    Powerful Computer Required! [Urgent]
    30 Posts 10 Posters 4.0k Views 10 Watching
    • soloS
      18mb
      Dropbox - Error - Simplify your life
      (www.dropbox.com)
      • ely862meE
        ely862me
        That looks better because the heights are not as divided as mine.
        Anyway, I believe that the image itself is a bit over exaggerated in details for the job requested. Perhaps some smooth transitions, like a wavy terrain would be more like it.
        new map.rar
        Elisei (sketchupper)
        Come and See EliseiDesign
        • L
          Lersince1991
          Many thanks for the help everyone, its looking fantastic, I think ely862me's version has worked the best as it is the healthiest and has the most detail.
          I'll be sure to post final photographs up when I can!
          ely862me: It would be good if you could explain your workflow? Just that there seems to be a noise where I would expect flat surfaces, I actually quite like it but just wondered if you did it in a more powerful program like the suggested blender? or wether it is in fact from sketchup?
          Many thanks again, excellent help from the guru's!
          • ely862meE
            ely862me
            You're welcome!
            Which one are you referring to? The first or this last one ?
            The first one is achieved with Bitmap to mesh plugin and cleaned up. Perhaps the height which I chose made it that way.
              attached is a zipped .blend file. you can see in the animated .gif below the setting to change to affect the height...
              ...when happy click the apply button on all 3 modifiers to make the actual mesh and export to .dae
              landscape.zip
              this will tax your system less than SketchUp will and give you more control.
                Appetizing birthday cake! πŸ˜„
                  [edg3d:3t8cla6v]SoFlZ8yn4gXn6nB[/edg3d:3t8cla6v]
                  polycrunching the mesh can get it as low as <3mb...
                  landscape.zip
                  ...an interesting challenge for sure. thanks for sharing it!
                  looking forward to final output.
                  • hellnbakH
                    hellnbak
                    My computer could handle it, but I couldn't. Most of what you guys are talking about is WAY over my head πŸ˜’
                    • L
                      Lersince1991
                      Completed! πŸ‘
                      Took 60 hours on the CNC milling bed using a 6mm drill bit, I wanted smaller but it was unrealistic.
                      from 36mm Birch plywood (2x 18mm 4' x 4').
                      Next stages for it are to fill in areas of water with resin, not decided on the colour or to leave it clear yet though!
                      And 3D printed buildings will be set on top of that.
                      I will also use the digital model for some renders.
                      • ely862meE
                        ely862me
                        Nice ! πŸ‘
                        60 hours , woah, is it worthy ? Power consumption wise ?
                        I hope to finish my CNC setup soon and I will be looking forward for some tips and tricks about sketchup and cnc.
                        • L
                          Lersince1991
                          Hi, Just a follow up.
                          I've attached a photo of the final model including 3d printed parts and 5kg of tinted black resin for the water and a welded steel stand consisting of 18 unsupported legs.
                          If your interested you can see the rest of the project which is now on my website, all modelled in sketchup and rendered manually in photoshop. - I still have a lot of images to add but you can scroll down to view whats there at the minute.
                          http://www.lukeriggall.co.uk/architecture/the-arc-centre
                          The final master model stats were around 25 million edges, 10 million faces within 400k components, performance was manageable (on 2015) by using layers.
                          • KrisidiousK
                            Krisidious
                            Nice work guys... Nice method Rich. An interesting project. I saw one online that used plywood sheets and created a large and rolling topographical map and was then filled with glass and in the end it made a beautiful body of water cut from earth.
                            Only a few thousand...
                            403 Forbidden
                            (duffylondon.com)
                            http://duffylondon.com/wp-content/uploads/2014/07/Abyss-Table_03b_web-800x800.jpg
                            And here's another I liked. More simple and natural... As well as feasible.
                            http://netdna.coolthings.com/wp-content/uploads/2014/07/greg-klassen-river-collection-tables-1.jpg
                            By: Kristoff Rand
                            • hellnbakH
                              hellnbak
                              403 Forbidden
                              (duffylondon.com)
                              Wow, I really like the looks of that Abyss table, absolutely mesmerizing. Don't know why they are limiting it to just 25 copies after working on the design for a year. Unless they are being realistic about how many they will sell at that price! And you would think they would be a tad more specific about the type of wood used, instead of just saying "high-quality wood". And they give the dimensions, but not the weight. All that wood and glass gotta weigh quite a bit (unless their idea of high-quality wood is balsa πŸ˜† )
                              I would definitely cover it with bulletproof glass or something unbreakable, can't imagine what it would cost to replace one of those custom glass layers.
                              Definitely gonna get one or two of them, just as soon as I buy a lottery ticket (and win)
                              • KrisidiousK
                                Krisidious
                                I did a design for one after seeing it and estimated it to be about 6k in cost of materials I think. I'd have to go find it to be sure. And I considered the same thing. VERY heavy. I bid mine using 4x8 sheets though. And if someone was smart enough to design wisely and to use a CNC to optimize the cutting, you might be able to trim some cost in reusing scraps.
                                By: Kristoff Rand
                                • 2 / 2
