    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.0m Views 183 Watching
    • fredo6F Offline
      NEW RELEASE 1.7a - 19 Oct 2014
      This release is required for SU 2014 when your username contains non-ascii characters
      Note that non-ascii characters are not supported for SU13 and previous versions of Sketchup
      Download new release at main post
      • W Offline
        WebBeau
        Thanks a lot
        • E Offline
          Esense3d
          Hello Fredo
          I would like to translate this plugin on all German but can not find language files
          Bezier spline is only partially translated
          Fredo I now have this new address
          Roland F Swiss
          • fredo6F Offline
            @esense3d said:
            Hello Fredo
            Roland F Swiss
            Thanks for this proposal.
            BezierSpline is not compliant with LibFredo6. So, it is built differently. I will make a full refresh one of these days.
            Anyway, the current version already includes a German translation.
            • E Offline
              Esense3d
              Hello Fredo
              I See but it is not Full Translated
              Just Parts of it
              I also have your other plugins translated fully ie including the main folder
              and other
              Therefore, any icons etcetera in German
              If you want I send you these versions as rbz versions to
              If you do not mind I would publish in the German part please
              Roland F.
              • fredo6F Offline
                NEW RELEASE 1.7b - 22 Mar 2015
                This release removes noisy traces at startup of Sketchup
                • fredo6F Offline
                  NEW RELEASE 1.7c - 23 Mar 2015
                  This release removes noisy traces at startup of Sketchup - second trial
                    rdcraighead
                    This site is terribly confusing. I just want to buy BezierSpline script, but see no link to allow me to do so. Why does this need to be so complicated?
                      GĂĄbor
                      What do you mean by being complicated? In the PluginStore you can easily find it by a simple search: http://sketchucation.com/pluginstore?pln=BezierSpline
                        It's free.
                        • MsketcherM Offline
                          Msketcher
                          I'm having problems with locking axis reference while drawing a classic bezier curve. It looks like it's trying to, as the "square mark" at the cursor is filled and turns color depending upon which arrow key I press, but it does not restrict axis for me. I'm on a Mac, SketchUp 2015 Pro. I've looked at the manual and thought I am doing everything right. I swear I had it working earlier today...
                          • N Offline
                            NZSnowman
                            Just downloaded. Can not wait to try. Looks great!
                            • I Offline
                              iris1211
                              why I can't download it....
                                I can only guess it's because you didn't follow any of the links in the first post of this thread.
                                Since several options are provided, surely you can get it from one of them.
                                  dbrenders
                                  Hi Fredo I'm a big fan and user of your plugins, i have them all in my must have plugins list. 😄 .
                                  These days I've been working with bz curves for doing wires and cables etc... and i found a bit dificult some time to place contol points in the right way due to the snapping . Also when trying to reposition or edit the points was bit diffuclt to adjust in an accurate way.
                                  Do you think it would be possible to have in future versions handles or any kind of gizmo thing, ( as thomthom uses in the bz surfaces) for this tools, would be very helpful and much appreciated. Thank you very much in advance .
                                  Best
                                  David
                                  Enviat des del meu SM-P600 usant Tapatalk
                                  • fredo6F Offline
                                    Best
                                    David
                                    You can use arrow and Ctrl-Arrows to get some inferences along axes.
                                    But otherwise, the best is to try to use Construction points.
                                    I'll try to make it easier in a next version.
                                    • N Offline
                                      numerobis
                                      A spline behavior like in ACAD would be nice. 😉
                                      I think they are more harmonic or fluent. Here is a direct comparison:
                                      http://abload.de/img/splinetesth9sgw.jpg
                                      • fredo6F Offline
                                        Which method did you use in your example: CubicBezier, Catmull, FSpline?
                                        • N Offline
                                          numerobis
                                          Catmull. What is FSpline? With CubicBezier you mean the B-Spline, right?
                                          • fredo6F Offline
                                            Catmull, Cubic Bezier and FSpline pass by the Control Points (BSpline does not).
                                            Fred
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 22
                                            • 23
                                            • 13 / 23
