    Face-me Components Rotating Unexpectedly
    28 Posts 8 Posters 4.4k Views 8 Watching
      Where are your model axes ?
      Are your face-me components' axes equivalent ??
      • AureusA
        Aureus
        The site is 1500x600m big so the origin of the model is pretty distant from those trees, more than a kilometre. You can see it yourself if you download the SU file from my previous post. But that is how it is, that cannot be changed.
        As for how axes of the face-me component relate to the axes of the containing component this can be seen on the GIF image below.
          Why is the model origin so far off ?
          Large distances can cause issues...
          Also, have you ever 'reset' the model's axes at all ?
          Hover over an axis away from other entities and choose 'Reset'...
          Clearly something is adrift "in the axis department" !
          Have you also tried adjusting the various Preferences > OpenGL settings to see if they have any effect ?
          • AureusA
            Aureus
            I'm modelling a part of the town, and as I said the site is pretty big so wherever you put the origin some parts of the site will be distant from it.
            I'm not modeling everything in the same file but I'm modelling parts of the site in smaller files so now it's not even convinient for me at this stage to change the origin of the main file since I don't need some mess with 'Paste in Place' command.
            Anyway, I'd like to hear does anyone else have the same problem with the file I uploaded.
            And also what causes missing shadows from some faces of the trees...
              slbaumgartner
              Yes, I see the same issue with the file you uploaded. For whatever they are worth, some random observations:
              Though the trees are "face me" they really don't look like they are flat to the viewport. Their bounding boxes certainly aren't. Also, the bounding boxes are quite large compared to the tree, as if there is some hidden or minuscule geometry in there somewhere, though I can't find any.
              They are nested inside components, so I tried exploding the components. That reduced the bounding boxes to a tight 2D fit, but still they aren't oriented flat to the viewport and still if you find a malignant viewpoint they will tumble.
              While they are undergoing weird gymnastics, I can't select any of the offending trees by clicking on their current view location, but they select if I click in open air where they would be if upright. After I exploded the components, if I click on a rotated tree, it immediately snaps back upright!
              The effect is quite sensitive to exactly where you orbit, almost as if there is a "gimbal lock" sort of singularity affecting the transformations that only happens at certain view directions.
              All this makes me suspect there really is a nasty corner-case bug in how the transformations for face-me components are managed.
              • AureusA
                Aureus
                1 I think that the reason why a bounding box of the simple component is bigger than you'd expect probably has to do something with anticipation of rotation of the face-me tree which is inside.
                2 I also noticed that thing with clicking the air where the upright tree should be but it isn't when starts its gymnastics. Curious, isn't it?
                3 slbaumgartner, have you checked why shadows of some faces are not cast though they should?
                • Wo3DanW
                  Wo3Dan
                  It´s a nightmare and almost as if having drunk too much when orbiting this model
                  At first I thought it had something to do with mirrored components but correcting thad didn't do the trick.
                  I haven´t found the exact cause of the issue but kept selecting malicious trees one by one > right clicking them > select Reset Scale and/or Reset Skew until all of them obeyed the orbit tool as should.
                  I would sugguest to recreate the tree component from raw geometry (=explode>explode>explode....till raw) and replace all of these trees (through the 'Component' browser) by the new one.
                    slbaumgartner
                    I poked around a bit and found that if you check Edge shadows, those do appear and they don't participate in the gymnastics. But I haven't found a reason why the Faces aren't casting shadows.
                    Along the way I noticed that this model is about 200m below the red-green plane of your model. I don't think that affects the flopping and shadows issues, but was surprised that you are modeling a canyon 😉
                    Bottom line: somewhere along your process for creating this you stepped through a portal into the Twilight Zone.
                    • AureusA
                      Aureus
                      If you look the first GIF file I uploaded you'll see that one face-me tree is acting weird even though it's only a couple of metres distant from the origin of the model (which I deleted). So I think that having the origin distant from the trees cannot be the cause for this behaviour. At least not in this situation.
                      After all, I think that big distances are not relevant per se, but only in relation to the size of your entities. In the case of my main model (which is big and complex), the distances are big but I don't have microscopic details. Also I didn't have any other problem with it prior creating these face-me trees.
                      And not only that but it appears that only one specific tree type is from some reason problematic: one of those two linden trees. I made two linden tree types and one of them decided to dance.
                      My new guess is that this has to do something with the way I scaled those face-me trees or the way I made unique one of the instances of that problematic linden type, which I then copied all around the site and now some of them refuse to behave nicely. 😕
                      As for the missing shadows...this issue was present on different tree types. I solved it in an unusual way: simply by changing a bit the RGB value of the material applied to the faces which refused to cast shadows. When I changed back to the old RGB value shadows remained. It's enigma to me.
                      Twillight Zone, yes. 😕
                        mac1
                        Face Me Trees Behaving Weird Again_mac1.skpIt appears resetting of scale and skew on the ones with problems make them perform as expected. More test needs to be done , was wrong once already 😳
                        BTW it sounds like you are going to trouble not needed. The small circles can be used as proxies, you can then replace them with a target tree ( you select the proxies and then target tree in component browser, then select replace selected. Hope our friends have not changed this been several years ? ) and they will be copied in to the proxies scale and its axis aligned to the proxies.
                        This file simplifies you op model, I used all same trees, randomly select some trees, open component browser, select a replacement tree, it could be a motorcycle if you want. Click it an select replace selected see what you get.
