    Twisted Dovetail
    35 Posts 11 Posters 7.2k Views 11 Watching
      @krisidious said:
      @dave r said:
      What makes it look fake?
      The seam along the dovetails...
      That's not a seam. It's a marking gauge line for the baseline. You'll sometimes see it on hand cut non-twisted dovetails too. It's part of the marking out for the joint. The baseline is often cut deep because it forms a guide for the chisel when cleaning out the waste.
      http://www.philadelphiafurnitureworkshop.com/category/show/images/Dovetails_000.JPG
        slbaumgartner
        The mental hurdle in this joint as nicely illustrated in Scott's video is that the joint slides together along a 45 degree sloped line, not straight in as we are accustomed to. That fools the mind and eye into thinking it can't go together at all!
        Steve
        • tuna1957T
          tuna1957
          if memory strikes right , the late Tage Frid shows how to layout , cut and fit this joint in his book " Tage Frid Teaches Woodworking" . Hope to give it a try just for grins one of these days.
            I had the pleasure of watching Tage Frid handcut dovetails once years ago. He came to speak to a college woodworking class I was in. We watched as he laid out and quickly cut a set of dovetails. When he was finished, he put the joint together and then he looked around the room. Not at us but at the walls of the shop. The professor asked him what he was looking for and he replied, "A dovetail hammer." No one in the class including the professor ever heard of a dovetail hammer before. Frid broke into a smile and walked over to the hand tool wall and grabbed a claw hammer. He walked back over to where he'd been working and gave one of the pins a few whacks to spread out the fibers and fill a small gap he'd created when cutting the joint. Then he held up the hammer with a grin and said, "This is a dovetail hammer." πŸ˜†
            • robertWanR
              robertWan
              Ipossible?
              Robert
              jaskolczy ogon.skp
                They slide in/out on the diagonal ?
                • robertWanR
                  robertWan
                  No. πŸ˜„
                  Radial.
                  .skp is up.
                  Robert
                  • jeff hammondJ
                    @robertwan said:
                    Ipossible?
                    ha. wow.. at first i was thinking "ok, there's no way that's going together.. especially getting all 4 pieces to do it"
                    but, after checking your .skp, it appears like it will actually work.
                    πŸ‘
                      slbaumgartner
                      It could be a challenge to create a jig for cutting that one accurately!
                      • robertWanR
                        robertWan
                        I made on the CNC.
                        Robert
                        • cottyC
                          cotty
                          Nice and clever!
                          my SketchUp gallery
                          • robertWanR
                            robertWan
                            I tried on the CNC, but it can not be done. The test is .skp file above.
                            http://scontent-b.cdninstagram.com/hphotos-xaf1/t51.2885-15/e15/10693512_322800104559875_387077836_n.jpg
                            Robert
                            • jeff hammondJ
                              do you mean it can't be done with CNC or it can't be done at all?
                              • robertWanR
                                robertWan
                                Chisel can be done.
                                I'll try to draw it later, it looked as if made on CNC.
                                Robert
                                • robertWanR
                                  robertWan
                                  It's not bad, I thought there would be more problems.
                                  That's what it looks like when made on CNC, there are few problems.
                                  1-6 can be corrected with a chisel. 7 and 8 is an empty space, but invisible.
                                  There's only 7x7x7 [mm] to cut out with a chisel.
                                  Robert
                                  jaskolczy ogon CNC.skp
                                  • jeff hammondJ
                                    are you going to cut one?
                                    • robertWanR
                                      robertWan
                                      Minimum of two pieces.
                                      Robert
                                      • 2 / 2
