    [Plugin] Drop Vertices
    54 Posts 18 Posters 155.1k Views 18 Watching
    • cottyC
      cotty
      What did I wrong here?
      klick image
      my SketchUp gallery
        Scant on what you've tried...
        arcs/curves do not drop unless they are exploded first...
        but see this example...
          Here is v2.0 http://sketchucation.com/pluginstore?pln=dropverts It now overcomes the curve issue.
          All edges in a dropped curve are now treated as separate edges.
          • cottyC
            cotty
            Thank you, nice update!
            my SketchUp gallery
              Does it possible to imagine a "drop" on X or Y direction ?
              (sure I can rotate all before but...)
              • mariochaM
                mariocha
                Hi TIG,
                I found that To Middle and To average do not work.
                Console indicates that line 93 z=z.to_s.to_l if z is faulty; cannot convert to length.
                I changed it to z=z.to_f if z . (float) They now work.
                Is this right ?
                %(#008000)[Mario C.
                • mariochaM
                  mariocha
                  In this port are functions for the 3 axis.
                  I tried to stick to the actual extension standards.
                  Re-named it since it does more than just drop.
                  Added LanguageHandler, french. And a contextual menu for the most frequent ones I use.
                  Mc-AlignEnds.rbz
                  %(#008000)[Mario C.
                    maxosmedia
                    Extension Errors Report
                    SketchUp: 26.2.242
                    OS: Tahoe
                    Ruby: 3.2.2
                    Extension: [unknown]
                    Error: SyntaxError (/Users/maxos/Library/Application Support/SketchUp 2026/SketchUp/Plugins/ropverts.rb:1: syntax error, unexpected ':', expecting end-of-input
                      @maxosmedia
                      Why have you posted 6 almost identical posts about something - one will do.
                      And your post doesn't contain enough info for the error either.
                      You can copy the whole thing and post that - it'd include the error details, and even the line number ?
                      In you copy/paste it looks like you didn't get the file name right - it's dropverts.rb - you missed off the 'd' - or have you somehow mangled the file's name in reality within the Plugins folder ?
                      ALSO note that this script is 16 years old and no one has posted here for 10 years. So SketchUp versions and their Ruby installations can vary to generate errors for older scripts when loaded in newer SketchUp versions !
                      Having said that, I just loaded it into v2026 [PC] and it works fine - just as expected... So please be more helpful with your reporting, so we can help you...
                        @tig
                        Extra removed.
                        • 3 / 3
