    AmbientOcclusion for SketchUp released
    extensions
    42 Posts 15 Posters 14.7k Views 15 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      @fluid said:
      Yes, unfortunately the SketchUp api doesn't allow to render directly into the standard viewport
      Within a custom Tool, you can draw in the viewport. http://www.sketchup.com/intl/en/developer/docs/ourdoc/view#draw2d
      Tomasz from Thea Render even found a way to inject the render in the assembly to be able to see the render in the viewport while using any tool. But that's another master level πŸ˜„
      • jujuJ Offline
        juju
        I'm trying to figure out how this differs from Visualizer...
        • mariochaM Offline
          mariocha
          Repeated BUGSPLATs, on Windows 7 under Parallels. πŸ˜•
          %(#008000)[Mario C.
            jiminy-billy-bob
            Visualizer is a true renderer (although very limited features). This is "just" Ambient Occlusion.
            It could actually be very interesting if it was happening in the viewport. For client presentation/interaction, etc
            Sometimes you just want to add some depth to the model without a realistic render.
            • pbacotP Offline
              Is the blur in the last image a part of the plugin's function or post pro?
              • F Offline
                fluid
                The blur is a ray-traced depth of field done directly by the plugin (in the pro version)
                • FrederikF Offline
                  Frederik
                  @pixero said:
                  Isn't that what LightUp does?
                  Thea4SU is also able to do this, hence you're wrong, Nicola...
                  Cheers
                  Kim Frederik
                  • F Offline
                    fluid
                    Thanks for pointing that out, we'll look into it for the upcoming release
                    • F Offline
                      fluid
                      We just did a new release, fixing the Bugsplat that some users were experiencing. You can get it here
                        sepo
                        Hmmm...The output looks like Podium version 1.x with no lighting and AO preset. I remember it well as wrote a preset and it was damn fast. If is not real time in the SU viewport it is step backward IMHO.
                        • pbacotP Offline
                          What would realtime in the SU Viewport mean? You could view your models like this while navigating and working on them?
                          • olisheaO Offline
                            olishea
                            would be cool if it baked the textures
                            oli
                              πŸ‘
                              • jujuJ Offline
                                juju
                                @fluid said:
                                We just released a new version of AmbientOcclusion, you can get it here: http://www.ambientocclusion-sketchup.com
                                This new version adds rendering directly inside the SketchUp viewport.
                                [flash:7ci503sq]https://www.youtube.com/v/Rst3-SoYAvA[/flash:7ci503sq]
                                nice...
                                • F Offline
                                  fluid
                                  We just released a new version of AmbientOcclusion, adding support for SketchUp 2015 for Mac and fixing some bugs. You can get it here.
                                  • olisheaO Offline
                                    olishea
                                    I like it; simple and effective.
                                    Would be awesome if you had an option to overlay the sketchup lines onto the render in one shot πŸ˜‰ Anti-aliased of course. Should be able to maintain the current sketchup line style too such as line extension.
                                    Many people like to make simple "clay" renders with a line overlay to help reveal details.
                                    A vignette option may also be cool. Goes really well with AO renders.
                                    oli
                                    • F Offline
                                      fluid
                                      We just released AmbientOcclusion 1.5.0, you can get it here.
                                      In this version:
                                      • Added hard shadows
                                      • Added opacity control for xray effect
                                      Hard Shadows
                                      X-Ray
                                        tim
                                        I'm giving this a quick tryout and so far I quite like what I see. On my 3y.o. iMac it renders modest models very rapidly - my whole-house model is taking quite a while though, unsurprisingly.
                                        Two annoyances I noticed pretty quickly
                                        a) once you've turned on 'render viewport' I can't see a way to turn it off. closing the model window seems to be the only option, followed by reopening. Not as friendly as it could be.
                                        b) it seems to take an interesting view of what is visible and what is not. When rendering my house from a view supposedly only showing the layer for the timber frame the rendering was displaying many other layers but not all. Odd. If you would like to use it for testing I'll happily send you a copy of the model file.
                                        Oh, and I just noticed that it leaves the sliders (used by opacity setting etc) lying around on the screen.
                                          Jim
                                          I like it also because it's easy and fast even on my old laptop. But after I do a few renders, SketchUp gets really slow to do anything. Even just creating a box starts lagging. I'm going to guess you are using SketchUp observers inefficiently.
                                          • pbacotP Offline
                                            I guess I don't get it. The rendering looks nice but the shadows look unrealistic to me. A lot people like this sort of thing though.
                                            EDIT: I don't use SketchUp (live) a lot for project demonstrations, but I did the other day. I admit this feature might have enhanced the appearance of the model in that process.
                                            • 1 / 3