                        • AureusA
                          Aureus
                          What I have done when creating my tree collection and placing it in my model can be seen in the gifs below. This time I made the circles bigger so that one can see them more easily.
                          First I create a circle and make it a component. Then I put inside a previously made face-me tree. Then I copy it here and there and use Fredo scale and flip function to add to some diversity. (With the third instance I made a little mistake.)
                          Then I make one of the component unique as well as the face-me tree inside cos I realize I need a bit longer trunk for the slopes. I longer it for 2m and I move down the circle too. I don't touch the axes. I copy that unique component around and scale its instances to different ratios. Some of them I flip around the red or green axis.
                          ![At one point I decide to replace one tree type with some other. I just delete one face-me tree type and insert a new one. Since the "circle + tree" component has been already scaled I don't have to repeat that process. The GIF shows they are properly scaled.](/uploads/imported_attachments/QX8G_Ivedonethis02.gif "At one point I decide to replace one tree type with some other. I just delete one face-me tree type and insert a new one. Since the "circle + tree" component has been already scaled I don't have to repeat that process. The GIF shows they are properly scaled.")
                          The last GIF shows the trees from above. Due to scaling some circles turned to elipses. You can also see why those bounding boxes differ from tree to tree.
Now good question is why those trees with the longered trunks behave as they should without silly gymnastics that made me start this thread? Earlier I posted a SU and GIF file where one can see them displaying that notorious face-me behaviour. Here they act just fine.
                            mac1
                            This was done probably in time it takes for you to do 1 tree almost. Suggest you are stove piped. There are two cases where one type tree was located at verties of rec with random rotation and scaling of 1 to 0.5, second case was trees form you model BTW copied along a Bezier curve and then a few selected ones replaced with different type tree. This was done using a plugin called comp spray plugin available at plugin store.
                            I have tried and done 💚
                            • AureusA
                              Aureus
                              Well, mac 1,
                              I'm sure you've realized that when you pick a problematic component and reload its face-me sub-component by replacing it with some other face-me component such are native SU characters...the behaviour remains the same (see the image below). 😮
                              However if you reload a whole component (like Derrick) instead of "circle+face-me tree" component then there's no silly movements.
                              This will remain some kind of mystery.
                              Eventually I had to put new trees manually on the same location, one by one. So far new trees are OK. 😄
                                mac1
                                Face Me Trees Behaving Weird Again_mac1A.skp
                                Very condescending and presumptuous comment especially when you have not tried the solution presented before I posted, it is not just replacement=> read the post! Here is the skp model I made before posting the picture. 💚
                                • AureusA
                                  Aureus
                                  I simply realized that in your experiment you used the tree type that wasn't problematic at all so what you solved had been already solved.
                                    mac1
                                    Making assumptions is a basic voliation of general approaches to trouble shooting.
                                    Will try one more time, take the model you posted above and orbit until things go crazy, select one of those, look at the out liner that will show you which instance it is, select edit component and you should see all the instances of that definition selected in the out liner, select reset skew, that will change all the instances since you are in the edit mode. Now try the orbit again and you should see the problem is gone for that definition. Just to be on the safe since I think I exploded the lower level entity in your nested model so you have one so program deals with just the one item and possible different axis location.
                                    The question is how did the skew happen??
                                    • AureusA
                                      Aureus
                                      Cheap philosophy is of no help here.
                                      It won't make any serious contribution to this thread. 😄
                                        driven
                                        Chris explains how to create one here...
                                        [web 100%,400:8geuufsp]http://sketchucation.com/forums/viewtopic.php?f=15&t=17375#p139176[/web:8geuufsp]
                                        • AureusA
                                          Aureus
                                          Hi driven,
                                          I see there's an old thread about skewing components. Very good.
                                          I made a couple of pretty detailed descriptions (with images included) what I did when creating those components and from them it's obvious I could accidentally make some skewed components (as I had that component inside component story + flipping). The fact that some trees were skewed didn't bother me as trees are in nature skewed anyway, in some sense. I didn't even notice some are skewed. And after all, visually they looked OK. The problem occurred when some trees started to rotate in a weird way.
                                          And what's even more strange is that...now I cannot make them 'dance' by repeating the same process.
                                          One thing from the thread you posted: Chris explained how to create a skewed component by rotating the inner component and scaling non-uniformly the outer one. I remember I used a flipping method (and maybe in one case I flipped the sub-component) as there's no point in rotating a face-me component.
                                          Yet, whatever I do now the trees behave normally.
                                          I replaced ill-behaving tree components with some other trees that used to be OK and then edited them to my liking. I did this manually not by reloading. Now all the trees behave as expected even though some of them are still skewed!
                                          So this is the catch:
                                          1. It's not the distance of the origin of my main model as trees rotating in a weird way do so even when they are a couple of metres distant from the origin which you can see if you import them into a new file.
                                          2. Those ones which used to behave unexpectedly were skewed but not all of my skewed trees behave like that.
                                          3. I cannot produce such behaviour by will nor the others who tried to do so.
                                          That's why I wrote it looks like this will remain some kind of mystery.
                                          I solved the problem by replacing problematic trees with some which are not but I don't know what actually went wrong.
                                          What?
                                          And why?
                                            mac1
                                            Trouble shooting to help NSA and DOD that was a theme always in our minds and you see that same from folks from the FAA during accident investigations. I do not think they think it is cheap approach and we all have a tendency to fall in that trap that can lead one astray. So it is best to not make statements like made here in.
