    AmbientOcclusion for SketchUp released
    extensions
    42 Posts 15 Posters 17.3k Views 15 Watching
    • F
      fluid
      Yes, unfortunately the SketchUp api doesn't allow to render directly into the standard viewport
      • PixeroP
        Pixero
        Isn't that what LightUp does?
        • jiminy-billy-bobJ
          jiminy-billy-bob
          Within a custom Tool, you can draw in the viewport. http://www.sketchup.com/intl/en/developer/docs/ourdoc/view#draw2d
          Tomasz from Thea Render even found a way to inject the render in the assembly to be able to see the render in the viewport while using any tool. But that's another master level πŸ˜„
          • jujuJ
            juju
            I'm trying to figure out how this differs from Visualizer...
            • mariochaM
              mariocha
              Repeated BUGSPLATs, on Windows 7 under Parallels. πŸ˜•
              %(#008000)[Mario C.
              • jiminy-billy-bobJ
                jiminy-billy-bob
                Visualizer is a true renderer (although very limited features). This is "just" Ambient Occlusion.
                It could actually be very interesting if it was happening in the viewport. For client presentation/interaction, etc
                Sometimes you just want to add some depth to the model without a realistic render.
                • pbacotP
                  Is the blur in the last image a part of the plugin's function or post pro?
                  • F
                    fluid
                    The blur is a ray-traced depth of field done directly by the plugin (in the pro version)
                    • FrederikF
                      Frederik
                      Thea4SU is also able to do this, hence you're wrong, Nicola...
                      Cheers
                      Kim Frederik
                      • F
                        fluid
                        Thanks for pointing that out, we'll look into it for the upcoming release
                        • F
                          fluid
                          We just did a new release, fixing the Bugsplat that some users were experiencing. You can get it here
                            sepo
                            Hmmm...The output looks like Podium version 1.x with no lighting and AO preset. I remember it well as wrote a preset and it was damn fast. If is not real time in the SU viewport it is step backward IMHO.
                            • pbacotP
                              What would realtime in the SU Viewport mean? You could view your models like this while navigating and working on them?
                              • olisheaO
                                olishea
                                would be cool if it baked the textures
                                oli
                                  πŸ‘
                                  • jujuJ
                                    juju
                                    @fluid said:
                                    We just released a new version of AmbientOcclusion, you can get it here: http://www.ambientocclusion-sketchup.com
                                    This new version adds rendering directly inside the SketchUp viewport.
                                    [flash:7ci503sq]https://www.youtube.com/v/Rst3-SoYAvA[/flash:7ci503sq]
                                    nice...
                                    • F
                                      fluid
                                      We just released a new version of AmbientOcclusion, adding support for SketchUp 2015 for Mac and fixing some bugs. You can get it here.
                                      • olisheaO
                                        olishea
                                        I like it; simple and effective.
                                        Would be awesome if you had an option to overlay the sketchup lines onto the render in one shot πŸ˜‰ Anti-aliased of course. Should be able to maintain the current sketchup line style too such as line extension.
                                        Many people like to make simple "clay" renders with a line overlay to help reveal details.
                                        A vignette option may also be cool. Goes really well with AO renders.
                                        oli
                                        • F
                                          fluid
                                          We just released AmbientOcclusion 1.5.0, you can get it here.
                                          In this version:
                                          • Added hard shadows
                                          • Added opacity control for xray effect
                                          Hard Shadows
                                          X-Ray
                                          • T
                                            tim
                                            I'm giving this a quick tryout and so far I quite like what I see. On my 3y.o. iMac it renders modest models very rapidly - my whole-house model is taking quite a while though, unsurprisingly.
                                            Two annoyances I noticed pretty quickly
                                            a) once you've turned on 'render viewport' I can't see a way to turn it off. closing the model window seems to be the only option, followed by reopening. Not as friendly as it could be.
                                            b) it seems to take an interesting view of what is visible and what is not. When rendering my house from a view supposedly only showing the layer for the timber frame the rendering was displaying many other layers but not all. Odd. If you would like to use it for testing I'll happily send you a copy of the model file.
                                            Oh, and I just noticed that it leaves the sliders (used by opacity setting etc) lying around on the screen.
                                            • 1 / 3
