    1.5k Posts 477 Posters 4.2m Views 477 Watching
    • L
      littleche
      @fredo6 said:
      @littleche said:
      HI
      I Have problem with this model . round corner can't rounding this model and recive overlab error.
      How can I fix this problem?
      thanks
      Unfortunately, with the current algorithm, this is not possible.
      At the sharp corner, you have edges which are smaller than the offset.
      Sorry for inconvenience
      Thank you fredo . You are always trying to develop this plugin.And I thank you very much.If you are not a thing of SketchUp shortage!
      I hope you can fix algorithm in the next version .Always sincerely pray for your success...
      • W
        Will C
        I've been using this plugin for a while now and it's pretty awesome. Makes curving edges a lot faster with less frustration. Thanks for making this.
        • T
          Tony2015
          thx fredo
          • bac9-flclB
            bac9-flcl
            @fredo6
            Is it possible to fix the chamfer process failing on such a corner?
            http://i.imgur.com/EuaXGhj.png
            It's pretty much impossible to avoid places like those in serious quad-based hardsurface modeling, and other chamfering implementations (in 3ds Max, Maya, etc.) never had issues with topology like that, so I'm not sure if anything really prevents proper chamfering here. Typically, corners like those are simply resolved like this:
            http://i.imgur.com/8UUbDRJ.png
            • fredo6F
              Not possible with the current algorithm.
              Would require another technique, which I may implement one of these days.
              • bac9-flclB
                bac9-flcl
                Thanks for the info!
                While at it, can you take a look at this improvement? It would be an enormous help for users inserting edges into n-gons to control triangulation, and to users with quad-based geometry or otherwise unavoidable coplanar face sequences:
                http://i.imgur.com/wnsXjhF.png
                • G
                  Guig2000
                  this plugin helped me previously, so, thanks for that, fredo.
                  But well it don't like curves at all even at 100 000 scale and despite that in this sample, the offset is much smaller than my requirement, I had overlaps everywhere.
                  http://www.zimagez.com/miniature/sketchuproundcorneroncurved.png
                  http://www.zimagez.com/miniature/sketchuproundcorneroncurved20.png
                  Also a good enhancement could be to be able to have multi-offsets capability in a selection.
                  • P
                    pegaze
                    hi everyone,
                    i just run that plugin and after generating geometry, the model became a single part, i'm not able to select a face, if i try to select a face or anything else, the model is all selected ... is it always like that or may i miss something ?
                    i also dont see any line on the edges.
                    thanks for your answers.
                      It depends on the settings you've chosen. If you choose to smooth/soften the edges, then you'll get that behavior. But you can choose not to soften the edges and then you'll be able to select a single face. Or you could turn on Hidden Geometry and select individual faces even with the edges softened.
                      • P
                        pegaze
                        Great !! Thanks a lot, it's now working well
                        • W
                          Wookbert
                          Have you ever noticed the tiny size of RoundCorner control bar on a MacBook Retina? (MBPr 13" running 10.11.1 or any other Mac OS X version)? See attachment.
                          Any idea how to solve this?
                          • I
                            indrifitrian6
                            where i can find the download link button?
                              Look in the SketchUcation PluginStore - link in menu above...
                              Use the page's Search tool to find the entry, it it's not immediately seen...
                              • fredo6F
                                There is nothing that can be done in scripts for high resolution screens under Sketchup.
                                • It might be that SU2016 has improved the situation
                                • otherwise, if you go to Window > LibFredo6 Settings... > Default Parameters..., you should find a check box about Retina. It should double the size of the buttons. However, there is not garantee that the character size would follow.
                                • W
                                  Wookbert
                                  @fredo6: Wasn't aware of the Retina check box. It helps a bit, the text however still is too small to be read and edited conveniently.
                                  • fredo6F
                                    The logic of font size vs screen resolution is not accessible from the Ruby API.
                                    However, you may want to read this thread, where other Mac users are discussing potential solutions.
                                    • G
                                      gregoiregentil
                                      Bonjour! I don't manage to get round corners for this design (http://imgur.com/kYQ9ITf😞
                                      What am I doing wrong? Here is the file: http://www.filedropper.com/casing-v1
                                      I'm running the latest of Fredo6 and round corners on Sketchup 8.
                                        In your screenshot you show the radius of the rounding (called Offset) as 0.1 mm. That's incredibly small. Try a reasonable value for the size of the object.
                                          Yes, as Dave says, SketchUp itself [and by connection its Plugins] can't cope with dimensions with tiny dimensions [<=1/1000"]
                                          So try something a bit bigger...
                                          • G
                                            gregoiregentil
                                            Regarding my previous post with an error while trying to create a round corner for a kind of dome, yes, I tried much bigger values for the offset but it was the same problem, nothing happened when I click generate.
                                            I figured out that the culprit was the arcs at the base of the geometry. If I replace the arcs by straight lines, the plugin can generate something. I understand how it could be challenging for a plugin to generate rounded corners when you have a circle or arc at the base. And if the arc is converted to successive small lines, it's even more challenging and it will push you to have a very small offset.
                                            So I will most likely stay with straight lines at the base. My question becomes more now: is there a way to have different offset for different lines during the same single rounded corner generation. Because you might want to have two different values for 3 lines that intersect so I don't think that you can do it sequentially.
                                            • 51
                                            • 52
                                            • 53
                                            • 54
                                            • 55
                                            • 74
                                            • 75
                                            • 53 / 75
