    Grumman G-44 Widgeon
    79 Posts 13 Posters 15.2k Views 13 Watching
    • Bryan KB Offline
      Added exhaust and main wing flaps. Reduced the polygons in an aft fuselage section as well an area near top of cockpit.
        Something I find quite useful is to have hidden geometry switched on and then move single points in a group to match other groups around them. This is handy when you use curviloft and find different sections with different profiles. You can see these as lines or bulges on the surface of the completed loft that look 'out of alignment'. Sorry if I am not being clear I will post a pic later to better show what I mean.
        • Bryan KB Offline
          That's a very good explanation. That's pretty much exactly how I do it as well as cleaning up bad surfaces. It's very helpful. πŸ‘
          • hellnbakH Offline
            hellnbak
            Brian
            Any progress on the beast?
            • Bryan KB Offline
              @hellnbak said:
              Brian
              Been busy with the new job. Long days. I'm anxious to finish it. I've at least had time to see some mistakes and plan out the fixes.
              • Bryan KB Offline
                Minor fixes and additions:
                Completed outer flap actuators
                Added door handle
                Added pilot and copilot (yes, they are twins!)
                Added interior main landing gear housing for later space to created runway version.
                Almost completed paint scheme.
                Some faces were reversed and did not show right in render.
                • Bryan KB Offline
                  First test render using Twilight v2 for the first time. Number 6, High, setting. (I think I'm going to like Twilight)
                  Satin finish on white paint and semi-gloss on the turquoise/aquamarine.
                  • hellnbakH Offline
                    hellnbak
                    πŸ˜†
                    Looking very nice.
                    Obvious question - when are you gonna tackle the props? Not really necessary for the flying version, just a blur, but you mention a runway version is to come. I know they can be a pain, I had to build some a while back, took a little time to get the shape and pitch just right.
                    • Bryan KB Offline
                      @hellnbak said:
                      πŸ˜†
                      Looking very nice.
                      I'll build those soon. Actually, I think props are easy. I figured out a trick a few years ago when I modeled an RUV. I just hope I can remember the steps. πŸ˜†
                      • okomtaO Offline
                        okomta
                        i'm watching,,nice plane,,:D
                        • Bryan KB Offline
                          Okomta, I have posted the finished renders in the main gallery page.
                          Thank you the compliment.
                          • Leonard96L Offline
                            Leonard96
                            Added door handle
                            I've noticed that is a rendering software for a low PC, right? Can you tell me the name of it? Thank you!
                            My secret weapon is creativity
                              Leonard96
                              Added door handle
                              I've noticed that is a rendering software for a low PC, right? Can you tell me the name of it? Thank you! I need only the background(sky and land/water). It's kinda hard to make a background in sketchUP while rendering some scenes! You can't get too close to the model if the background is too large!
                              • Bryan KB Offline
                                It's the free version of Twilight. I was using Kerkythea before, but Twilight is far easier to use.
                                • 4 / 4
