    Powerful Computer Required! [Urgent]
    30 Posts 10 Posters 4.0k Views 10 Watching
      attached is a zipped .blend file. you can see in the animated .gif below the setting to change to affect the height...
      ...when happy click the apply button on all 3 modifiers to make the actual mesh and export to .dae
      landscape.zip
      this will tax your system less than SketchUp will and give you more control.
        Appetizing birthday cake! πŸ˜„
          [edg3d:3t8cla6v]SoFlZ8yn4gXn6nB[/edg3d:3t8cla6v]
          polycrunching the mesh can get it as low as <3mb...
          landscape.zip
          ...an interesting challenge for sure. thanks for sharing it!
          looking forward to final output.
          • hellnbakH
            hellnbak
            My computer could handle it, but I couldn't. Most of what you guys are talking about is WAY over my head πŸ˜’
            • L
              Lersince1991
              Completed! πŸ‘
              Took 60 hours on the CNC milling bed using a 6mm drill bit, I wanted smaller but it was unrealistic.
              from 36mm Birch plywood (2x 18mm 4' x 4').
              Next stages for it are to fill in areas of water with resin, not decided on the colour or to leave it clear yet though!
              And 3D printed buildings will be set on top of that.
              I will also use the digital model for some renders.
              • ely862meE
                ely862me
                Nice ! πŸ‘
                60 hours , woah, is it worthy ? Power consumption wise ?
                I hope to finish my CNC setup soon and I will be looking forward for some tips and tricks about sketchup and cnc.
                Elisei (sketchupper)
                Come and See EliseiDesign
                • L
                  Lersince1991
                  Hi, Just a follow up.
                  I've attached a photo of the final model including 3d printed parts and 5kg of tinted black resin for the water and a welded steel stand consisting of 18 unsupported legs.
                  If your interested you can see the rest of the project which is now on my website, all modelled in sketchup and rendered manually in photoshop. - I still have a lot of images to add but you can scroll down to view whats there at the minute.
                  http://www.lukeriggall.co.uk/architecture/the-arc-centre
                  The final master model stats were around 25 million edges, 10 million faces within 400k components, performance was manageable (on 2015) by using layers.
                  • KrisidiousK
                    Krisidious
                    Nice work guys... Nice method Rich. An interesting project. I saw one online that used plywood sheets and created a large and rolling topographical map and was then filled with glass and in the end it made a beautiful body of water cut from earth.
                    Only a few thousand...
                    403 Forbidden
                    (duffylondon.com)
                    http://duffylondon.com/wp-content/uploads/2014/07/Abyss-Table_03b_web-800x800.jpg
                    And here's another I liked. More simple and natural... As well as feasible.
                    http://netdna.coolthings.com/wp-content/uploads/2014/07/greg-klassen-river-collection-tables-1.jpg
                    By: Kristoff Rand
                    • hellnbakH
                      hellnbak
                      403 Forbidden
                      (duffylondon.com)
                      Wow, I really like the looks of that Abyss table, absolutely mesmerizing. Don't know why they are limiting it to just 25 copies after working on the design for a year. Unless they are being realistic about how many they will sell at that price! And you would think they would be a tad more specific about the type of wood used, instead of just saying "high-quality wood". And they give the dimensions, but not the weight. All that wood and glass gotta weigh quite a bit (unless their idea of high-quality wood is balsa πŸ˜† )
                      I would definitely cover it with bulletproof glass or something unbreakable, can't imagine what it would cost to replace one of those custom glass layers.
                      Definitely gonna get one or two of them, just as soon as I buy a lottery ticket (and win)
                      • KrisidiousK
                        Krisidious
                        I did a design for one after seeing it and estimated it to be about 6k in cost of materials I think. I'd have to go find it to be sure. And I considered the same thing. VERY heavy. I bid mine using 4x8 sheets though. And if someone was smart enough to design wisely and to use a CNC to optimize the cutting, you might be able to trim some cost in reusing scraps.
                        By: Kristoff Rand
                        • 2 / 2
