    Grumman G-44 Widgeon
    79 Posts 13 Posters 15.2k Views 13 Watching
    • Bryan KB Offline
      @hellnbak said:
      Can't wait to see the finished model, I think it's going to be awesome πŸ‘
      Thanks hellnback, but there are going to be a lot of mistakes on this one. SketchUp is now crashing constantly and becoming a lot less precise.
      It will look good from a distance. πŸ˜†
      • pbacotP Offline
        Model's looking great there Bryan! Watching for more! (Happy New Year, guys) β˜€G44Widgeon29.png
        • Bryan KB Offline
          Thanks for the "props", pbacot. (I see what you did there πŸ˜† )
          • hellnbakH Offline
            hellnbak
            Any idea what the problem might be? Have you tried reinstalling it?
            • Bryan KB Offline
              πŸ˜„ Old PC and high poly count.
              • hellnbakH Offline
                hellnbak
                Yes, it's easy to see that the poly count would be very high
                And, if I may say, unnecessarily so. Having that many polys doesn't add anything to your model as far as quality or appearance goes, it only (as you are discovering) serves to place a heavy load on your computer. Is there any chance you could backtrack (hopefully you have saved previous versions in various stages of development) and cut down on the polys?
                • Bryan KB Offline
                  πŸ˜† I won't be backtracking on this one at all. This particular aircraft design has serious compound curvilinear surfaces. Without Curviloft, I could not have made this model. I would still be working on just the fuselage.
                  Update: Fixed the cockpit side window configuration and proportion.
                    Fantastic mate, really nailed the aircraft with that model, how about a render?
                    • Bryan KB Offline
                      Thanks! Still have some more details left to create.
                      • Bryan KB Offline
                        Been busy at the new job and getting home late so haven't been making a lot of progress. Here's an update, but it's mostly detail corrections. I still need to finish the wing details and add the rear landing gear, maybe put a pilot in it.
                        • Bryan KB Offline
                          Added exhaust and main wing flaps. Reduced the polygons in an aft fuselage section as well an area near top of cockpit.
                            Something I find quite useful is to have hidden geometry switched on and then move single points in a group to match other groups around them. This is handy when you use curviloft and find different sections with different profiles. You can see these as lines or bulges on the surface of the completed loft that look 'out of alignment'. Sorry if I am not being clear I will post a pic later to better show what I mean.
                            • Bryan KB Offline
                              That's a very good explanation. That's pretty much exactly how I do it as well as cleaning up bad surfaces. It's very helpful. πŸ‘
                              • hellnbakH Offline
                                hellnbak
                                Brian
                                Any progress on the beast?
                                • Bryan KB Offline
                                  @hellnbak said:
                                  Brian
                                  Been busy with the new job. Long days. I'm anxious to finish it. I've at least had time to see some mistakes and plan out the fixes.
                                  • Bryan KB Offline
                                    Minor fixes and additions:
                                    Completed outer flap actuators
                                    Added door handle
                                    Added pilot and copilot (yes, they are twins!)
                                    Added interior main landing gear housing for later space to created runway version.
                                    Almost completed paint scheme.
                                    Some faces were reversed and did not show right in render.
                                    • Bryan KB Offline
                                      First test render using Twilight v2 for the first time. Number 6, High, setting. (I think I'm going to like Twilight)
                                      Satin finish on white paint and semi-gloss on the turquoise/aquamarine.
                                      • hellnbakH Offline
                                        hellnbak
                                        πŸ˜†
                                        Looking very nice.
                                        Obvious question - when are you gonna tackle the props? Not really necessary for the flying version, just a blur, but you mention a runway version is to come. I know they can be a pain, I had to build some a while back, took a little time to get the shape and pitch just right.
                                        • Bryan KB Offline
                                          @hellnbak said:
                                          πŸ˜†
                                          Looking very nice.
                                          I'll build those soon. Actually, I think props are easy. I figured out a trick a few years ago when I modeled an RUV. I just hope I can remember the steps. πŸ˜†
                                          • okomtaO Offline
                                            okomta
                                            i'm watching,,nice plane,,:D
                                            • 4 / 4
