    [Plugin] Selection Toys
    594 Posts 121 Posters 396.7k Views 121 Watching
    • tt_suT Offline
      tt_su
      @josephkim626 said:
      For some reason, "Select Coplanar Faces" results some other parallel faces selected that aren't necessarily "Coplanar"?
      The menu name is misleading - it's Same Direction instead of truly coplanar.
      • josephkim626J Offline
        josephkim626
        @dave r said:
        Could you post an example SKP file that exhibits this behavior?
        And please complete your profile with SketchUp version and operating system.
        Sorry, it is tested on windows 7 and sketchup 2014 (in different machines)
        Red circled face was the face that was used to execute "select coplanar face"
        example
        skp file
          So there's no bug. Just a naming confusion. it would appear that "Coplanar Faces" should read something like "Parallel Faces with Normals Facing the Same Direction". Select>Parallel Faces selects Parallel Faces regardless of the normal orientation.
            Perhaps 'CoNormal', rather than 'CoPlanar' ?
            • E Offline
              Esense3d
              Hello
              Tomtom
              Can i Translate this somehow?
              Please Help
              Roland F.
                acheilman
                This is by far the plugin I use the most. Does anyone know if there is a way to make hot commands similar to 3dmax or softimage for the selection toys. I know you can right click and get to the tool from there when you have a selection, but I do not see an option for a hot key in my preferences. I find myself wanting to press the 2 or E keys frequently.
                  You can set up a shortcut to any native or plugin generated menu/context-menu command.
                  But for that command to appear in the filtered list, then that command must be available when you open Preferences > Shortcuts dialog.
                  So for example, if you want to shortcut 'Reverse Face' you must have a face preselected before opening the dialog, otherwise there will be no matching entry in the list.
                  Pressing a shortcut key when the command is not available just does nothing.
                  Remember you can assign the F-keys too, and keys in conjunction with modifiers like Shift/Ctrl/Alt
                  Do not shortcut plain .,;[]<>/*- x s, TAB, plain-numerals, or the arrow-keys - as these are used by SketchUp and/or several plugins...
                    acheilman
                    The methods above did not seem to work. "reverse face" is in the dialouge box already as an option to apply a shortcut, but selection toys only has options to create shortcuts for the UI Settings, Edge Loops, And Cheat Sheet. Apologies if I am missing something
                      JGA
                      Works for me, did you have a face selected before opening your preferences?
                      Regards,
                      JGA
                        AcesHigh
                        Is Selection Toys working with Sketchup 2015 for you guys?
                        At Preferences, it shows there as loaded.
                        But I get no toolbar, no right-click context options, no submenu either at Extensions nor Tools...
                          What version do you have installed?
                          (Yes - it works in SU2015)
                            AcesHigh
                            funny, I could swear I had written a post regarding a topic somewhere else where a guy had a problem with Selection Toys and you answered him, and the problem seemed to be his username had a Unicode character.
                            and yes, my username has a Unicode Character. (the username is AcesHigh, but for some reason, the windows path is user/usuário instead of user/aceshigh
                            And I have no idea how to change the user path without breaking Windows into an unusable mess.
                              Ah! Damn! That thing... achk. Yea, renaming your windows username is not ideal. hmm... This might be fixable. But I won't have time until next week to look at this.
                              EDIT: Just checked my latest changes to this extension - the latest one (2.3.9) was specifically to address unicode issues. Can you please confirm which version you have installed?
                                Doh! You got it from PluginStore, right?
                                I just realized I'd forgotten to hit Publish when I was updating the extension - so it was still version 2.3.8 that was available in the PluginStore.
                                Just updated it - try that one.
                                  AcesHigh
                                  yes, it was 2.3.8 😄
                                  thanks ThomThom. Anyway, there are a few other plugins that are giving me errors too since Sketchup moved its plugin folders to appdata.
                                  so I will try to change my username profile path following this tutorial
                                  http://www.ghacks.net/2011/03/28/how-to-change-a-windows-account-name-and-user-profile-folder-name/
                                  • gonashviliG Offline
                                    gonashvili
                                    @thomthom said:
                                    http://www.sketchucation.com/forums/scf/download/file.php?id=17957&mode=view
                                    [attachment=4:q89dnyc9]<!-- ia4 -->loop_sphere.png<!-- ia4 -->[/attachment:q89dnyc9]
                                    Hey there sir Thom, this is highly off-topic, but whats the plugin that divides a box into segments like here on this pic?
                                    Well, I take it you didn't do it by 'hand', manually..
                                      No plugin for that - I just copied and pasted.
                                        SplitUp to the rescue.... 😳
                                          or maybe this last one! 😉
                                          Minute 3.23
                                            bsfranza
                                            hi there together...
                                            i have a suggestion for a real good addition to this plugin 😃
                                            SELECT EDGES WHICH ARE PARALLEL
                                            why would one need that?! after importing a cad drawing where the hatch is exploded and oall of the lines happen to be on one layer 😕
                                            could be really handsome 😃
                                            thanks for your consideration on adding this option
                                            EDIT
                                            jim has answered my request here with a simple one liner 😄
                                            http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=64523%26amp;p=591916#p591916
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 29 / 30
