    Twisted Dovetail
    35 Posts 11 Posters 6.6k Views 11 Watching
    • S ShepherdS Offline
      S Shepherd
      See if this helps. The first image I posted is the starting position.
      • jeff hammondJ Offline
        oops, i missed that bit.. was thinking the coincident point would have to be in the middle somewhere. the animation clears it up though.
        πŸ‘
        • KrisidiousK Offline
          Krisidious
          Nice animation Shep...
          This is one of the ones that looked faked.
          http://www.richardjonesfurniture.com/Tables-Chairs/boire-coffee-table/boire-table-3-600.jpg
          By: Kristoff Rand
            Krisidious
            So the twist has to be identical on the inside front as it is on the backside top for it to work?
            By: Kristoff Rand
              What makes it look fake?
                because it looks like there's not a way to assemble/dissemble it.. that's what the joint is for anyway, right?
                like-- "hey bud, why don't you try to figure that one out hehheh"..
                or is it inherently stronger than a traditional dovetail?
                  S Shepherd
                  One thing that's different about this is the miter on the end pair. I think it's done like this.
                    Krisidious
                    The seam along the dovetails...
                    By: Kristoff Rand
                      That's not a seam. It's a marking gauge line for the baseline. You'll sometimes see it on hand cut non-twisted dovetails too. It's part of the marking out for the joint. The baseline is often cut deep because it forms a guide for the chisel when cleaning out the waste.
                      http://www.philadelphiafurnitureworkshop.com/category/show/images/Dovetails_000.JPG
                        slbaumgartner
                        The mental hurdle in this joint as nicely illustrated in Scott's video is that the joint slides together along a 45 degree sloped line, not straight in as we are accustomed to. That fools the mind and eye into thinking it can't go together at all!
                        Steve
                        • tuna1957T Offline
                          tuna1957
                          if memory strikes right , the late Tage Frid shows how to layout , cut and fit this joint in his book " Tage Frid Teaches Woodworking" . Hope to give it a try just for grins one of these days.
                            I had the pleasure of watching Tage Frid handcut dovetails once years ago. He came to speak to a college woodworking class I was in. We watched as he laid out and quickly cut a set of dovetails. When he was finished, he put the joint together and then he looked around the room. Not at us but at the walls of the shop. The professor asked him what he was looking for and he replied, "A dovetail hammer." No one in the class including the professor ever heard of a dovetail hammer before. Frid broke into a smile and walked over to the hand tool wall and grabbed a claw hammer. He walked back over to where he'd been working and gave one of the pins a few whacks to spread out the fibers and fill a small gap he'd created when cutting the joint. Then he held up the hammer with a grin and said, "This is a dovetail hammer." πŸ˜†
                            • robertWanR Offline
                              robertWan
                              Ipossible?
                              Robert
                              jaskolczy ogon.skp
                                They slide in/out on the diagonal ?
                                  robertWan
                                  No. πŸ˜„
                                  Radial.
                                  .skp is up.
                                  Robert
                                    @robertwan said:
                                    Ipossible?
                                    ha. wow.. at first i was thinking "ok, there's no way that's going together.. especially getting all 4 pieces to do it"
                                    but, after checking your .skp, it appears like it will actually work.
                                    πŸ‘
                                      slbaumgartner
                                      It could be a challenge to create a jig for cutting that one accurately!
                                        robertWan
                                        I made on the CNC.
                                        Robert
                                        • cottyC Offline
                                          cotty
                                          Nice and clever!
                                          my SketchUp gallery
                                            robertWan
                                            I tried on the CNC, but it can not be done. The test is .skp file above.
                                            http://scontent-b.cdninstagram.com/hphotos-xaf1/t51.2885-15/e15/10693512_322800104559875_387077836_n.jpg
                                            Robert
