          Sorry for inconvenience
            littleche
            @fredo6 said:
            @littleche said:
            HI
            thanks
            Thank you fredo . You are always trying to develop this plugin.And I thank you very much.If you are not a thing of SketchUp shortage!
            I hope you can fix algorithm in the next version .Always sincerely pray for your success...
            • W Offline
              Will C
              I've been using this plugin for a while now and it's pretty awesome. Makes curving edges a lot faster with less frustration. Thanks for making this.
                Tony2015
                thx fredo
                • bac9-flclB Offline
                  bac9-flcl
                  @fredo6
                  Is it possible to fix the chamfer process failing on such a corner?
                  http://i.imgur.com/EuaXGhj.png
                  It's pretty much impossible to avoid places like those in serious quad-based hardsurface modeling, and other chamfering implementations (in 3ds Max, Maya, etc.) never had issues with topology like that, so I'm not sure if anything really prevents proper chamfering here. Typically, corners like those are simply resolved like this:
                  http://i.imgur.com/8UUbDRJ.png
                  • fredo6F Offline
                    Not possible with the current algorithm.
                    Would require another technique, which I may implement one of these days.
                      bac9-flcl
                      Thanks for the info!
                      While at it, can you take a look at this improvement? It would be an enormous help for users inserting edges into n-gons to control triangulation, and to users with quad-based geometry or otherwise unavoidable coplanar face sequences:
                      http://i.imgur.com/wnsXjhF.png
                        Guig2000
                        this plugin helped me previously, so, thanks for that, fredo.
                        But well it don't like curves at all even at 100 000 scale and despite that in this sample, the offset is much smaller than my requirement, I had overlaps everywhere.
                        http://www.zimagez.com/miniature/sketchuproundcorneroncurved.png
                        http://www.zimagez.com/miniature/sketchuproundcorneroncurved20.png
                        Also a good enhancement could be to be able to have multi-offsets capability in a selection.
                          pegaze
                          hi everyone,
                          i just run that plugin and after generating geometry, the model became a single part, i'm not able to select a face, if i try to select a face or anything else, the model is all selected ... is it always like that or may i miss something ?
                          i also dont see any line on the edges.
                          thanks for your answers.
                            It depends on the settings you've chosen. If you choose to smooth/soften the edges, then you'll get that behavior. But you can choose not to soften the edges and then you'll be able to select a single face. Or you could turn on Hidden Geometry and select individual faces even with the edges softened.
                              pegaze
                              Great !! Thanks a lot, it's now working well
                              • W Offline
                                Wookbert
                                Have you ever noticed the tiny size of RoundCorner control bar on a MacBook Retina? (MBPr 13" running 10.11.1 or any other Mac OS X version)? See attachment.
                                Any idea how to solve this?
                                • I Offline
                                  indrifitrian6
                                  where i can find the download link button?
                                    Look in the SketchUcation PluginStore - link in menu above...
                                    Use the page's Search tool to find the entry, it it's not immediately seen...
                                    • fredo6F Offline
                                      There is nothing that can be done in scripts for high resolution screens under Sketchup.
                                      • It might be that SU2016 has improved the situation
                                      • otherwise, if you go to Window > LibFredo6 Settings... > Default Parameters..., you should find a check box about Retina. It should double the size of the buttons. However, there is not garantee that the character size would follow.
                                      • W Offline
                                        Wookbert
                                        @fredo6: Wasn't aware of the Retina check box. It helps a bit, the text however still is too small to be read and edited conveniently.
                                        • fredo6F Offline
                                          The logic of font size vs screen resolution is not accessible from the Ruby API.
                                          However, you may want to read this thread, where other Mac users are discussing potential solutions.
                                            gregoiregentil
                                            Bonjour! I don't manage to get round corners for this design (http://imgur.com/kYQ9ITf😞
                                            What am I doing wrong? Here is the file: http://www.filedropper.com/casing-v1
                                            I'm running the latest of Fredo6 and round corners on Sketchup 8.
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 73
                                            • 74
                                            • 62 / 74
