    Grumman G-44 Widgeon
    79 Posts 13 Posters 16.5k Views 13 Watching
    • Bryan KB
      Almost done... with the flying version. I still want to do a runway version to show the landing gear.
      Still more detail left to add on this one. Most of this version's changes were made possible by hellnback sending me some very detailed plans. Thank you again.
      Those pontoons were... interesting, but I can now do crazy curvilinear surfaces thanks to Curviloft.
      This is straight SketchUp with a watermark background, ground turned on and colored and profiles and edges turned off.
      Wow. For some reason this file jumped from 6mb to 39mb!
      • hellnbakH
        hellnbak
        Can't wait to see the finished model, I think it's going to be awesome πŸ‘
        • Bryan KB
          Pontoon braces added. Pontoons angled correctly.
          • Bryan KB
            Thanks hellnback, but there are going to be a lot of mistakes on this one. SketchUp is now crashing constantly and becoming a lot less precise.
            It will look good from a distance. πŸ˜†
            • pbacotP
              Model's looking great there Bryan! Watching for more! (Happy New Year, guys) β˜€G44Widgeon29.png
              • Bryan KB
                Thanks for the "props", pbacot. (I see what you did there πŸ˜† )
                • hellnbakH
                  hellnbak
                  Any idea what the problem might be? Have you tried reinstalling it?
                  • Bryan KB
                    πŸ˜„ Old PC and high poly count.
                    • hellnbakH
                      hellnbak
                      Yes, it's easy to see that the poly count would be very high
                      And, if I may say, unnecessarily so. Having that many polys doesn't add anything to your model as far as quality or appearance goes, it only (as you are discovering) serves to place a heavy load on your computer. Is there any chance you could backtrack (hopefully you have saved previous versions in various stages of development) and cut down on the polys?
                      • Bryan KB
                        πŸ˜† I won't be backtracking on this one at all. This particular aircraft design has serious compound curvilinear surfaces. Without Curviloft, I could not have made this model. I would still be working on just the fuselage.
                        Update: Fixed the cockpit side window configuration and proportion.
                          Fantastic mate, really nailed the aircraft with that model, how about a render?
                          • Bryan KB
                            Thanks! Still have some more details left to create.
                            • Bryan KB
                              Been busy at the new job and getting home late so haven't been making a lot of progress. Here's an update, but it's mostly detail corrections. I still need to finish the wing details and add the rear landing gear, maybe put a pilot in it.
                              • Bryan KB
                                Added exhaust and main wing flaps. Reduced the polygons in an aft fuselage section as well an area near top of cockpit.
                                  Something I find quite useful is to have hidden geometry switched on and then move single points in a group to match other groups around them. This is handy when you use curviloft and find different sections with different profiles. You can see these as lines or bulges on the surface of the completed loft that look 'out of alignment'. Sorry if I am not being clear I will post a pic later to better show what I mean.
                                  • Bryan KB
                                    That's a very good explanation. That's pretty much exactly how I do it as well as cleaning up bad surfaces. It's very helpful. πŸ‘
                                    • hellnbakH
                                      hellnbak
                                      Brian
                                      Any progress on the beast?
                                      • Bryan KB
                                        @hellnbak said:
                                        Brian
                                        Been busy with the new job. Long days. I'm anxious to finish it. I've at least had time to see some mistakes and plan out the fixes.
                                        • Bryan KB
                                          Minor fixes and additions:
                                          Completed outer flap actuators
                                          Added door handle
                                          Added pilot and copilot (yes, they are twins!)
                                          Added interior main landing gear housing for later space to created runway version.
                                          Almost completed paint scheme.
                                          Some faces were reversed and did not show right in render.
                                          • Bryan KB
                                            First test render using Twilight v2 for the first time. Number 6, High, setting. (I think I'm going to like Twilight)
                                            Satin finish on white paint and semi-gloss on the turquoise/aquamarine.
                                            • 4 / 4
