    [Plugin] Selection Toys
    594 Posts 121 Posters 397.1k Views 121 Watching
    • E Offline
      Esense3d
      Hello
      Tomtom
      Can i Translate this somehow?
      Please Help
      Roland F.
        acheilman
        This is by far the plugin I use the most. Does anyone know if there is a way to make hot commands similar to 3dmax or softimage for the selection toys. I know you can right click and get to the tool from there when you have a selection, but I do not see an option for a hot key in my preferences. I find myself wanting to press the 2 or E keys frequently.
          You can set up a shortcut to any native or plugin generated menu/context-menu command.
          But for that command to appear in the filtered list, then that command must be available when you open Preferences > Shortcuts dialog.
          So for example, if you want to shortcut 'Reverse Face' you must have a face preselected before opening the dialog, otherwise there will be no matching entry in the list.
          Pressing a shortcut key when the command is not available just does nothing.
          Remember you can assign the F-keys too, and keys in conjunction with modifiers like Shift/Ctrl/Alt
          Do not shortcut plain .,;[]<>/*- x s, TAB, plain-numerals, or the arrow-keys - as these are used by SketchUp and/or several plugins...
            acheilman
            The methods above did not seem to work. "reverse face" is in the dialouge box already as an option to apply a shortcut, but selection toys only has options to create shortcuts for the UI Settings, Edge Loops, And Cheat Sheet. Apologies if I am missing something
              JGA
              Works for me, did you have a face selected before opening your preferences?
              Regards,
              JGA
                AcesHigh
                Is Selection Toys working with Sketchup 2015 for you guys?
                At Preferences, it shows there as loaded.
                But I get no toolbar, no right-click context options, no submenu either at Extensions nor Tools...
                  What version do you have installed?
                  (Yes - it works in SU2015)
                    AcesHigh
                    funny, I could swear I had written a post regarding a topic somewhere else where a guy had a problem with Selection Toys and you answered him, and the problem seemed to be his username had a Unicode character.
                    and yes, my username has a Unicode Character. (the username is AcesHigh, but for some reason, the windows path is user/usuário instead of user/aceshigh
                    And I have no idea how to change the user path without breaking Windows into an unusable mess.
                      Ah! Damn! That thing... achk. Yea, renaming your windows username is not ideal. hmm... This might be fixable. But I won't have time until next week to look at this.
                      EDIT: Just checked my latest changes to this extension - the latest one (2.3.9) was specifically to address unicode issues. Can you please confirm which version you have installed?
                        Doh! You got it from PluginStore, right?
                        I just realized I'd forgotten to hit Publish when I was updating the extension - so it was still version 2.3.8 that was available in the PluginStore.
                        Just updated it - try that one.
                          AcesHigh
                          yes, it was 2.3.8 😄
                          thanks ThomThom. Anyway, there are a few other plugins that are giving me errors too since Sketchup moved its plugin folders to appdata.
                          so I will try to change my username profile path following this tutorial
                          http://www.ghacks.net/2011/03/28/how-to-change-a-windows-account-name-and-user-profile-folder-name/
                          • gonashviliG Offline
                            gonashvili
                            @thomthom said:
                            http://www.sketchucation.com/forums/scf/download/file.php?id=17957&mode=view
                            [attachment=4:q89dnyc9]<!-- ia4 -->loop_sphere.png<!-- ia4 -->[/attachment:q89dnyc9]
                            Hey there sir Thom, this is highly off-topic, but whats the plugin that divides a box into segments like here on this pic?
                            Well, I take it you didn't do it by 'hand', manually..
                              No plugin for that - I just copied and pasted.
                              • Rich O BrienR Online
                                SplitUp to the rescue.... 😳
                                  or maybe this last one! 😉
                                  Minute 3.23
                                    bsfranza
                                    hi there together...
                                    i have a suggestion for a real good addition to this plugin 😃
                                    SELECT EDGES WHICH ARE PARALLEL
                                    why would one need that?! after importing a cad drawing where the hatch is exploded and oall of the lines happen to be on one layer 😕
                                    could be really handsome 😃
                                    thanks for your consideration on adding this option
                                    EDIT
                                    jim has answered my request here with a simple one liner 😄
                                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=64523%26amp;p=591916#p591916
                                    • romboutR Offline
                                      rombout
                                      Im on mac and nothing happens when i use the selection methods, i dont see any ouput in the ruby console or a error.
                                      Im using latest version 2.2.2 on SU215 osx 10.11.5
                                      • Dan RathbunD Offline
                                        Dan Rathbun
                                        No you're not. Latest (as of this reply) is 2.3.9.
                                        http://sketchucation.com/pluginstore?pln=tt_selection_toys
                                        or
                                        http://extensions.sketchup.com/en/content/selection-toys
                                        or
                                        https://github.com/thomthom/SelectionTools/releases
                                        I'm not here much anymore.
                                        • romboutR Offline
                                          rombout
                                          Now using 2.3 nothing happens on mac. Any one here with same issues on mac?
                                          I see no error in the console nothing
                                            I just checked it on my Mac. It works for me. Are you sure you're using it correctly? Try making a cube, select it all by dragging a selection fence around it. Then click the green Edges button in the toolbar. Does it change the selection to only the edges?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 29
                                            • 30
                                            • 15 / 30
