    Powerful Computer Required! [Urgent]
    30 Posts 10 Posters 3.8k Views 10 Watching
    • L
      Lersince1991
      or maybe run CleanUp first?
      • ely862meE
        ely862me
        Actually it did it quite fast and it is not that much of a deal. Just an i7 3770, others than processor speed is not important with sketchup. The eaten memory is just 3.5 gb.
        I am trying to clean it up by bits to not draw it into the not responding mode.
        Question: Why don't use the cam program that creates the code for the cnc? Usually these programs have the ability to create mesh from bitmaps.
        Elisei (sketchupper)
        Come and See EliseiDesign
        • L
          Lersince1991
          Excellent,
          Really? I spoke to them any they said they couldn't so been trying all day to do it this way instead. πŸ˜•
          edit: Plus I need this anyway for the master model for render to be fair.
          • ely862meE
            ely862me
            https://www.dropbox.com/s/yuqj2r3jer4mej8/bmp%20a.rar?dl=0 still over 70mb
            • soloS
              18mb
              Dropbox - Error - Simplify your life
              (www.dropbox.com)
              • ely862meE
                ely862me
                That looks better because the heights are not as divided as mine.
                Anyway, I believe that the image itself is a bit over exaggerated in details for the job requested. Perhaps some smooth transitions, like a wavy terrain would be more like it.
                new map.rar
                • L
                  Lersince1991
                  Many thanks for the help everyone, its looking fantastic, I think ely862me's version has worked the best as it is the healthiest and has the most detail.
                  I'll be sure to post final photographs up when I can!
                  ely862me: It would be good if you could explain your workflow? Just that there seems to be a noise where I would expect flat surfaces, I actually quite like it but just wondered if you did it in a more powerful program like the suggested blender? or wether it is in fact from sketchup?
                  Many thanks again, excellent help from the guru's!
                  • ely862meE
                    ely862me
                    You're welcome!
                    Which one are you referring to? The first or this last one ?
                    The first one is achieved with Bitmap to mesh plugin and cleaned up. Perhaps the height which I chose made it that way.
                      attached is a zipped .blend file. you can see in the animated .gif below the setting to change to affect the height...
                      ...when happy click the apply button on all 3 modifiers to make the actual mesh and export to .dae
                      landscape.zip
                      this will tax your system less than SketchUp will and give you more control.
                        Appetizing birthday cake! πŸ˜„
                          [edg3d:3t8cla6v]SoFlZ8yn4gXn6nB[/edg3d:3t8cla6v]
                          polycrunching the mesh can get it as low as <3mb...
                          landscape.zip
                          ...an interesting challenge for sure. thanks for sharing it!
                          looking forward to final output.
                          • hellnbakH
                            hellnbak
                            My computer could handle it, but I couldn't. Most of what you guys are talking about is WAY over my head πŸ˜’
                            • L
                              Lersince1991
                              Completed! πŸ‘
                              Took 60 hours on the CNC milling bed using a 6mm drill bit, I wanted smaller but it was unrealistic.
                              from 36mm Birch plywood (2x 18mm 4' x 4').
                              Next stages for it are to fill in areas of water with resin, not decided on the colour or to leave it clear yet though!
                              And 3D printed buildings will be set on top of that.
                              I will also use the digital model for some renders.
                              • ely862meE
                                ely862me
                                Nice ! πŸ‘
                                60 hours , woah, is it worthy ? Power consumption wise ?
                                I hope to finish my CNC setup soon and I will be looking forward for some tips and tricks about sketchup and cnc.
                                • L
                                  Lersince1991
                                  Hi, Just a follow up.
                                  I've attached a photo of the final model including 3d printed parts and 5kg of tinted black resin for the water and a welded steel stand consisting of 18 unsupported legs.
                                  If your interested you can see the rest of the project which is now on my website, all modelled in sketchup and rendered manually in photoshop. - I still have a lot of images to add but you can scroll down to view whats there at the minute.
                                  http://www.lukeriggall.co.uk/architecture/the-arc-centre
                                  The final master model stats were around 25 million edges, 10 million faces within 400k components, performance was manageable (on 2015) by using layers.
                                  • KrisidiousK
                                    Krisidious
                                    Nice work guys... Nice method Rich. An interesting project. I saw one online that used plywood sheets and created a large and rolling topographical map and was then filled with glass and in the end it made a beautiful body of water cut from earth.
                                    Only a few thousand...
                                    403 Forbidden
                                    (duffylondon.com)
                                    http://duffylondon.com/wp-content/uploads/2014/07/Abyss-Table_03b_web-800x800.jpg
                                    And here's another I liked. More simple and natural... As well as feasible.
                                    http://netdna.coolthings.com/wp-content/uploads/2014/07/greg-klassen-river-collection-tables-1.jpg
                                    By: Kristoff Rand
                                    • hellnbakH
                                      hellnbak
                                      403 Forbidden
                                      (duffylondon.com)
                                      Wow, I really like the looks of that Abyss table, absolutely mesmerizing. Don't know why they are limiting it to just 25 copies after working on the design for a year. Unless they are being realistic about how many they will sell at that price! And you would think they would be a tad more specific about the type of wood used, instead of just saying "high-quality wood". And they give the dimensions, but not the weight. All that wood and glass gotta weigh quite a bit (unless their idea of high-quality wood is balsa πŸ˜† )
                                      I would definitely cover it with bulletproof glass or something unbreakable, can't imagine what it would cost to replace one of those custom glass layers.
                                      Definitely gonna get one or two of them, just as soon as I buy a lottery ticket (and win)
                                      • KrisidiousK
                                        Krisidious
                                        I did a design for one after seeing it and estimated it to be about 6k in cost of materials I think. I'd have to go find it to be sure. And I considered the same thing. VERY heavy. I bid mine using 4x8 sheets though. And if someone was smart enough to design wisely and to use a CNC to optimize the cutting, you might be able to trim some cost in reusing scraps.
                                        By: Kristoff Rand
                                        • 2 / 2
