    Big problem (sketchup 8)
    22 Posts 5 Posters 2.4k Views 5 Watching
    • P
      PPGiorgio
      please up, today i'm still not able to use plugin or other functions that use the webdialog
      • K
        kaas
        Have you tried re-installing SketchUp and/or updating your SketchUp version to it's latest maintenance release?
        • P
          PPGiorgio
          yes i uploaded to the latest version of sketchup and the lastest one of internet explorer (setted now as default browser).
          i think that is a problem due to the connection between the program and internet explorer (something about web dialog) but i still didn't find any solutions.
          when i started using sketchup it worked, after a few time dind'nt work more.
          so in this moment i'm not able to use many plugins and other tools of sketchup such as the 3d warehouse window(if i try to run it from the program), and the same for other tools.
          • BoxB
            As Tig mentioned above, Have you cleared the Cache of Internet Explorer?
            Check that your antivirus and firewall are allowing SU to connect.
            • P
              PPGiorgio
              the firewall is allowing su to connect, i just checked
              • P
                PPGiorgio
                may can it be a problem with java or ruby?
                • K
                  kaas
                  There seems something broken in the communication between the webdialog and sketchup. Maybe you have you disabled JavaScript in your internet explorer settings? are you absolutely sure Javascript is enabled?
                  • P
                    PPGiorgio
                    i just checked javascrpit is enable, very strange...
                    • P
                      PPGiorgio
                      no one can solve this problem?
                        You were asked twice if you had cleared the Internet Explorer cache but you never responded that you did. Have you tried this?
                        Have you considered trying SU2015 to see if you get a different result than you're getting with SU8?
                        • P
                          PPGiorgio
                          Yes, I cleared the cache.
                          I tried with SU2014 but with no results.
                          Thank you for the fast reply
                            Hmmm....
                            It must be something with your computer because it isn't happening to everyone. What version of Windows are you running? Do you have access to another computer you could use to try this?
                              Can you try to upgrade your Internet Explorer to the latest version... [v11?]
                              Empty the cache and check the Internet Options are set up to allow the running of javascript and not be too restrictive on what is opened etc...
                              Then restart SketchUp and try the web-dialogs again.
                              • P
                                PPGiorgio
                                Windows 7 Home Premium.
                                Yes, I think too because in the first period I installed SU on this pc there were no problems, then suddenly it began to not runnung more.
                                I'm sure that if I use another pc I will not have problem, but I use this one for the university in fact I think that the last solution I have is to format it.
                                • P
                                  PPGiorgio
                                  I already have the latest verion.
                                  Now i'm checking for the option about java.
                                  IE seems not to have problems for the restriction of java, i checked in the plug-in window and it is enabled, than I checked the security panel and the voice about the script of java applet and it is enabled too.
                                  Thank you so much
                                  • BoxB
                                    Fire wall, anti virus, windows updates, adblocker, popup blocker, internet security options, adaware virus,caches, cookies, so many possible reasons......mostly related to PC maintenance/house keeping.
                                    Difficult in any language.
                                      It is "javascript" - not "Java" which is a different thing...
                                      As @Box says, there are many things to look at, many beyond the scope of plain SketchUp...
                                      For example, have you recently run a virus-checker ?
                                      • P
                                        PPGiorgio
                                        Have you any advice about the most common problems?
