    Powerful Computer Required! [Urgent]
    30 Posts 10 Posters 4.0k Views 10 Watching
      based off your displacement map Blender can do this...
      ...and you can control the density/height
      but a collada export of 500k tris result in a 75mb file. importing that into SketchUp you probably need to go make coffee, hoover house, cut lawn etc....
      • ely862meE
        ely862me
        127 mb πŸ˜„
        Elisei (sketchupper)
        Come and See EliseiDesign
        • L
          Lersince1991
          @ely862me said:
          127 mb πŸ˜„
          Wow how on earth did your machine do that?!
          Does it zip for dropbox etc...?
          • L
            Lersince1991
            or maybe run CleanUp first?
            • ely862meE
              ely862me
              Actually it did it quite fast and it is not that much of a deal. Just an i7 3770, others than processor speed is not important with sketchup. The eaten memory is just 3.5 gb.
              I am trying to clean it up by bits to not draw it into the not responding mode.
              Question: Why don't use the cam program that creates the code for the cnc? Usually these programs have the ability to create mesh from bitmaps.
              • L
                Lersince1991
                Excellent,
                Really? I spoke to them any they said they couldn't so been trying all day to do it this way instead. πŸ˜•
                edit: Plus I need this anyway for the master model for render to be fair.
                • ely862meE
                  ely862me
                  https://www.dropbox.com/s/yuqj2r3jer4mej8/bmp%20a.rar?dl=0 still over 70mb
                  • soloS
                    18mb
                    Dropbox - Error - Simplify your life
                    (www.dropbox.com)
                    • ely862meE
                      ely862me
                      That looks better because the heights are not as divided as mine.
                      Anyway, I believe that the image itself is a bit over exaggerated in details for the job requested. Perhaps some smooth transitions, like a wavy terrain would be more like it.
                      new map.rar
                      • L
                        Lersince1991
                        Many thanks for the help everyone, its looking fantastic, I think ely862me's version has worked the best as it is the healthiest and has the most detail.
                        I'll be sure to post final photographs up when I can!
                        ely862me: It would be good if you could explain your workflow? Just that there seems to be a noise where I would expect flat surfaces, I actually quite like it but just wondered if you did it in a more powerful program like the suggested blender? or wether it is in fact from sketchup?
                        Many thanks again, excellent help from the guru's!
                        • ely862meE
                          ely862me
                          You're welcome!
                          Which one are you referring to? The first or this last one ?
                          The first one is achieved with Bitmap to mesh plugin and cleaned up. Perhaps the height which I chose made it that way.
                            attached is a zipped .blend file. you can see in the animated .gif below the setting to change to affect the height...
                            ...when happy click the apply button on all 3 modifiers to make the actual mesh and export to .dae
                            landscape.zip
                            this will tax your system less than SketchUp will and give you more control.
                              Appetizing birthday cake! πŸ˜„
                                [edg3d:3t8cla6v]SoFlZ8yn4gXn6nB[/edg3d:3t8cla6v]
                                polycrunching the mesh can get it as low as <3mb...
                                landscape.zip
                                ...an interesting challenge for sure. thanks for sharing it!
                                looking forward to final output.
                                • hellnbakH
                                  hellnbak
                                  My computer could handle it, but I couldn't. Most of what you guys are talking about is WAY over my head πŸ˜’
                                  • L
                                    Lersince1991
                                    Completed! πŸ‘
                                    Took 60 hours on the CNC milling bed using a 6mm drill bit, I wanted smaller but it was unrealistic.
                                    from 36mm Birch plywood (2x 18mm 4' x 4').
                                    Next stages for it are to fill in areas of water with resin, not decided on the colour or to leave it clear yet though!
                                    And 3D printed buildings will be set on top of that.
                                    I will also use the digital model for some renders.
                                    • ely862meE
                                      ely862me
                                      Nice ! πŸ‘
                                      60 hours , woah, is it worthy ? Power consumption wise ?
                                      I hope to finish my CNC setup soon and I will be looking forward for some tips and tricks about sketchup and cnc.
                                      • L
                                        Lersince1991
                                        Hi, Just a follow up.
                                        I've attached a photo of the final model including 3d printed parts and 5kg of tinted black resin for the water and a welded steel stand consisting of 18 unsupported legs.
                                        If your interested you can see the rest of the project which is now on my website, all modelled in sketchup and rendered manually in photoshop. - I still have a lot of images to add but you can scroll down to view whats there at the minute.
                                        http://www.lukeriggall.co.uk/architecture/the-arc-centre
                                        The final master model stats were around 25 million edges, 10 million faces within 400k components, performance was manageable (on 2015) by using layers.
                                        • KrisidiousK
                                          Krisidious
                                          Nice work guys... Nice method Rich. An interesting project. I saw one online that used plywood sheets and created a large and rolling topographical map and was then filled with glass and in the end it made a beautiful body of water cut from earth.
                                          Only a few thousand...
                                          403 Forbidden
                                          (duffylondon.com)
                                          http://duffylondon.com/wp-content/uploads/2014/07/Abyss-Table_03b_web-800x800.jpg
                                          And here's another I liked. More simple and natural... As well as feasible.
                                          http://netdna.coolthings.com/wp-content/uploads/2014/07/greg-klassen-river-collection-tables-1.jpg
                                          By: Kristoff Rand
                                          • hellnbakH
                                            hellnbak
                                            403 Forbidden
                                            (duffylondon.com)
                                            Wow, I really like the looks of that Abyss table, absolutely mesmerizing. Don't know why they are limiting it to just 25 copies after working on the design for a year. Unless they are being realistic about how many they will sell at that price! And you would think they would be a tad more specific about the type of wood used, instead of just saying "high-quality wood". And they give the dimensions, but not the weight. All that wood and glass gotta weigh quite a bit (unless their idea of high-quality wood is balsa πŸ˜† )
                                            I would definitely cover it with bulletproof glass or something unbreakable, can't imagine what it would cost to replace one of those custom glass layers.
                                            Definitely gonna get one or two of them, just as soon as I buy a lottery ticket (and win)
