ℹ️ GoFundMe | Our friend Gus Robatto needs some help in a challenging time Learn More
Bricks'n'Tiles alternative
extensions
10 Posts 4 Posters 1.3k Views
    miikka1978
    Bricks'n'Tiles has been my favorite tile texture generator for a long time. Anyway, I updated my Windows 7 to Windows 10 and I can't get it working anymore. Do you know if there are any similar texture generator softwares available?
    This domain is for sale
    (www.bricksntiles.com)
    Edit 12.1.2023:
    Here few ones that have been proposed/considered:
    https://architextures.org/
    https://www.vizpark.com/shop/omnitiles-standalone/
    https://www.poliigon.com/search/generator
    https://www.materialmaker.org/
    https://www.renderhub.com/viverna/tiles-generator-texture
    https://www.stonecurators.com/stone-designer/
    https://blenderartists.org/t/addon-parquet-floor-generator/630413
      rv1974
      Missing this utility too.
      Lately I use Floor generator in 3DS Max to make huge stone wall textures.
      • topic:timeago-later,7 years
        miikka1978
        I have lately been getting back to 3D model rendering and I would like to create my own textures from product images.
        What are the software (free or paid) that you are using nowadays to create your own tiling/seamless textures, see example below?
        I am still dreaming about Bricks'n Tiles but unfortunately it is no longer available. I also have some really old Substance player (Make_It_A_Parquet) template but somehow it doesn't really work because I am not able to change the background color and there are some weird lines in the output.
        https://i.postimg.cc/HLt06Kr0/Sunbstance-Player.jpg
          Gus R
          Have you looked into Poliigon generators? They also use the sbsar method. I got the modern bricks generator and it's really good. They also have a marble tiles generator. They also have a color picker to adjust tones which can be used outside of the Substance Player.
          www.instagram.com/gusrobatto/
          https://bsky.app/profile/gus-robatto.bsky.social
          • R Online
            This is quite good for a free alternative to node based procedural material creation...
            Material Maker
            Material Maker procedural textures authoring tool web page
            (www.materialmaker.org)
            Download the free D'oh Book for SketchUp
              miikka1978
              This looks really nice / quick /simple solution. Is there some way to use a source image as an input texture? For example if I have a source texture from a tile manufacturer I could use the image and just create nice tiling texture with some variations for tiles to make it realistic. I checked some Poliigon generator tutorials but I didn't see any option to use source images.
              Source image example:
              https://i.postimg.cc/JhDvXkMJ/LATTIALAATTA-BOSTON-GREIGE-60cm-x-60cm.jpg
              bp station locations us
                Gus R
                I am not aware of being able to use any source textures with the Poliigon generator.
                Another option might be Architextures where you can upload a source texture. I created some textures there yesterday and uploaded some that I required. You can add textures. Not sure how many.
                You can generate a basic diffuse or color map and a black and white bmp. I like to create a normal map using the Nvidia Texture Tools. That's for rendering.
                It's $5.95/month.
                  Gus R
                  I was able to generate a simple tile pattern using your sample for the pattern. You'd have to experiment with all the different settings there. You can add more than one texture.
                    Gus R
                    Your sample is pretty small so make sure you get anything from 1K to 4K in size. A 1K would be 1024x1024 pixels. It's all double from there: 1024, 2048, 4096, etc. The smallest size texture forces the other textures to be reduced in size so you'll lose a lot of resolution.
                      miikka1978
                      It's $5.95/month.
                      Thanks for this tip. This seems like a perfect solution for my purpose. I just assigned for this at least for a month.
                      Material Maker
                      I will also check the Material Maker. After a quick test this seems to be really comprehensive tool but it takes quite some time to learn to use it. I tested quickly some basic templates but even those included so many inputs/outputs that I got totally confused.
