    [Plugin] Selection Toys
    594 Posts 121 Posters 587.6k Views 121 Watching
    • josephkim626J
      josephkim626
      For some reason, "Select Coplanar Faces" results some other parallel faces selected that aren't necessarily "Coplanar"?
        Could you post an example SKP file that exhibits this behavior?
        And please complete your profile with SketchUp version and operating system.
        • tt_suT
          tt_su
          The menu name is misleading - it's Same Direction instead of truly coplanar.
          • josephkim626J
            josephkim626
            Sorry, it is tested on windows 7 and sketchup 2014 (in different machines)
            Red circled face was the face that was used to execute "select coplanar face"
            example
            skp file
              So there's no bug. Just a naming confusion. it would appear that "Coplanar Faces" should read something like "Parallel Faces with Normals Facing the Same Direction". Select>Parallel Faces selects Parallel Faces regardless of the normal orientation.
                Perhaps 'CoNormal', rather than 'CoPlanar' ?
                • E
                  Esense3d
                  Hello
                  Tomtom
                  Can i Translate this somehow?
                  Please Help
                  Roland F.
                    acheilman
                    This is by far the plugin I use the most. Does anyone know if there is a way to make hot commands similar to 3dmax or softimage for the selection toys. I know you can right click and get to the tool from there when you have a selection, but I do not see an option for a hot key in my preferences. I find myself wanting to press the 2 or E keys frequently.
                      You can set up a shortcut to any native or plugin generated menu/context-menu command.
                      But for that command to appear in the filtered list, then that command must be available when you open Preferences > Shortcuts dialog.
                      So for example, if you want to shortcut 'Reverse Face' you must have a face preselected before opening the dialog, otherwise there will be no matching entry in the list.
                      Pressing a shortcut key when the command is not available just does nothing.
                      Remember you can assign the F-keys too, and keys in conjunction with modifiers like Shift/Ctrl/Alt
                      Do not shortcut plain .,;[]<>/*- x s, TAB, plain-numerals, or the arrow-keys - as these are used by SketchUp and/or several plugins...
                        acheilman
                        The methods above did not seem to work. "reverse face" is in the dialouge box already as an option to apply a shortcut, but selection toys only has options to create shortcuts for the UI Settings, Edge Loops, And Cheat Sheet. Apologies if I am missing something
                          JGA
                          Works for me, did you have a face selected before opening your preferences?
                          Regards,
                          JGA
                            AcesHigh
                            Is Selection Toys working with Sketchup 2015 for you guys?
                            At Preferences, it shows there as loaded.
                            But I get no toolbar, no right-click context options, no submenu either at Extensions nor Tools...
                              What version do you have installed?
                              (Yes - it works in SU2015)
                                AcesHigh
                                funny, I could swear I had written a post regarding a topic somewhere else where a guy had a problem with Selection Toys and you answered him, and the problem seemed to be his username had a Unicode character.
                                and yes, my username has a Unicode Character. (the username is AcesHigh, but for some reason, the windows path is user/usuário instead of user/aceshigh
                                And I have no idea how to change the user path without breaking Windows into an unusable mess.
                                  Ah! Damn! That thing... achk. Yea, renaming your windows username is not ideal. hmm... This might be fixable. But I won't have time until next week to look at this.
                                  EDIT: Just checked my latest changes to this extension - the latest one (2.3.9) was specifically to address unicode issues. Can you please confirm which version you have installed?
                                    Doh! You got it from PluginStore, right?
                                    I just realized I'd forgotten to hit Publish when I was updating the extension - so it was still version 2.3.8 that was available in the PluginStore.
                                    Just updated it - try that one.
                                      AcesHigh
                                      yes, it was 2.3.8 😄
                                      thanks ThomThom. Anyway, there are a few other plugins that are giving me errors too since Sketchup moved its plugin folders to appdata.
                                      so I will try to change my username profile path following this tutorial
                                      http://www.ghacks.net/2011/03/28/how-to-change-a-windows-account-name-and-user-profile-folder-name/
                                      • gonashviliG
                                        gonashvili
                                        @thomthom said:
                                        http://www.sketchucation.com/forums/scf/download/file.php?id=17957&mode=view
                                        [attachment=4:q89dnyc9]<!-- ia4 -->loop_sphere.png<!-- ia4 -->[/attachment:q89dnyc9]
                                        Hey there sir Thom, this is highly off-topic, but whats the plugin that divides a box into segments like here on this pic?
                                        Well, I take it you didn't do it by 'hand', manually..
                                          No plugin for that - I just copied and pasted.
                                            SplitUp to the rescue.... 😳
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 27 / 30
