    Grumman G-44 Widgeon
    79 Posts 13 Posters 14.1k Views 13 Watching
    • hellnbakH Offline
      hellnbak
      Can't wait to see the finished model, I think it's going to be awesome πŸ‘
      • Bryan KB Offline
        Pontoon braces added. Pontoons angled correctly.
        • Bryan KB Offline
          Thanks hellnback, but there are going to be a lot of mistakes on this one. SketchUp is now crashing constantly and becoming a lot less precise.
          It will look good from a distance. πŸ˜†
          • pbacotP Offline
            Model's looking great there Bryan! Watching for more! (Happy New Year, guys) β˜€G44Widgeon29.png
            • Bryan KB Offline
              Thanks for the "props", pbacot. (I see what you did there πŸ˜† )
              • hellnbakH Offline
                hellnbak
                Any idea what the problem might be? Have you tried reinstalling it?
                • Bryan KB Offline
                  πŸ˜„ Old PC and high poly count.
                  • hellnbakH Offline
                    hellnbak
                    Yes, it's easy to see that the poly count would be very high
                    And, if I may say, unnecessarily so. Having that many polys doesn't add anything to your model as far as quality or appearance goes, it only (as you are discovering) serves to place a heavy load on your computer. Is there any chance you could backtrack (hopefully you have saved previous versions in various stages of development) and cut down on the polys?
                    • Bryan KB Offline
                      πŸ˜† I won't be backtracking on this one at all. This particular aircraft design has serious compound curvilinear surfaces. Without Curviloft, I could not have made this model. I would still be working on just the fuselage.
                      Update: Fixed the cockpit side window configuration and proportion.
                        Fantastic mate, really nailed the aircraft with that model, how about a render?
                        • Bryan KB Offline
                          Thanks! Still have some more details left to create.
                          • Bryan KB Offline
                            Been busy at the new job and getting home late so haven't been making a lot of progress. Here's an update, but it's mostly detail corrections. I still need to finish the wing details and add the rear landing gear, maybe put a pilot in it.
                            • Bryan KB Offline
                              Added exhaust and main wing flaps. Reduced the polygons in an aft fuselage section as well an area near top of cockpit.
                                Something I find quite useful is to have hidden geometry switched on and then move single points in a group to match other groups around them. This is handy when you use curviloft and find different sections with different profiles. You can see these as lines or bulges on the surface of the completed loft that look 'out of alignment'. Sorry if I am not being clear I will post a pic later to better show what I mean.
                                • Bryan KB Offline
                                  That's a very good explanation. That's pretty much exactly how I do it as well as cleaning up bad surfaces. It's very helpful. πŸ‘
                                  • hellnbakH Offline
                                    hellnbak
                                    Brian
                                    Any progress on the beast?
                                    • Bryan KB Offline
                                      @hellnbak said:
                                      Brian
                                      Been busy with the new job. Long days. I'm anxious to finish it. I've at least had time to see some mistakes and plan out the fixes.
                                      • Bryan KB Offline
                                        Minor fixes and additions:
                                        Completed outer flap actuators
                                        Added door handle
                                        Added pilot and copilot (yes, they are twins!)
                                        Added interior main landing gear housing for later space to created runway version.
                                        Almost completed paint scheme.
                                        Some faces were reversed and did not show right in render.
                                        • Bryan KB Offline
                                          First test render using Twilight v2 for the first time. Number 6, High, setting. (I think I'm going to like Twilight)
                                          Satin finish on white paint and semi-gloss on the turquoise/aquamarine.
                                          • hellnbakH Offline
                                            hellnbak
                                            πŸ˜†
                                            Looking very nice.
                                            Obvious question - when are you gonna tackle the props? Not really necessary for the flying version, just a blur, but you mention a runway version is to come. I know they can be a pain, I had to build some a while back, took a little time to get the shape and pitch just right.
                                            • 4 / 4
